Thread Tools
Old 14th April 2008, 13:53   #1 (permalink)
PatienceWins's Avatar
Default Vibration of Accelerator and Steering
I feel vibrations in accelerator and steering in my Getz once the rpm crosses 2000 rpm. What could be the reason?
I have done wheel balacing, rotation and allignment of the wheels. So I think wheels are not the culprit.
The vehicle is 11 months old and has just done 7500 kms. All the services were done on time.
PatienceWins is offline   Reply With Quote
Old 14th April 2008, 14:41   #2 (permalink)
iraghava's Avatar
Does it happen when you accelerate or when you brake?
__________________
There is a very fine line between "Hobby" and "Mental Illness".
Old 14th April 2008, 23:16   #3 (permalink)
It happens only while accelerating.
Its not bad, but annoying at high speeds.
The only modification I have done is K&N stock replacement filter.
Old 15th April 2008, 00:02   #4 (permalink)
flipsyde's Avatar
get your engine mounts checked. shouldn't be a problem in a new car .......... but get it checked anyway.
__________________
An architect's most useful tools are an eraser at the drafting board, and a wrecking bar at the site - Frank Lloyd Wright
flipsyde is offline   Reply With Quote
Old 15th April 2008, 00:05   #5 (permalink)
Thanks flipsyde. Will get it checked.
Old 15th April 2008, 00:05   #6 (permalink)
Default Vibrations In Getz
Hi, i feel it could be either from worn or faulty engine mounts, and in some cases it has been observed that the belt tension is allso a cause for this, just try getting it loose a little.
alankarmotor is offline   Reply With Quote
Old 15th April 2008, 10:19   #7 (permalink)
Thats a good point Alankar. Thanks
I remember the technician applying some grease on the belt when there was squeaking noise from the belt of my Santro.
Thread Tools
Santro: Return spring for Accelerator and brake pedal? ajith Modifications & Accessories 18 2nd April 2008 20:20
Vibration on accelerator pedal while using the horn kaushik_s Technical Stuff 2 8th September 2007 13:59
noise and vibration akshay1234 Technical Stuff 7 5th July 2007 20:10
Steering wheel vibration lohithrao Technical Stuff 6 25th April 2007 10:48
Vibration in Accent CRDI badri Technical Stuff 4 4th January 2007 18:41
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
