Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 25th May 2006, 19:23   #1 (permalink)
Default Performance mods for RX135? (In Pune)
For quite some time, I am toying around with the idea of either souping up good old RX135, or exchanging it with another powerful bike (No ZMA or P-180 for me, but something from Yamaha stable like Fazer 250). I am still not decided on it, but what possible modifications can be done on RX135?
I need your inputs on following:
  1. Is it worthwhile to modify 5 year old bike?
  2. My RX135 is 4 gear, so does it make sense to do just perf mods and no gear box change?
  3. What all modifications can be done and cost for each? (I don't care about cosmetics).
  4. More importantly, who can do it in Pune? Contact number? I don't want a road-side garagewalah to screw up the bike.
__________________
Drive fast, but drive safe.
RX135 is offline   Reply With Quote
Old 25th May 2006, 19:29   #2 (permalink)
typeOnegative's Avatar
Err, make it a favour for two.
typeOnegative is offline   Reply With Quote
Old 25th May 2006, 20:36   #3 (permalink)
autozealot's Avatar
Ooops! Three I guess.........but in Mumbai pls
az
autozealot is offline   Reply With Quote
Old 25th May 2006, 22:49   #4 (permalink)
mail4ajo's Avatar
Yet to quench your desire, you could do the following regular stuff:
1. Port and polish the Chamber
2. Put high performance Fibre REED Valves
3. Power air filter
4. Custom Expansion Chamber
5. Quick Throttle
6. Upjet your CARB
7. Get smaller sprockets up front
mail4ajo is offline   Reply With Quote
Old 26th May 2006, 01:05   #5 (permalink)
3. Power air filter
5. Quick Throttle
6. Upjet your CARB
Do I not have to replace whole gear box to 5 speed one? What would be approximate costs per each modification?
__________________
Old 26th May 2006, 14:03   #6 (permalink)
mail4ajo's Avatar
Gear box replacement is really tough and expensive, stick to the stock.
1. Port and polish the Chamber - 2 -3K depending on machinist
2. Put high performance Fibre REED Valves - 750Rs
3. Power air filter - 1000-3000 depending on the brand
4. Custom Expansion Chamber - 1000-2000 based on make
5. Quick Throttle - 800Rs
6. Upjet your CARB-200-300rs
7. Get smaller sprockets up front - change entire kit-500Rs
Old 26th May 2006, 14:25   #7 (permalink)
airfoil's Avatar
This is what I'd recommend:
* Buy a new 5 speed bore kit and head (the 5 speed bore revs out much better than the 4 speed bore) - this will cost about Rs. 4000 in all
* Polish the new bore and get a street port (mild) done on the bore by a
reputed tuner (cost can vary between Rs. 500 and 4000 depending on the tuner)
* Upjet the carb to match the new bore
* Install a UNI or K&N air filter - this will be a conical sorta filter which attaches directly to the carb and will necessitate the removal of your existing airbox (about Rs. 2500)
* Resprocket to the 5 speed sprocket kit (I believe it is 16/34 as opposed to 16/36 for the four speed) (~Rs. 500 for a new kit)
* Try to get your hands on an expansion chamber from a reputed tuner (PM me for details) (costs vary between Rs. 1500 and 4000)
* Install a Pulsar disk brake kit for the front - this is probably the best upgrade one could make for an RX (~Rs. 4000)
* Get the CDI unit replaced - a reputed B'lore based gentleman makes some awesome CDI units (~Rs. 2500)
* Replace the entire gearbox to that of a 5 speed - expensive route and not much recommended - it is probably better to sell your 4 speed 135 and buy another 5 speed instead (~Rs. 5000)
Do all of these performance mods and your bike will easily better the Pulsar 180s and the like.
Other optional upgrades include replacing the carb with a flatslide carb, & installing performance reed valves/spacers. You may also want to get your bike kitted out with a 100/90 lighting kit.
airfoil is offline   Reply With Quote
Old 26th May 2006, 15:14   #8 (permalink)
Team-BHP Moderator
Technocrat's Avatar
I know a guy with whom two of my friends have got their RXs(RX 100 & RX 135) ported. One of them also owns an RD & has got all his stuff on his RD done by the same guy.
Both of them are extremely happy with his work. I have seen some good bikes at his garage.
But some how people\member of RD Dreams call him Fake. i guess one of the RDD members was duped by him. Well for RD i cant say much because the parts are always an issue. But I think RX should be just fine.
So if you are interested I will let you know his workshop details.
__________________
Everyone crashes. Some get back on. Some don't. Some can't
Accidents hurt - safety doesn't.
Old 26th May 2006, 15:28   #9 (permalink)
All those mods are exciting, but without 5 speed gear box, I can't really use all the performance enhancements. And looks like 5 speed gear box costs a bomb (~5000 Rs.) I feel, instead of spending 15-20K on modifications, I might as well buy a new one. (Yamaha sucks big time. They still are going to launch F250).
__________________
Old 26th May 2006, 16:55   #10 (permalink)
speedsatya's Avatar
details please .....
speedsatya is offline   Reply With Quote
Old 28th May 2006, 19:33   #11 (permalink)
mail4ajo's Avatar
How will changing the CDI unit help in making the performance better?
Old 28th May 2006, 23:28   #12 (permalink)
Viju's Avatar
Hey RX135,
The 5 speed gearbox costs almost 8000/- brand new. But Yamaha does sell what they call a 'conversion kit' in which you change a couple of gears and a few components - you can get that for around 2200/-. The ratios will not be exactly the same as a 5 speed box, but you still have 5 gears to play with and it will benefit performance.
It's not necessary that you change to a 5 speed cyl-piston kit to get good performance. Ported 4 speeds can deliver good initial acceleration. Go for the 5 speed kit if you are more interested in the top-end.
@Speedsatya : The Bangalore-based tuner that airfoil has mentioned is none other than Mr. R.D. Chinoy who runs RDDreams. He sells a digital CDI for the RX series for approx. 1950/-.
@mail4ajo : It lets your bike rev out much more, the engine runs cooler, emissions are lower and if you have a light wrist on the throttle, will improve F.E. drastically. I have used this CDI on my RX135 and it resulted in a F.E. of 58.2 kmpl 'cos I ride very carefully. Have posted the review in the customer-feedback section of RDD. I think getting this CDI should be the first step for anyone looking to increase performance of their RX's.
Hope this helps.
__________________
Cheers,
Viju Raj.
1999 Zen LX, 1984 RD350, 2005 RX135
Viju is offline   Reply With Quote
Old 29th May 2006, 10:16   #13 (permalink)
How much of performance boost do these mods give out? In terms of torque and in terms of BHP?
@Viju: I was not aware of conversion kits. I'll check if it is locally available.
__________________
Thread Tools
mods and performance mods for unicorn please give your views rider60 Motorbikes 117 6th September 2008 12:39
Performance Mods for Accent Gangsta Modifications & Accessories 26 24th June 2008 14:43
Performance Mods for Sierra reddy6980 Modifications & Accessories 6 23rd May 2008 09:39
performance mods chandan Modifications & Accessories 10 17th December 2005 14:48
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
