Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more
Thread Tools
Old 16th February 2008, 00:52   #1 (permalink)
Superleggera's Avatar
Default Question on Laptop RAM Upgrade (unmatched modules)
Guys, I am planning to upgrade the RAM of my laptop. It’s a Lenovo Y410, with 2 memory slots and currently it has two 1 GB sticks filled in it. This machine would support a max of 4 GB RAM with 64 bit windows vista, but mine is 32 Bit windows vista which would support max of 3 GB RAM. My question is, If I put a 1 GB stick in one slot and 2 GB stick in another slot, will it create any problem? I remember some body saying for Core Duo processes, the memories have to be distributed evenly. Is this true?
Superleggera is offline   Reply With Quote
Old 16th February 2008, 01:29   #2 (permalink)
Rehaan's Avatar
From my rough understanding of it :
Generally DDR needs two pairs of "matched" ram... (ie same frequency and size) in order to make use of the DDR (double data rate).
However, in the case of a laptop, chances are that your FSB speed will probably be around the same as the ram speed (eg. 667Mhz), so in that case having DDR doesnt really give you any advantage.
Not sure how much of a difference it would make in other scenarios (eg. Ram 667MHz, FSB 800MHz)
I have a 667 FSB and 667 RAM, and i'm running one 512 667 and another 2gb 667. Works fine.
cya
R
__________________
The memory of you will ride by our side forever.
Old 16th February 2008, 06:14   #3 (permalink)
gopz's Avatar
You can go ahead and install 1x1GB and 1x2GB.
There will be no noticeable difference in the DDR speed, though it will not run at single channel mode.
gopz is offline   Reply With Quote
Old 16th February 2008, 08:46   #4 (permalink)
Check the bus speed and the speed of the ram you would be adding.
If there's a bus speed mismatch, I can guarantee that the system will slow down even if more RAM is present in the system.
Btw, by design 32bit OS support max 4GB ram.
Where did you get this idea of 32bit OS supporting only 3GB RAM?
__________________
LIC is best for Home and Auto Loans.
Be decent. Avoid four letter words starting with F. (Ford and Fiat) Haa haa!
subscrive is offline   Reply With Quote
Old 16th February 2008, 11:26   #5 (permalink)
ashthedivx's Avatar
As in general, just check the PCXXXX thing with DDR2 speed match between tow sticks which must be atleast 667 Mhz. However, 32bit OS do support > 3GB i.e. 4 GB Max.
As right now prices of DDR2 are on lower side, i would suggest you to pickup as much as you can.
Old 16th February 2008, 11:37   #6 (permalink)
yaar simple go to the shop keeper as him to put the ram. Run CPUZ and check out the specs of the new ram installed, Enjoy.
Old 16th February 2008, 23:59   #7 (permalink)
Rehaan's Avatar
Could you elaborate on that a little please, what exactly do you mean by "mismatch" ?
cya
R
__________________
Old 19th February 2008, 08:03   #8 (permalink)
Subscrive - I read it here
There are couple of other forums on this topic, but they are paid sites.
Old 19th February 2008, 08:17   #9 (permalink)
gopz's Avatar
32bit OS cannot see 4GB. The max it can see is around 3 to 3.5GB only.
Thread Tools
Ram rameshp Introduce yourself 1 21st September 2008 11:05
Ram Ram dosto Vikrocks Introduce yourself 11 24th May 2007 16:03
Unmatched Sounds with Infinity + JBL on Swift vishnugs Sound Off and Show Off 22 7th March 2007 14:28
question for laptop owners manaa45 Gadgets, Computers & Software 15 20th August 2005 00:52
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
