Thread Tools
Old 17th May 2007, 01:39   #1 (permalink)
kaushik_s's Avatar
Default Braking- of a Zen
Hi All,
My ride is a 99 model carb Zen and I feel the brakes are not that sharp as I've seen on a Santro(new ones) or Palio..I mean to say it doesn't gives a jolt even if braked hard and the braking seems to be somewhat not very quick(but it does stop in time)..But I'm used to it now..
Now what happened is that I've read about the Left foot braking thing here at TBHP and I thought let me just see what happens if I try it.. Now I found an open space and there was no other car in the vicinity I tried my left foot.. And to my utter surprise braking was very very sharp and it felt similar to that of the new cars..It felt like the wheels got locked and felt the jolt of a sudden stop... So after that I tried my normal method of braking, right footed one.. but as soon as I leave the throttle and pressed the brake everything seem to be as it was before, i.e. the braking was not very sharp and I didn't felt the jolt of sudden stopping and the car was slowing down normally..
What can be the reason of this ?? Is there any power assist short of thing to the brakes while throttle is being pressed which increases the braking efficiency ?? Or is there any problem with my car itself(I'm planning to check this with one of my friends Zen(similar model))
Kaushik
kaushik_s is offline   Reply With Quote
Old 17th May 2007, 02:16   #2 (permalink)
v1p3r's Avatar
That's because your left foot is not accustomed to braking. You will be putting a lot more pressure on the pedal with your left foot, than with your right foot, even though you may think otherwise.
__________________
Peace is a lie, there is only passion.
Old 17th May 2007, 13:01   #3 (permalink)
kaushik_s's Avatar
Viper, I guess that's not the case.. I tried doing very hard braking with my right foot also and car was stopping gradually only.. not like a jolt.. Actually I also thought the same thing at first.. But it was totally different.. may be is because of the throttle, well I don't know.. I wish I could show it to you people..
Kaushik
Old 17th May 2007, 14:19   #4 (permalink)
ajitkommini's Avatar
Kaushik, what Viper is saying makes sense. I've tried this too. I found that my left foot isnt used to making gradual / fine movements as much as my right foot. So when you brake with the left foot, it's more like an "on / off" thing rather than a gradual increase in braking pressure. This is why there is a perceived difference in braking. I dont think it has anything to do with acceleration and all.
ajitkommini is online now   Reply With Quote
Old 17th May 2007, 14:30   #5 (permalink)
Kaushik
it has nothing to do with car, just the fact that your right foot is accustomed to regular braking.
our left foot is accostomed to pressing clutch pedal hard but lifting off in a gradual slow manner, while right foot get used to controlled pushing & easing off by the repeated movements, & over the years it becomes habit.
while braking with right foot we use, jointly more of anlke moment force+some push from leg, while using left foot we use more force of leg than use of ankle joint, thats why even if you push hard with right foot you will impart less force on pedal.(coz we tune our right foot over the years of driving to use ankle joint while pushing)
__________________
Arun
arunforu1 is offline   Reply With Quote
Old 17th May 2007, 17:08   #6 (permalink)
kaushik_s's Avatar
hmmmm .. so it may be only some short of mental issue more then mechanical issue ;-) .. Well then I'll try this thing again with keeping these things in mind.. But yeah may it's all in the mind only..
Thread Tools
Hard braking in CVT!!! funkydevil Technical Stuff 30 5th February 2008 15:50
scorpio braking issue zenopio Technical Stuff 7 3rd June 2007 21:01
Left Foot Braking: Yes/No..? MaserQ Street and Travel Experiences 2 19th March 2007 05:16
Engine Braking a_micky Technical Stuff 1 26th February 2007 23:03
Vibrations under hard braking RJK Technical Stuff 15 21st July 2005 13:42
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
