Go Back   Team-BHP > Indian Cars > Team-BHP Reviews > Long-Term Ownership Reviews
Long-Term Ownership Reviews Ownership reports, of Indian cars, spanning over several years and thousands of kms
Thread Tools
Old 4th March 2009, 21:49   #1 (permalink)
SS-Traveller's Avatar
Default Accent Viva CRDi Dec '04 - Bid Adieu After 106,063 km.
Missing engine
Should have started this thread some time earlier, but I was posting maintenance reports of my car to another thread - http://www.team-bhp.com/forum/long-t...ms-report.html (Accent Viva CRDI 38000 Kms report). However, the last few weeks have seen my Accent require more frequent visits to garages to set things right, although I have never been left stranded on the road.
The latest in the series of troubles faced was today. 7.20 AM, on my way to work 70 km away, the car lost power and started knocking when I had hardly covered 15 km. Instant provisional diagnosis - one cylinder malfunctioning. Immediate apprehension - injector gone. That'll be a big hole in the pocket!
Decided to have the car checked outside, by my old-time mechanic friend. Logic - Injectors are a whole lot more expensive at Hyundai than they are outside.
10 AM: Injectors fine - disconnecting their electrics one at a time left the engine dead. With injector failure, the dead injector being disconnected would have made no difference. Small sigh of relief. Guy says probably a blown head gasket. I agree. Ok, let's open up the head.
The cam cover is removed, and what's that? A broken piece of metal there? Cylinder 3, inlet valve rocker broken in two. accent-viva-crdi-dec-04-bid-adieu-after-106-063-km-abcd0002.jpg
Diagnosis done, look no further. accent-viva-crdi-dec-04-bid-adieu-after-106-063-km-abcd0001.jpg
But wait. Something's wrong with the camshaft too. Cylinder 2 inlet cam lobe has damage to it - metal's chewed up. accent-viva-crdi-dec-04-bid-adieu-after-106-063-km-abcd0005.jpg
The Cyl 2 inlet valve rocker roller also damaged.accent-viva-crdi-dec-04-bid-adieu-after-106-063-km-abcd0007.jpg
2 rockers and the camshaft replaced. Suspect damage may have been done by incompetent people changing the timing belt at HMP Delhi in end-Jan'09. Can't prove anything.
Total cost: Rs.5000. Genuine Hyundai camshaft = 3000, each genuine rocker = 400, + labour. Would have worked out twice as expensive (or more) if this was done at co. workshop. Car runs like clockwork. I'm happy and home at 3 PM. Bunked work today.
__________________
“Medicine, the only profession that labors incessantly to destroy the reason for its existence” ~ James Bryce
Old 4th March 2009, 21:54   #2 (permalink)
Nice to know engine damage can be repaired in such a small amount.
I am not an expert but normally shouldnt one have a complete engine overhaul when you have any engine work done.
Experts: Clarity on this would be nice to know.
Indian1979 is offline   Reply With Quote
Old 4th March 2009, 22:11   #3 (permalink)
sameel's Avatar
lucky fellow.
my accent DLS is in for engine work now.. head gasket blown. cylinder needs reboring! since its got rusted due to leak of water into cylinder due to gasket leak!! head also goin to be shaved! hehe. its run 1.5lakh kms now. and its almost 8 yrs old. so its ok
vlaves might need replacement!! injectors too might need replacement!
she will be running with an almost brand new engine after the work.
sameel is offline   Reply With Quote
Old 4th March 2009, 22:26   #4 (permalink)
Eddy's Avatar
Dada, we need a more detailed ownership experience please.
Also, from where do you source genuine Hyundai parts ?
__________________
Car is no longer a luxury; parking space is.
Swift VDI(ABS) Sep 07 - 53K Kms
Ford Ikon Flair Sep 04 - 70K Kms
Eddy is offline   Reply With Quote
Old 4th March 2009, 22:27   #5 (permalink)
Default The Brakes
On my fourth set of pads now, installed at about 87,000 km. The first set lasted upto 33,000, second set changed at 58,000. The discs were turned also during the recent change. Cost of pads + lathework + labour was Rs.1500. Rear brakes work fine, still have some material on the shoes. Opened and checked. Should last 100,000+ km.
__________________
Old 4th March 2009, 22:59   #6 (permalink)
Default The Tyres
The original equipment Bridgestone tubed tyres lasted for about 56,000 km. I then changed to a set of 4 Infinity tubeless tyres. Discovered major tread damage to two tyres due to a suspected rear wheel misalignment at around 88,000 km, and posted separately to this thread earlier:
http://www.team-bhp.com/forum/tyre-a...ml#post1155029 (Good VFM Infinity tyre damaged).
Am now on new Bridgestone tubeless on the front axle and Infinity tubeless on the rear axle. Happy with the ride and grip. Cost of the 2 new Bridgestones: Rs.4400, including fitment and balancing.
__________________
Old 9th March 2009, 13:17   #7 (permalink)
Default The suspension
Mostly noise-free till now. have just noticed a hard noise on braking/accelerating hard. Suspect steering rack or anti-roll bar mounting bushes are gone. Will check it out the coming weekend.
At around 59k km, both the tie-rod ends were changed under warranty.
Rear suspension is riding fine.
I like this suspension setup. Ride quality is not too cushy and soft, but neither is it hard and intrusive. Doesn't transmit all the minor bumps into the cabin, but holds the car well through corners.
__________________
Old 11th March 2009, 19:08   #8 (permalink)
Default The first day I was stranded...
This was in July '08, and I was on my way to work, somewhere in rural Gurgaon. A little before 8 AM. Car running as sweetly as ever, 65K on the odo. The engine suddenly cut out. Died. No knocks, no jerks, no hiccups. Just died, and I pulled over to the side of the road. Cranked a few times, no joy - not even a splutter.
Tried to call Hyundai's helpline. No answer. No one picked up the phone. So I decided to wait till the HMP opens. Ten minutes later, I thought of trying to start again. And it did! One turn of the key and the engine fired, settling into a smooth idle again. Perplexed, I started off again. 2 km down the road, the engine died again. And wouldn't start again. This time there was a sharp whine from the rear, somewhere under the rear seat...
__________________
Old 11th March 2009, 19:39   #9 (permalink)
supremeBaleno's Avatar
Location: Weekdays at DetroitOfIndia (Chennai) & Weekends at VeniceOfTheEast (Alappuzha).
Whoa !! That is quite some kms done.
I also have OE tubed Bridgestones on my car and at 27K kms they still look good for another 25K kms atleast. Waiting for these to wear off to change to wider tyres. Looks like it is going to be a long wait since my annual running is only 7k kms.
__________________
Suzuki Baleno : 91bhp @ 5500rpm, 130.5Nm @ 3000 rpm, 14kmpl in city @ 100% a/c.
Fun & economy needn't be mutually exclusive.
Old 11th March 2009, 19:51   #10 (permalink)
Default ...and why I was stranded.
That whine was enough to announce a fuel pump fault. Switch off and let the pump cool off a little, and it would start working again. A few km, and it would fail due to overheating. That seemed fine, and I was carrying an 80k km/4yr warranty, so I was not too concerned. Set off to the workshop, and had the car back in an hour or so with a new pump. Did you check for dirt in the tank? Service advisor: Your tank is absolutely clean, Sir.
And three days later, the same whine from the rear and the engine died on me again. Second trip to HMP Mathura Road...
__________________
Old 12th March 2009, 12:18   #11 (permalink)
Default Second visit to HMP - and a third.
Back to HMP I went. This time it was a quick turn-around - half an hour and I was out. Sir, a connection was loose. Five km from the workshop, the engine dies again. Back to the workshop, and I really blow my fuse. GM Services turns up to find out what happened. Fuel pump taken out and replaced - again (free of cost). Tank inspected and found to be really dirty - cleaned for Rs.400, but not to my satisfaction. Why couldn't they check this the first time when I asked? Why was I bluffed to, the second time, about a loose connection?
Went back to my regular mechanic outside and had the tank re-cleaned. Never had the problem again in the last 25k km.
One interesting offshoot of this incident. HMP insisted the muck came from using XtraMile diesel, and that Hyundai recommends normal diesel. I checked with someone in Toyota too, and they recommend normal diesel too.
__________________
Old 13th May 2009, 11:21   #12 (permalink)
headers's Avatar
Thats a nice log you've got.. Whats your current Mileage?
__________________
Addicted to it - A 4L V8 producing 300+ horses and ...
Old 13th May 2009, 14:36   #13 (permalink)
Current mileage is 92.5k km. Small niggling noises coming up from the suspension. Will have them attended to this week, prior to taking the car to Pune next week.
__________________
Old 15th May 2009, 20:58   #14 (permalink)
...have just noticed a hard noise on braking/accelerating hard. Suspect steering rack or anti-roll bar mounting bushes are gone.
Small niggling noises coming up from the suspension. Will have them attended to this week...
Strange are the ways of car mechanics!
That hard noise (a kind of 'khut') from somewhere below my feet had been there for the last couple of months, and it occurred on hard braking or hard acceleration. No noise over potholes or rough roads (which rules out rack/tie-rod end/anti-roll bar bushes). No noise on accelerating with full steering lock (rules out driveshaft noise). Could be struts - all tight there, no oil leaks, no damping loss. HMP told me to leave the car for a day (or two) to diagnose the noise. Couldn't do that for some time now due to a lot of other commitments. Took it to one of my regular mechanics last weekend. He told me he'd have to strip the whole suspension/steering setup to find out the source. Naah!
Took the car today to another of my regular mechanics. He was also convinced like me, that the suspension/steering need not be opened up straight away. We spent about 2 and a half hours diagnosing the noise.
Finally, all it took was straightening of the engine shield (the underbody sump protection plate, aka the bash plate) and tightening the engine mounts.
Voila! Noise gone... Running smooth as ever now.
__________________
Old 16th May 2009, 00:34   #15 (permalink)
Deeps's Avatar
@SS: Why dont you just stick to one mechanic/workshop?
4yr/80K warranty is impressive.
__________________
Stupidity is not a handicap! Park somewhere else!
Deeps is offline   Reply With Quote
Thread Tools
Problems with Accent Viva CRDi goel.honey Modifications & Accessories 16 9th March 2009 09:15
Hyundai Accent Viva CRDI tez Sedans 2 30th April 2008 16:24
Accent VIVA CRDi for Sale Ricky_63 Shifting gears 9 1st February 2008 11:52
hyundai accent viva crdi lamborghini The Indian Car Scene 35 25th May 2006 20:28
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
