Old 6th October 2007, 20:42   #1
dkamath's Avatar
Thanked: 162 Times
Electronic Ignition for Maruti 800 carb model - Need Advise
Hi guys, came across an ad some time back, in the mags, about a Co. that claims to have developed an electronic ignition for carburetted Maruti 800 (the Co. name goes by 'Eureka' or so). The system, they say, would enhance the performance of the car, also providing fail-safe service.
My question: Do any of you have an idea on this? Please comment.
dkamath is offline
Old 8th October 2007, 17:11   #2
Thanked: 268 Times
Will you please be more specific ?
mithun is offline
Old 8th October 2007, 19:43   #3
Thanked: 311 Times
Maybe you are talking about a contact-less distributor? Surely not a full fledged ECU?
anupmathur is offline
Old 8th October 2007, 21:49   #4
Thanked: 57 Times
hey , the ignition system basically uses the same coil and other stuff...only the distributor is changed from the old mechanical to a contact less system which has magnetic pick up points, so there is no miss fires and constant adjusting is not required... so good and consistent performance..... it's been in in the market since early 90-91 I believe..have driven 800 with this system and it's quit good.
and hey it does have an CDI on CB..
dinar is offline
Old 9th October 2007, 09:59   #5
dkamath's Avatar
Thanked: 162 Times
thanks all, for the replies. and sorry for the delay in reverting.
yes dinar, that's exactly the one i'm interested in knowing more about.
if you got more info about where i can go take a look, please let me know.
thanks in advance
dkamath is offline
Old 11th October 2007, 08:28   #6
rdkarthik's Avatar
Thanked: 13 Times
I installed one on a friends car, it works great. Its runing for the past 2.5 years without needing a look. Engine cranks easily, runs smoother ,better throttle response....
rdkarthik is offline
Old 11th October 2007, 08:31   #7
rdkarthik's Avatar
Thanked: 13 Times
I guess the 'eureka' one in question comes with its own set of ignition coils, distributor and pickup mechanism.
Old 11th October 2007, 08:38   #8
Thanked: 311 Times
I think they used to claim it is fitted on top of existing distributor and it would be possible to revert to original condition within minutes.
I could be wrong here.
Old 11th October 2007, 09:02   #9
rkbharat's Avatar
Thanked: 724 Times
Do we have to remove the existing Carburetor, and put in a new system. What is the estimated cost involved.
I have M800 recently revived, Just 6600KM driven. I am very much interested to know more about it.
rkbharat is offline
Old 19th October 2007, 22:15   #10
dkamath's Avatar
Thanked: 162 Times
that makes it two of us now
hi rdkarthik, any more info from your end on where you sourced it from, will be of help. can you please pass on the contact details of the dealer/stockist, if you still got it? thanks in advance
dkamath is offline
Old 21st October 2007, 13:56   #11
rdkarthik's Avatar
Thanked: 13 Times
The one i has was given to me by a friend, let me see if i can get more info on where you can source one.
Your carb remains as it is. Its just the distributor and coils that are to be replaced.
Old 21st October 2007, 17:23   #12
Thanked: 57 Times
guys sorry for not replying for so long, my friend had new distributor , new cables and CDI changed nothing else.but now it comes with new coils... I think you have to order it directly from the company...my friend had done the same...
dinar is offline
Old 25th October 2007, 22:54   #13
dkamath's Avatar
Thanked: 162 Times
thanks to both of you, and sorry for not taking a look into this thread.
rdkarthik, if its a "Eureka" kit that your friend's got, then i must be having the contact info too. else, please pass it on sometime.
dkamath is offline
Old 26th October 2007, 11:50   #14
Ravi Yadav's Avatar
Thanked: 12 Times
Now three of us.I would also go for it.
Ravi Yadav is offline
Old 27th October 2007, 19:20   #15
Thanked: 9,212 Times
The Eureka kit is made by Autoescorts in Mumbai. The contact person is a guy named Kiran Bhide. They make oints replacement kits for Bullet as wel. I tried contacting him through email but the email id is not working.
If anyone has contact info of Autoescorts please let me know.
Sankar is offline
