After Happywheel(HW), now it was my turn to secure the wheel cover. I spoke to HW thinking he found a single length cable lock for all this, but he was using 2 interlocked to get the length. I was looking for Single length cable with loop or lock. Things I wanted to do.
- Strengthen all vulnerabilities in the wheel cover
- Put up a cable with Lock to secure the Wheel cover.
- Make it visually discouraging by showing off the secure cable lock.
Found some in the US, on amazon and in China, shipping from US would be costly + the locks too were expensive, our chinese fellow was a manufacturer and bulk supplier, therefore my search continued. Luckily, a colleague was in China and I sent him the specs that I required. In first attempt he couldnt find the specified lock near where he was, I asked him to look again, he's back next week.
But they say " Dhoodne se tau bhagwaan bhi mil jaata hai", Vola, I found a distributor who had the required locks imported from UK and through him the retailer who were selling it online. These were Btwin cycle locks.
The hole in the wheel cover is 11mm (1.1cm) and the cable locks they had were of 6mm, 8mm and 13mm diameter(will not fit) and 100cm and 150cm in length, I required only around 80cm for a tight fit. Another dilemma, the 6mm and 8mm came in a set of 3 locks but did I have the choice!!, bought the set @Rs 325 inclusive of shipping.
Now the strengthening part, HW's zipper fly was propped open therefore I decided to plug it with Araldite, its got good strength, heat and water resistant.
Now once I removed the cover, I also found that the center cone is fixed with 4 bolts onto the cover itself with vertically embedded nuts.
Now we could also use the idea of drilling a hole at the end of the cone and using a simple locally available cycle lock,but i voted against it, the idea is to discourage the thief visually in attempting the theft and in this method, the thief would try to use force in pulling out the cover unaware of the visually hidden lock, which might cause damage to the cover and the nuts which are embedded into the cover might give away.
If you decide to use this method, use Araldite on the rims of the nut and plastic holder to strengthen the bond.
Once I was done with the method I preferred, these were the results.
The benefits of this were:
- I have hidden the lock part inside, between the Wheel cover and tyre(more secure, no easy access)
- Since the locking part is inside the wheel cover facing down, it prevents the lock assembly from water spalshes and water to get inside the assembly too (as its face down), if something gets inside it will drain immediately.
Zzzz, now I can sleep peacefully.
I had a very good experience for the purchased lock at lifemojo.com which I would like to mention here and provide the link if you want to buy it too.
- I had first placed a query for the length and diameter of the lock, they called back immediately providing the details and updated their website too.
- Once I placed the order, they sent an SMS confirmation and called within an hour to confirm the same and provided an estimated delivery date.
- Once the courier reached me, they called to confirm the same.
Very good customer service, here's the link
Buy Set 3 Locks Online - Locks - Cycling - Sports - Btwin - Decathlon | LifeMojo
