Re: Coolant liquid leakage Quote:
Originally Posted by joe1980 It is a Golf 6. It has seen in 5 years roughly 100000 km! I got an expensive quote to get this fixed! Well I have no choice now. Got to fix it! I'm planning to change the water pump, drive belt, guide roller in one package. |
Change whatever parts are required to be changed. Or you will be spending more than necessary. I assume you are someplace in Europe and labour is expensive. Quote:
Should I ask them for the radiator, hoses and engine block as well? I'm not sure if they did this, but that would cost me additional money if I would do that.
They will charge you for extra labour but it will ensure at least you don't have another potential point of failure lurking somewhere else under the bonnet. Quote:
Now tell me one thing, should I first replace the WP as per the mechanic, drive the car for a couple of days and observe it for further leakages? Should the problem not go away, I go back and check for the radiator, hoses and so on? Is this a valid approach? The problem for me is that the more I ask them now, the more they are going to charge and the more time it would take for me to get my car back.
Yes you can postpone further checks if you want to. But my sincere advice is to get the whole cooling system checked to prevent surprises whilst on the hwy and long distance journeys. Checking a system for leaks isn't difficult if they have the right tools.
If you really don't want to spend extra on labour, get the WP replaced & drive the car for a 1-2 days & check coolant levels. You'll immediately notice a drop in the overflow/pressure reservoir if there's a leak. Go back for further checks if it is necessary. |
