Thread Tools
Old 17th April 2004, 19:40   #1 (permalink)
Unhappy
Do MPFI cars have carbs, if not why ? How does the sys work in MPFI cars.
__________________
What a Mind can Conceive and Believe, it can Achieve.
kakx is offline   Reply With Quote
Old 17th April 2004, 19:51   #2 (permalink)
Shan2nu's Avatar
No, carbs and MPFi's are totally different engines.
I ain't no techie but from what i've heard, MPF-i engines control the fuel supply to the enigne depending on the amount of air that has been sucked in. Correct me if i'm wrong.
Does the same happen in Carb engines? Or do those enigines let out designated amounts of fuel irrespective of available air.
Hey Rehaan......i guess it's time for one of those illustrated explainations man. Just love reading them.
Rehaan, from now on will be reffered to as "Mr. Howstuffworks".
Regards...
Shan2nu
__________________
VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE
Old 18th April 2004, 13:23   #3 (permalink)
Team-BHP Moderator
Rehaan's Avatar
By popular demand>
here is a SUPER SIMPLIFIED diagram.
will edit this post and write about it in a bit.....
plz let me know if u see any mistakes!
To put it simply
The carb has no exact control of how much fuel goes in, it all depends on how much fuel the air passing through the carb atomises and takes with it. Hence it is tough to mantain the ideal air/fuel mix of 14.7 : 1
The fuel injection has injectors which are basically like sprays that can spray in an exact amount of fuel into the intake, and using the information collected by the sensors the ECU calculates how much fuel should be sprayed in, hence keeping an almost perfect air/fuel mix.
cya
Rehaan
__________________
The memory of you will ride by our side forever.
Old 18th April 2004, 15:14   #4 (permalink)
Shan2nu's Avatar
Hey about the air/fuel ratio of 14.7 :1......does that 14.7 represent the atmospheric pressure?
Regards...
Shan2nu
__________________
Old 18th April 2004, 15:32   #5 (permalink)
Team-BHP Moderator
Rehaan's Avatar
interesting.....but nope dont think so.....its the ratio of air to fuel, (in terms of volume)
R
__________________
Old 21st April 2004, 12:42   #6 (permalink)
Rehaan,
Teacher Teacher, THank you. You are good at it.
Regds
Praful
__________________
Old 21st April 2004, 18:53   #7 (permalink)
wow rehan that was a good explaination
toyota is offline   Reply With Quote
Old 24th April 2004, 08:08   #8 (permalink)
Team-BHP Moderator
Rehaan's Avatar
Thnx,
glad u guys liked it...had fun making em (and an excuse to procrastinate)
cya
R
__________________
Old 24th April 2004, 23:20   #9 (permalink)
hi rehan
good explanation.u made it look 2 simple. congrats.
but are you sure the 14. 7 :1 the ratio of to fuel is as per volume.
i think it is as per the weight.
ashish112 is offline   Reply With Quote
Old 25th April 2004, 00:54   #10 (permalink)
Team-BHP Moderator
Rehaan's Avatar
Originally Posted by [b
Quote[/b] (ashish112 @ April 24 2004,21:50)]but are you sure the 14. 7 :1 the ratio of to fuel is as per volume.
Hey man,
thats right..... i initially wrote molecular volume..but then edited it out to keep it simple.....but i guess the word i should have used was "mass" ...right?
thnx
Rehaan
__________________
Thread Tools
MPFI or Carb? raajks Technical Stuff 2 18th December 2007 19:43
MPFI or CARB. for CNG breezydrive Technical Stuff 5 15th November 2007 22:06
Carb/MPFI - Which is having longer engine life ? mithun Technical Stuff 47 10th October 2007 01:58
99'ZEN carb to ZEN mpfi.... Balram Modifications & Accessories 17 10th December 2006 08:04
carb or mpfi? which gives more power? iceman91 Technical Stuff 18 5th April 2005 10:48
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
