Hi Friends,
Offlate i'm experiencing a weird noise from the car, when I press the clutch the noise comes down, now it has developed even when i'm running the car in any gear, my mechanic initially suspected it's a pressure plate(clutch) problem, now he is suggessting about checking the bearings in the Gearbox.
My query is now that I'm willing to find the problem, whether it's clutch/gearbox issue, i wanted to try the Zen's gearbox for better shifting & ratios... Please can you suggest your opnions on it? Can we use the Zen's GB on an Esteem what are the mods we require to do?
Originally Posted by bruce
(Post 595473)
Offlate i'm experiencing a weird noise from the car, when I press the clutch the noise comes down, now it has developed even when i'm running the car in any gear, my mechanic initially suspected it's a pressure plate(clutch) problem, now he is suggessting about checking the bearings in the Gearbox. |
I have the same issue, as if a whirling fan inside the gearbox, with my OHC and I am told that I should suspect the ISB (Input Shaft Bearing).
I had a similar noise in my zen and had to get the input shaft repaired for this noise to go away
Thanks, yes my mechanic tells me the same, I'm in a dilemma to goback to the Esteem's GB or covert to Zen's GB to get that Initial accelaration.
