Thread Tools
Old 5th April 2006, 11:57   #1 (permalink)
tsk1979's Avatar
Default AC query, regarding on off
Most air conditioned units and refrigerators have this warning. Wait for 3 minutes before restarting after a switch off. Infact newer samsung ACs when switched on do not start the compressor for 3 minutes after starting. There are also stabilizers which switch on after a delay.
Now come to the car scene. you will find your AC switching off and on frequently due to automatic climate control thermostat etc., If such frequent compressor on and off can damage the home AC, cant it damage the car AC or shorten the life? Or are car AC compressors made differently so that this does not impact them so much?
__________________
Reclaiming.....!
Old 5th April 2006, 12:47   #2 (permalink)
revharder's Avatar
in cars if you are manually doing that ON-OFF to the compressor than you are surely damaging the unit.
the machine itself diagnoses when the pre-set temp has reached it will cut off the compressor and will restart it on its own sensing the increase in cabin temperature.
same goes for the home ACs etc.
as soon as the pre-set temp is reahced compressor get cut-off. and gets restarted when any increase in temperature is noticed.
and that 3 minutes delay-start is used to protect the compressor from the fluctuations in electricity. say if the electricity is continuously fluctuating then that 3 minute delay will give you enough time to switch your unit OFF.
moreover, say, if units gets started and just after it got started, electricity goes OFF or fluctuates highly, then the unit may get damaged.
so that 3 min delay is used as precautionary measure to let the electricity supply stabilize!
revharder is offline   Reply With Quote
Old 8th April 2006, 01:10   #3 (permalink)
turbo_c's Avatar
I think it has something to do with the fact that your home AC's compressor runs on electricty while your car's AC compressor is driven by the engine.
Your home AC's compressor is basically a large motor. Motors draw huge amounts of current when they are starting (upto 10 times the running current). That's why you may notice that the bulbs in your house dim slightly for a fraction of a second when the compressor starts up. The 3 minutes waiting is probably to give the compressor's motor windings time to cool off, since it might get quite hot with that huge starting current.
In your car, the worst thing that the AC can do by switching on / off often is increase the wear on the belt & clutch mechanism of the compressor but even with this, the compressor in your car would probably outlive the car itself !
- T u r b o C -
turbo_c is offline   Reply With Quote
Old 15th April 2006, 23:29   #4 (permalink)
though being a newbie here, what i have known is that a compressor does the same thing as its name suggests. it comresses the gas and throws it into condenser with a high pressure, when a compressor is switched off the chain of compression and gas circulation stops and the gas(pressurised) in the condensor or pipes starts moving backwards to normalise the pressure in the whole unit. If u start the compressor b4 it gets normalize then it is surely gonna put extra load on the unit.
i guess it explains the 3 minute delay.
manik058 is offline   Reply With Quote
Thread Tools
Innova Purchase Query + Query on Price Increase by Toyota SanMan SUVs, MUVs & 4x4s 7 30th April 2008 13:13
JBL 75.4 query panky12345 Ask the Gurus 25 5th September 2007 11:06
Speaker query cooldude1988765 Gadgets, Computers & Software 0 24th July 2007 01:28
KickPanel Query jinu_joseph Ask the Gurus 15 3rd August 2006 00:02
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
