| On owning a car Help articles related to owning a car |
| | Thread Tools |
| | #1 (permalink) |
| Team-BHP Support ![]() | There are few things in life as enjoyable as a simple road trip, and successful drives have always been the result of careful planning. Team-BHP shows you how to plan your trip: Preparing the car: • Tune up your car by having it serviced and checked at least a week before the trip. This advance check-up will head off possible problems on the road and give you enough time to fix any errors caused by the mechanic such as loose fuses and filters. • Start your trip with a full tank of fuel and make it a habit to fill up at the ½ level rather than letting it run down to near empty. We also recommend buying fuel only from company-owned petrol stations in large towns. • Carry a can of engine oil and radiator coolant in the trunk. If you drive an older car it would be wise to stock up on extra hosepipes and fan belts, too. • Learn how to change your tyres. In addition to a puncture repair kit, you should bring an extra inner tube. Most highway tyre-repair shops do not have the facilities to repair tubeless tyres. • Duplicate keys will help if you lock yourself out of the car. Carry them in your wallet so they don’t get locked in the car, too. • Dont forget to carry a photocopy of the car's documentation i.e. registration book, tax receipts, insurance and so on. • Have fog-lights fitted on your car in case you encounter extreme weather conditions. They will also be useful if your headlights malfunction. • Carry the 24-hour roadside assistance number if you have this service. Other things to carry: • Cash because credit and ATM cards often don’t work in small towns and villages. Loose change can make toll payments fast and convenient. • Maps if you are driving on unfamiliar roads. Team-BHPians recommend WIAA, TTK, Eicher and Lonely Planet India maps. • A mobile phone with a roaming facility and don’t forget the charger. • A camera with extra film or memory. • A first aid kit and medicine for common ailments like carsickness, colds, headaches and upset stomachs. • If you wear prescription glasses, bring an extra pair with you. • Bring snacks and drinking water; these can be a boon in traffic jams. • If you are traveling with children, pack some baby food, finger food and juice. You should also think about bringing toys to keep them occupied. • CDs and cassettes. Music will provide entertainment and keep your mind alert on the long drive. Planning: • Plan out a tentative schedule. • Make hotel reservations well in advance if you are planning an overnight trip. • Research good restaurants along your route. • Get a good night’s sleep before your road trip. Being well rested will help you concentrate on the road. • Wear light, comfortable clothing for the trip. • Avoid night driving: security is an issue and bad road conditions are hard to see at night. • Start early to beat the city traffic. • Take a break every 90 minutes and use this time to get out of the car, stretch and have some refreshments. Related Article:
__________________ Samurai The only Super Car in my book -Bowler Wild Cat Last edited by GTO : 8th November 2006 at 01:50. |
| | #2 (permalink) | |
| BANNED Join Date: Nov 2005 Location: ??
| Quote:
| | #4 (permalink) |
| BHPian Join Date: Feb 2006 Location: Melbourne
| a tow rope also comes in real handy in tricky situations. dont listen to soft songs (opinions may vary) but its known to calm our nerves in turn making us lethargic. in hot weather do use A/C & keep the temperature towards chiller cause it keeps the driver alert (Volvo study showed this, so in their cars the driver's seat gets little extra chill from the air con) keep a day or two free at the end of the journey to settle back before starting ur work again also unscrew all the wheel screws & put them back. this is to prevent from not being able to change the tire in need, when we find that the nut has jammed. keep following this link because loads of more information is on the way |
| | #5 (permalink) |
| BHPian Join Date: Mar 2005 Location: Epinal,France
| One very cool trick, that i learnt from a truck driver on a remote road in Karnataka...... if you have a flat and while unscrewing the nuts from the wheel, the nut slips, pack some sand into the spanner (won't work if you have an open ended, or a regular ring spanner, but most repair kits come with the capped type ring spanner) , and then try and remove the nut....works like a charm............ ![]()
__________________ '78 911 Turbo(930) 3.3L, 300BHP,4 Gears and a whole lotta sideways fun! |
| | #8 (permalink) |
| BANNED | Hi, In addition to what all the others have said make a small tool kit of your own which should comprise of the following: 1> Screw driver + & - both. 2> A monkey spanner 3> A Plier 4> A roll of Electrical insulation tape 5> Monsoon Tape 6> M Seal Fast curing 7> Spare fuses min 2 of each(especially main fuse located in engine compartment) 8> Allen Key set(if you have any gadgets fitted that require the same) 9> small role of 18 guage electrical wire(approx 1 metre) 10> Spare head light bulbs. 11> Spare fanbelts & hosepipes The above shall keep you equipped for any emergency. Even if you do find assistance more often than not they will lack the basic tools and basic items like the above are difficult to find on the highway or small villages leaving you stranded. Viper Last edited by viper : 30th October 2006 at 10:12. |
| | #9 (permalink) |
| BHPian | Viper, add the knowledge to use them properly. A frined of mine who has been using various cars for 5 years never changed a tyre. Chat with your mechanic briefly what could be done on your car if you get stuck, what are the likely failures. Know to locate and identify the parts. (this is not for experts) I would also add a pair of jumper wires. They come in handy for the cars that can not be push started. A good flash light with the battery still alive.
__________________ _____________________ 2004 Fiat Petra 1.6, 100 16V 2008 Suzuki swift ZXi |
| | #10 (permalink) |
| Senior - BHPian | Excellant thread.. I have a question. Is there any site where we can download good quality road maps of South India? Atleast a one that shows the towns and distances between places. I would appreciate if anyone can send me a soft copy, if they have one. I propose to drive around south India in a few weeks from now.
__________________ *06 Alto LXi* *97 Zen LX* *03 HH Ambition* *RC Cars - HPI Baja 5B SS, Thunder Tiger SledgeHammer S50, ST-1 & Sparrowhawk XB* |
| | #11 (permalink) |
| BHPian | Do not keep anything loose in the floor like bottles, slippers (especially driver's) etc. In case of emergency braking it can get underneath the brake pedal and may hinder braking. This applies to day to day driving, but more relevant in high speed situations. regards tifosi.
__________________ Drive carefully. It's not only cars that can be recalled by their maker. |
| | #12 (permalink) | |
| Senior - BHPian Join Date: Nov 2004 Location: Bangalore / Madras
Infractions: 0/1 (4) | Quote:
I suggest you pick the Road Atlas and Distance Guides for the states of Tamil Nadu, Kerala, Andhra Pradesh & Karnataka - published by IMS. These have district-wise road maps which are the best I've seen so far. I've felt that IMS is better than TTK. The links below should tell you what the books look like and they are available at most major bookstores. Tamil Nadu http://www.indiamapstore.com/map-pro...s/IMS0023.html Kerala http://www.indiamapstore.com/map-pro...s/IMS0015.html Andhra Pradesh http://www.indiamapstore.com/map-pro...s/IMS0002.html Karnataka http://www.indiamapstore.com/map-pro...s/IMS0014.html An investment of around Rs. 200 that will do you good. Note to the Moderators: I have no association with IMS except as a user of their maps.
__________________ Feb 1997 Bajaj KB125 RTZ 48K km Mar 2003 Tata Indica V2 LSi 101K km Jan 2007 Tata Safari 3.0 DiCOR EX 4x4 78K km | |
| | #13 (permalink) |
| Senior - BHPian Join Date: Dec 2006 Location: Bangalore
| Dont you guys think that if you'r having a set of imported alloys , the standard issue spanner from the car tool kit might not work hence wouldnt it be advisable to carry the size wheel spanner ? as the roadside tyre puncture fix guy might not be having the same ? |
| | #14 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
__________________ “I am matter and you are matter, but it doesn’t matter.” – Captain Beefheart | |
| | #15 (permalink) |
| Senior - BHPian | A good site for online maps is Maptell - India Maps, India Free Map, India GIS, India GIS Data. Click on maps in the links and choose the state from the drop down box. You can zoom in and out of the map. Its pretty cool. Use IE for better viewing. (though u will still have to scroll up and down). Its far better than many of the free sites that i know of. |
| Thread Tools | |
Similar Threads | ||||
| My Great Indian Road Trip - Inputs solicited. | cpyder | Route / Travel Queries | 21 | 18th October 2009 10:48 |
| An Indian - On the road | aerohit | Street and Travel Experiences | 52 | 12th November 2008 10:26 |
| India Today Article on Indian Car scene in 2005 | Samurai | The Indian Car Scene | 13 | 1st July 2008 11:14 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
