Mod Note : Please continue the discussion in this new thread. Thanks
I am planning a road trip to Puri and then possibly to Konark and then while coming back probably Bhubaneshwar too and around in the middle of November 2008.Actually the dates would be 13 Nov ( a holiday !) and back by 16th or 17th !
I have read the details on other travelogues especially Puranjoy's Kolkata to Puri and the wonderful write up by AK Roy (Bangalore-Kolkata which he did in 2006).
I need all guidance especially how the roads are after the monsoon and floods in Orissa recently.The BBSR-Puri road was washed away at two places this year.It would be of great help if HV Kumar comes on this thread and give his valuable opinion.Any inputs from any member would be vitally important for me.
The Kona expressway is in shambles after the monsoon but I have seen repairing work going on.Till Kolaghat the GQ is great,but the Kolaghat bridge is a HUGE headache,it is now reported that the bridge is almost on the verge of collapse.The traffic jam there is a pain in the a***.I am especially worried about two stretches,one is
50 km stretch between Balasore and Bhadrak ( it was incomplete in mid march 2008 when Puranjoy had made his trip,what the heck,it was worse when I drove to Puri in an Ambassador diesel even in June 2004 !) and the other is the
stretch betwwen BBSR and Puri.
Please guys any help would make me most grateful.I would keep updating this thread as we plan and also I promise to put up pictures and write a travelogue when I am back.
Tirthankar who drove Bangalore-Cal recently found the Bhadrak-Baleshwar stretch very bad, and has advised caution - and ideally, the stretch should be done by daytime. I expect that by the time you travel, there should be some repairs done and you should have a better drive. Allow for 1-2 hours extra to drive from Cal to BBSR.
A friend drove from BBSR-Puri a week before the Jagannnath Yatra and he reported decent roads. So hopefully, you should have problems in the BBSR-Puri-Konarak-BBSR circuit.
Well, Tirtha gave the first hand info which is the latest. I am sure some repair work will be done by that time. You can take the trip.
My only suggession will be to start at 4AM so that by the time you hit Jaleshwar it will be early morning. With lesser traffic you can cover the bad section and reach Puri by 4PM (Had the GQ been complete you would have had lunch at Puri comfortably).
Abhi
Originally Posted by akroy
(Post 1022449)
Abhi |
The two persons I wanted most to reply on this thread has replied,isn't that wonderful?
Thanks AKR for the info.Do you have the link to Tirthankar's thread?I had read the Kolkata-Hyd he made earlier,or is it the same one you are talking about? When I drove the Amby in 2004 to Puri,I didn't have any bit of information on the roads,but there were plenty of roadworks going on for the GQ.This time I am informed,and probably apprehensive more for that reason!
Originally Posted by hvkumar
(Post 1022009)
Tirthankar who drove Bangalore-Cal recently found the Bhadrak-Baleshwar stretch very bad, and has advised caution - and ideally, the stretch should be done by daytime. I expect that by the time you travel, there should be some repairs done and you should have a better drive. Allow for 1-2 hours extra to drive from Cal to BBSR. |
Thanks Sir,for both your presence and advice.I plan to start quite early (don't know though that whether we will manage a 4 am start!) and cover as much distance possible in the morning.The only thing that worries me in Bengal is the Kolaghat bridge.Only a month back me and my family had to turn back after being stuck at a traffic jam at the bridge for almost 2 hours.We had earlier planned to have lunch at Sher-e-Punjab beyond the bridge,but mothballed the plan and had late lunch at Reliance A1 plaza! :Frustrati
(Post 1022009)
So hopefully, you should have problems in the BBSR-Puri-Konarak-BBSR circuit. |
:Shockked:
btirthankar would be able to give the latest news on the condition of this road. I have travelled quite extensively on this stretch and sometimes the roads have been excellent and sometimes horrible, specially after the floods every year. One thing I would like to mention is since you are travelling for the first time is not to miss the Kharagpur bypass while going as it will save a lot of time. And also the road through Kharagpur is quite bad. To make sure that you dont miss the bypass you have to take the second left under the bridge at the Kharagpur turn. Hope that helps...
Originally Posted by BlackPearl
(Post 1023082)
One thing I would like to mention is since you are travelling for the first time is not to miss the Kharagpur bypass while going as it will save a lot of time. And also the road through Kharagpur is quite bad. To make sure that you dont miss the bypass you have to take the second left under the bridge at the Kharagpur turn. Hope that helps... |
After the completion of the GQ it is now extra difficult to find your way for
getting inside Kharagpur town. Just keep driving straight in the direction of Belda without bothering the flyover and you won't enter KGP. There is a nice morning tea joint called Roy's dhaba (no way connected to me!!) on the left just after the KGP exit.
Keep an extra couple of hours for Kolaghat. You might need only half an hour though, but be prepared for the worst.
The Puri-Konarak marine drive road was a silky smooth newly paved one a couple of years ago. Wonder how it is now. It' a lovely drive - I am sure you have driven there.
The roads inside Puri might be a bit confusing but there is a trick. If you get lost in Puri you will soon find yourself on Chakratirtha Road. I did exactly that to find my way to our guesthouse. :D
Knowing Joy when you are in Puri helps. If you want I can give you his number.
If the road condition feedback upsets you, go to Benares. It's literally a weekend drive now.
Thanks BP,Sudipto da and AKR for all the advice and suggestions.Will keep my eyes open for the KGP bypass.
@AKR: Will surely go through the links that you have provided.
whats the status of this trip? @ultimatechamp - did you go to Puri?
(Post 1060361)
whats the status of this trip? @ultimatechamp - did you go to Puri? |
Dont think so, daktar babu looks pretty engaged with baganbari meet :)
Abhi
i have done Kolkata - Puri - Konark - Kolkata last weekend
Road conditions
Kolkata - Kharagpur - good
Kharagpur - Jaleshwar - Very Good
Jaleshwar - Balasore - Few diversion, though road condition is good.
Balasore - Next 60Kms (10~15Kms ahead of Bhadrak) - Horrid Roads/lots of diversions (Low GC car should be avoided)
Good Road Starts upto Bhubneshwar.
good Petrol Bunk - One HP Bunk 10Kms ahead of Puri
and one BP Petrol Pump inside Balasore.
Petrol is Rs 5~6 cheaper in Orissa wrt WB.
And you would want to have a look at this
thread before you begin
Forgot to add, Road from BBSR to Puri is in Good condition.
At one place about 20Kms from Puri there is a makeshift bridge, but that is no problem. (Only one vehicle can cross the bridge at a time)
Road to Konark from pipli is full of spead breakers. (but beauty of surrounding is amazing)
(Post 1060361)
No Sir,I didn't on that weekend because of workload and other commitments.Have planned for mid-December again.
(Post 1060367)
Abhi |
:D
You are right AKR. Gawdd,I think I will think twice before arranging another before next winter.
@thebagchi : Thanks for the excellent update on current road conditions from Kolkata to Puri. I was aghast to read that in flipin Orissa,they asked for a Rs.800/ road tax. I have already said that in gmail,that am in with you against this atrocity. It has to be stopped at any cost.I spoke to a BBSR-Kolkata based Real estate promoter,who frequents between this stretch in his Dzire,but he was completely unaware of any such thing.
Is there any updates on road conditions to Puri-BBSR from Kolkata?
thebagchi,senindra ,both of you guys had gone to Konark/Gopalpur recently,is there any news update for travelling to Puri coming weekend (the 23rd-26th Jan)?
Any inputs from anybody would be so much appreciated.please:
Originally Posted by ultimatechamp
(Post 1136235)
Any inputs from anybody would be so much appreciated.please: |
Well road conditions should not have deteriorated in 2-3 odd weeks I would guess. It was good back then. Yesterday 5 of my bulleteer friends rode down the same way towards Ooty and they did not complain of bad roads either.
