Originally Posted by gemi_kk => Monocoque SUV's are basically SUV's and they are lighter, so this makes them more easy to control in some exceptional situations. |
Agree. Monocoques by design are more stable, body roll is much lesser since the entire chassis is a rigid, single unit.
Originally Posted by gemi_kk => Lighter body implies better life of tires, suspension and other wear and tear parts. (Might not be completely true if the quality of spares is not good.) |
Agree. And as you say, depends upon the quality of spares as well as original parts.
Originally Posted by gemi_kk => The body is light, so the engine required would be smaller so more FE. |
Requirement is low, agree. But one could still have a big engine for insane power-to-weight figures! Kidding
Originally Posted by gemi_kk => The body is light, so the engine would be small so should be easy for repairs and other tasks. |
As mentioned above, depends on the engine complexity. Which in turns increases the smaller the engine gets.
Originally Posted by gemi_kk => More space inside cabin and in bonnet  so more DIY could be done. |
If you meant for two cars with same external dimensions but one being mono and other being BoF, I guess that'd be true. Not sure.
Originally Posted by gemi_kk => Better visibility at night as the driver would be sitting a bit above. |
Again, depends on design. All SUVs are basically built to offer a higher seating position. The Skoda Yeti is touted as an SUV, yet the Tata Nano is taller than it at its highest point (had once seen a nose-to-tail pic in one of the threads on TBHP itself).
Originally Posted by gemi_kk => Expensive spares as it is considered as an SUV. |
Brand-dependant. Are you comparing mono vs BoF in this regard? If yes, I don't see any difference, since for a given manufacturer, mono will get the same/similar engine as the Body-on-Frame, so same/similarly priced spares. If you weren't comparing that way, well, Tata spares will always be cheaper than Range Rover. And with platform- and part-sharing nowadays, one may find many similar components in the sedan and SUV offerings of the same manufacturer.
Originally Posted by gemi_kk => Does monocoque chasis will be able to hold tight in case of an accident? (read low weight.) |
Did you mean emergency maneuvering or crash safety? Either way, I'd say mono is better than BoF.
Originally Posted by gemi_kk => Braking would be weak because of vehicle is big and not aerodynamic. so more load on pads and other areas. |
Didn't quite catch you. How would aerodynamics affect braking? In fact, weaker aero would mean greater air resistance, in turn helping the vehicle to stop better. But that's in theory. Due to the relatively soft tune of SUV suspension systems, there's a lot of wallowing and pitching involved. But here I'd say monocoques get my vote. More stable by design.
Originally Posted by gemi_kk => Emergency maneuvers. again, i am not sure. |
Monocoque all the way.
PS: As I said earlier, it all depends on customer requirements. You have mostly mentioned high speed runs in your considerations. That's not what Body-on-Frames are built for. They're for low-speed, high-fun, go-anywhere capabilities.
Its the capabilities that differ, so a disadvantage for Monocoques is and advantage for BoF's, and vice versa. I suggest the thread title should rather be just "Monocoque vs Body-on-Frame" or something similar.
