Team-BHP - Basic 4X4 Terms
-   4x4 Technical (https://www.team-bhp.com/forum/4x4-technical/)
-   -   Basic 4X4 Terms (https://www.team-bhp.com/forum/4x4-technical/100309-basic-4x4-terms-4.html)
Jeepster,
Thanks a lot for those fine pictures and explanation on GC of 540.
wheel offset
the offset of the rim/alloy is the amount of distance from center of rim/alloy.
in other words how much the rim/alloy goes in or out of the body.:D
see the picture below.
a + offset rim will reduce the standard track length of the jeep gypsy. (mostly sock rims are + offset ones in almost all vehicles)
& a - offset rim will increase the track length.
but the increased track can also result in the suspension (in IFS) & bearings (in rigid & IFS) issues.
some times the increased track limits the articulation too.
example. armada/bolero rear wheel arch. (even thar ):Frustrati
in stock form the tyre goes in the body tub under heavy articulation (pic 1, 2) , but when the track increases the tyre directly touches the wheel arch thus limiting articulation (pic 3).
source: http://www.team-bhp.com/forum/4x4-te...ml#post2378871
