Originally Posted by fazalaliadil Jaskirat, Plastic would not work at all, it seems to be made of teflon, am I right? Still it would not break unless there there was an obstruction that opposed the rotation to the point it broke. Behram Sir, kindly enlighten on the material and reason. Regards, |
(Post 2959809)
Jaskirat, Plastic would not work at all, it seems to be made of teflon, am I right? Still it would not break unless there there was an obstruction that opposed the rotation to the point it broke. |
Originally Posted by Jaskirat
(Post 2960849)
Hi Mr. Fazal, I sure it is Teflon. Though I have only seen the pictures, it is quite amazing how the thing has sheared. I think it must have been a failure of a bearing that caused this part to come under stress and break. It will be great know Mr. Behram's views on this. |
Originally Posted by Sutripta
(Post 2961202)
For silent running, phenolic cam gears were used for a long time. |
Originally Posted by DHABHAR.BEHRAM Dear Sudarshan / Fazal and Jaskirat - can I please see some photographs of the oil sump of this vehicle as it came out after the oil pump gear broke. This part is same as Scorpio, used in regular production in very large numbers. I would also like to see the engine-axle interface closeups in full jounce condition. Best regards, Behram Dhabhar |
Originally Posted by Sudarshan
(Post 2961409)
btw do you have pics of the complete assembly (dismantled parts ) ? |
(Post 2962548)
Dear Behram Sir, I will ask Karan to post some pictures of the sump. As per his initial feedback, the sump was not damaged, but we will wait for the pictures. |
(Post 2962486)
(Post 2962548)
Dear Behram Sir, I will ask Karan to post some pictures of the sump. As per his initial feedback, the sump was not damaged, but we will wait for the pictures. I will also try and get you the engine-axle interface close-up. Simulating full bounce would be bit of a challenge. I am posting a picture, which I had shared earlier. Engine-axle interface looks quite fine. Under full bounce, the axle should move further away from the sump. Regards, Jaskirat |
(Post 2964165)
Sorry, no. I think everybody is waiting for this report! Regards Sutripta |
Originally Posted by headers
(Post 2965886)
@Tharplus : Sir No pictures found :( |
Originally Posted by TurboDiesel
(Post 3124925)
No one to comment on why the plastic material was used for that gear in the pump? |
