Thread Tools
Old 5th May 2005, 22:47   #1 (permalink)
Stratos's Avatar
Lightbulb Hella develops LED HeadLamps
Luminous flux equal to xenon
Hella is developing complete headlamps using LED technology as a study provides information about possible series application from 2008.
The light and electronics specialist Hella, in cooperation with Volkswagen, has developed an LED headlamp which achieves low beam, high beam, direction indicator and daytime running light functions using cutting-edge LED technology only. The LED headlamp is a study using the VW Golf 5 as an example. It is to provide information about the performance ability of such systems and also offers the possibility of experiencing technical challenges in operation in the vehicle. A series solution is expected for the year 2008.
For the lighting functions, Hella uses both standard LEDs and LED assemblies especially designed for automotive applications. The light is directed onto the road with the aid of different optical systems. The most striking part of the headlamp is formed by seven pentagonal plastic lenses arranged in a honeycomb pattern. There is a shovel-shaped free-form reflector positioned next to these which produces the low beam together with four segments of the honeycomb. For the high beam, the other three segments of the honeycomb are also used. During the day, all seven segments of the honeycomb form the daytime running light. There are six standard LEDs arranged in a row beneath the shovel-shaped free-form reflector for the direction indicator function.
Light emitting diodes as a light source open up completely new possibilities for headlamp shapes and arrangements. This is made possible by the modular design as well as the large selection of different optical elements.
Source: Supercars.net
__________________
Patience is the Key
Stratos is offline   Reply With Quote
Old 5th May 2005, 23:01   #2 (permalink)
lamborghini's Avatar
Cool.
Wonder if they will come to India as an after market option for cars.
__________________
¢нєєяѕ
ℓαмвσ
lamborghinirules@gmail.com
lamborghini is offline   Reply With Quote
Old 5th May 2005, 23:44   #3 (permalink)
Team-BHP Moderator
Mpower's Avatar
LED headlamps are already in production in the Audi A8...only on the W12 version with the big-mouth grille
__________________
The difference between the men and the boys....................is the speed of their toys.
Old 6th May 2005, 00:24   #4 (permalink)
nitrous's Avatar
What are the advantages of LED headlamps over conventional and xenon lamps?? can anyone give a comparitive study?
__________________
The Road less travelled, is less travelled for a reason
Old 6th May 2005, 08:08   #5 (permalink)
Stratos's Avatar
LED's have life expectancies of up to 100'000 hours, FAR exceeding any other currently popular forms of bulbs etc for automotive application. if i remember correctly however, the current breed of LED's are not more efficient, just far more versatile. they can emmit different colours of light from one single LED', are VERY resistent to shock(no filament/element), produce virtually no heat and can be arranged in pretty much any configuration.
Source: supercars.net
__________________
Patience is the Key
Old 6th May 2005, 15:52   #6 (permalink)
DRC
DRC's Avatar
Theya also take a lot less current, as there is minimum heat generated.
Since, they do not use bulb-reflector mechanism, a lens can be integrated into the LED itself..
The source of light is very small, (unlike half an inch of filament) so there may be more uniform light distribution..
source, engineering books, datasheets of LEDs, a part of my job..
__________________
_____________________
Stand on your head, upside down..
The world does not look any different, but you sure will look different!
DRC is offline   Reply With Quote
Old 10th May 2005, 07:37   #7 (permalink)
Edmund's Avatar
I dont know if you guys have noticed this one, The intercity locomotives like the Deccan Queen which runs between Pune and Bombay have LED's as secondary lights in the front!!!!
I'm guessing they are just experimental.......but a tiny step for a giant leap coming up in the future!!!!
__________________
Zeropointeight for me to keep and miles to go before I sleep............
Edmund is offline   Reply With Quote
Old 10th May 2005, 12:06   #8 (permalink)
speedsatya's Avatar
[quote=Edmund]I dont know if you guys have noticed this one, The intercity locomotives like the Deccan Queen which runs between Pune and Bombay have LED's as secondary lights in the front!!!!
QUOTE]
hey Edmund,
are you sure about this????
speedsatya is offline   Reply With Quote
Old 11th May 2005, 00:15   #9 (permalink)
Edmund's Avatar
One hundred Percent sure...........took me by surprise too!!!
But they are not perfected to actually generate a great beam.........its still developmental im guessing.........
__________________
Thread Tools
LED lighting in cars gigy Technical Stuff 31 18th August 2008 15:48
BMW develops automatic parking system nishantgandhi Technical Stuff 7 30th January 2008 12:38
HELLA dealer / availability in Mumbai pls gbpscars Modifications & Accessories 6 21st August 2007 17:25
Hella Auxillary Xenon Lamps Ajay Narayan Modifications & Accessories 2 17th December 2005 19:40
Led Zeppelin v1p3r Shifting gears 6 27th June 2005 23:02
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
