Team-BHP > 4x4 & Off-Roading > 4x4 Technical
View Poll Results: Poll canceled.
option 1 0 0%
option 2 0 0%
Multiple Choice Poll. Voters: 14. You may not vote on this poll
Old 24th February 2023, 23:30   #301
Blooming Flower's Avatar
Thanked: 1,606 Times
Re: Torque generation and distribution
There is a simple way to understand the need for load. Hold a pencil lightly in your left hand (load L1), and try to rotate it using your right hand. You can do it with little force (force F1). Next, hold the pencil tightly in the left hand (load L2). The right hand will require lot more force (force F2) to rotate it. Now, hold the pencil lightly again (L1), try to apply F2 amount of force. You can't... because there is little load. You can't generate torque without a load to overcome.
Well, while this is a fantastic analogy for simpler explanation, but I think it’s the other way around.
Consider torque is a rotational effort, which can be approximated by the force applied by your fingers of the rotating hand (right hand) times the radius of the pencil stub. So, you apply ‘enough’ force on the pencil (such ‘enough’ to break the fingers if held much tightly).
First, you hold the pencil lightly (in left hand) and try to rotate it with another hand. With the aforesaid ‘enough’ force, it will rotate.
Again, you hold the pencil a bit tightly. Even now, if you apply the same amount of force it will rotate, because the force applied was much higher since the beginning to overcome the resistance.
Now, consider the fingers of your rotating hands are soaked with oil in such way that they slip on the pencil surface. Again, you apply the same ‘enough’ force. But the pencil will not rotate. It does not mean that your rotating hand (fingers) is not generating enough torque!
Similarly, you run the engine at 5K RPM, for say, or revving even harder as much as you can, and one wheel on the driving axle loses traction; despite the engine producing enough torque the vehicle cannot move on its own.
Blooming Flower is offline   (1) Thanks
Old 25th February 2023, 00:44   #302
Samurai's Avatar
Thanked: 49,859 Times
Sorry, I am not able to follow your example. What is 'enough' force? It is the same amount in each case, or different in each case?
Let's assume it is same, say 20Nm, which is enough to break fingers as you say.
Case 1: Pencil lightly held
To apply 20Nm to a lightly held pencil, it has to be rotated at a very high rpm. (can fingers really do this?)
Case 2: Pencil tightly held
When you apply 20Nm to a tightly held pencil, it will now rotate at lower rpm than before. Tighter the grip (load), lower the rpm.
Case 3: Rotating finger socked in oil
You won't be able to apply 20Nm to the pencil if it is slippery. Can a rockclimber climb a 30ft high smooth wall with his barehands? He simply won't be able to apply force to lift himself. No grip, no climbing. Similarly slippery turning finger won't apply any force to the pencil, so you won't be generating any torque.
Samurai is offline
Old 25th February 2023, 01:13   #303
Thanked: 61,588 Times
Re: Mahindra Thar : Official Review
Originally Posted by RadixLecti View Post
Thanks, I realise that. I also realise that from one post to the other I moved from discussing 'lifting' the weights to simply 'moving' them. My mistake. My original numbers would only work for horizontal movement on earth.
Depends entirely on the brake away- and friction coefficient.
As soon as you start moving stuff on earth horizontally you also need to figure in things like aerodynamics, wind resistance etc.
Jeroen
Jeroen is offline
Old 25th February 2023, 01:34   #304
Originally Posted by alpha1 View Post
it should generate constant explosive force on the piston during expansion stroke ... creating the constant force moment (torque) at the crank shaft.
It doesn’t.
Neither the Force due to combustion is constant nor is the arm that creates torque constant. The crank turns around at 0o and 180o the arm is actually exact zero! So is the torque. At 90o past top dead centre the arm is maximum. On the expansion stroke this does not necessarily coincide with the most force exerted on the position due to the combustion/expansion.
So the amount of torque depends/varies depending on the crank position, how the combustion and expansion takes place and in which part of the two or four stroke cycle you are.
These varying torque values can create problems. Can cause vibration and undue stresses.
A flywheel is partly there to dampen out that effect. (Among other things). On larger engines you might also find dynamic balancers. ((E.g. my Jeep Cherokee)
On both petrol or diesel engines as a rule of thumb to calculate the force on the piston you need to look at the pressure in relation to the position of the piston. If you know the dimension of the piston and the pressure you can calculate the theoretical force. For practical purposes you need to also consider centripetal forces (depends on rpm, mass and stroke). Also, you need to add in the gravitational constant and the forces that it creates.
So it is a bit more complicated. But on both petrol and diesel engine you will find that the pressure in the cylinder rises during compression and peak during ignition, which usually start a bit before top dead centre and ends just after top dead centre. The pressure peaks and as the pistons moves downwards the pressure drops as well.
So nothing constant when it comes to forces or arms and thus torque. Remember torque is a static unit! Nothing moves, its engineering unit is Nm. You need to calculate torque for every position of the crankshaft and it will be different for all those different positions. If it is a two stroke you will need to calculate it for 360o of crank rotation. For a four stroke you need to calculate it for 720o degrees of crank rotation.
Usually this gets plotted out as a function of piston stroke. Add RPMs and you have your power.
It is an important part of an engine design. This will also for instance allow you to dimension the bearings and bearing support correctly.
Another fact: on many engines if you run the engine at high RPM with no load the crank might actually push into the top of the bearings, rather than the bottom.
The centripetal forces are larger than the forces generated on the piston from combustion!
Werkspoor TM410 marine diesels had this problem initially. Nobody had thought of this initially and only designed the bearings for running under high RPM and high load.
Jeroen
Jeroen is offline   (2) Thanks
Old 25th February 2023, 07:05   #305
dhanushs's Avatar
Thanked: 11,488 Times
Assuming you own a Thar, please try this out in the Thar. The Thar has a power and torque meter. You will see only less torque being produced. But once the MLD kicks in or you get traction, you have more torque.
dhanushs is offline   (1) Thanks
Old 25th February 2023, 07:59   #306
Samurai's Avatar
I gave simpler explanation so that people can get a conceptual understanding. It is a common technique used in modelling. It doesn't mean the system is simple, so that you can use simple arithmetic or change any variable as you please. As Jeroen articulated, torque is delivered as a sine wave rather than continuous. Think alternating current (AC) instead of direct current (DC). That means you need to use calculus and not simple arithmetic.
Also, another point. We are not trying to discover the science or physical laws behind the working of a gearbox. Those were discovered centuries ago. This is settled science, and nothing like string theory.
Samurai is offline   (2) Thanks
Old 25th February 2023, 09:44   #307
Sorry, I don't own a Thar with this functionality.
However, in all my previous posts, I used the term 'usable' and 'available' torque. I understand how load or external resistance play role in engine torque and power generation. When an engine is running idle in neutral at high RPM, it generates energy, and this will proportionally vary with the RPM (not linearly, of course, as several other factors come into pictures.); and during this high RPM idle run, I completely agree the load vs torque curve will be different. The easiest example I recall-- in a small pandal of our vicinity, when the electrical load is increased how the so called, popular single cylinder diesel engine behaviour changes, and it's clearly can be sensed through the change in how it sounds! For this matter, if we run a vehicle engine at full throttle for several hours it obviously produces enough energy which is not 'usable'. Here, 'usable' means if the energy could be used to move the car from point A to point B.
But that does not mean that with the increasing RPM, in absence of the 'load', there is no increase in torque also. This phenomenon does not essentially change the inherent working principle of a differential.
If you put a PTO device (say a sugarcane juicer) between the gearbox/transfer case, and the differential connected by a propeller shaft in continuity, the engine will produce the 'engine load torque' from the load of the PTO device. At this condition also, if a wheel in the driving axle loses traction, all the 'available' torque through the propeller shaft will be transferred to it only.
OTOH, are all the owners of current generation Thar fed with wrong info. in the official owner's manual regarding how BLD works? Is it going to get revised in coming days?
Old 25th February 2023, 10:47   #308
SS-Traveller's Avatar
Thanked: 28,733 Times
Have noticed this, as also similar meters in some Maruti Suzuki vehicles. How do these meters work? Are there certain sensors to record the power and torque readings, or is this an extrapolation based on factors like fuel flow, throttle position and known dynamometer readings?
SS-Traveller is offline   (2) Thanks
Old 25th February 2023, 11:33   #309
One last post in this discussion. The torque fluctuation and torsional vibration from any IC engine are evened out by the flywheel first as well as a single or multiple universal/cardan joints in the propeller shaft. This phenomenon is more prominent in 3-cyl or odd-number cylinder engines. Apart from these two basic mechanical counter-measures, there exist several other modern methods to deal with the issue. And the arithmetic and calculus, whatever they are, are taken care of by the software in the background (e.g.the widely known GT-Power by Gamma Technologies) during the testing phase with proper design and performance inputs.
Anyways, imagine the propeller shaft of a vehicle is somehow connected with a massive ship diesel engine. No doubt, at the idle condition, with the lowest ever RPM (to run the engine), the 'available' torque value of the ship engine is much much higher than the peak 'engine load torque' of the original vehicle engine. Do you still believe the vehicle can move with one wheel on the drive axle without traction? Or, the ship engine too cannot generate much torque to move out the vehicle without 'engine-load' or resistance? Is the working principle of the differential altered?
Old 25th February 2023, 11:40   #310
Would be interesting to know.
I have come across all sorts of torque sensors used for R&D design on car axles and such.
E.g. https://binsfeld.com/torquetrak/markets/automotive/
On ships propellor shafts torque is measured by means of torque sensors. They are incredibly sensitive. I know we had several set ups in our lab at college. We had a 25 cm thick metal round bar with very simple strain gauge attached to it. With a simple pliers we would grap it and apply some force. It was surprising how little force was needed to get a response from the strain gauge!
That was over fourth years ago. Sensor technology has come a long way.
Jeroen
Old 25th February 2023, 12:21   #311
No, universal / cardan joints have nothing to do with fluctuation and or torsional vibration on an engine. If anything they need to be designed to withstand it!
Here the universal joint of my Jeep taken apart on my work bench. You tell me how it evens out fluctuation of torque?? There is no mass or anything else that would even out fluctuation of torque.
Contrary to popular belief, universal joints are not sort of rubbery floppy things. They are purely mechanical and all metal/steel. It is used to connecting rigid shafts whose axes are inclined to each other. They need to be as rigid as possible, in order to work efficiently. So they will “transmit” if you like torque and all fluctuation of torque from one shaft into the next.
As I mentioned earlier not only the flywheel, but on some cars they use what is known as dynamic or harmonic balancers. Here you see an image of the harmonic lancer of my Jeep. It sits on the front of the engine on the crank shaft, hence the seal you see there as well. It is also the pulley that drives the various engine accessories (alternator, AC compressor etc).
These harmonic balancers or dampeners are made of two steel parts held together by rubber. So they can move or rather rotate respectively from each other, which is what evens out fluctuation of torque. These harmonic balancers are often used on cars that have relatively small (weight wise) fly wheels such as the Jeep.
Also of course, you have the dual flywheel, which is simply put, a combination of a regular flywheel and a harmonic balancer, from a principle point of view.
Not necessarily. First of all it depends on whether it is two or four stroke. Next how the crankshaft is configured and lastly the firing order.
GT-power software or similar is/can be used to dimension for instance a fly wheel or a harmonic balancer. Or optimise firing order etc etc. But fluctuating torque is an inherent IC engine fact of life. You also want to deal with it as close to the engine or inside the engine itself. Because that is the most efficient way of dealing with it. Otherwise you need to dimension the prop shaft, gear box, differential etc all to handle it.
I am truly sorry. But whatever you write is incorrect or I simply don’t understand it at all.
Although simplifying can be a powerful tool in explaining yourself, it takes a real expert to do so. If you don’t understand the physics behind torque, no amount of "dumming" it down is going to make a credible simplified story.
Appreciate all your efforts though.
Of course, I might be wrong on all of this as well. It has happened before! I am just an old git these days.
Jeroen
Jeroen is offline   (4) Thanks
Old 25th February 2023, 12:33   #312
Samurai's Avatar
If Jeroen who used to be chief engineer on a ship can't understand your example, you will have to spare me. I am just a software engineer who dabbles in basic physics.
Samurai is offline
Old 25th February 2023, 13:50   #313
The sole purpose of cardan joints in RWD vehicles was to reduce the jerky rotation (angular speed fluctuation) by application of the phased component of angular velocity transfer, AFAIK.
Yes. It's one of the several other counter-measures I mentioned in my previous post.
Consider this for 4-stroke regime only, where designing a 3-cyl engine is tougher than developing a 4-cyl engine to deliver the same level of noise and vibration performance.
Nowadays, automobile industries do not solely depend on experimental, tangible testing. Rather, to cut-short the development time, simulation is the way forward. GT-Power can simulate/predict the engine performance quantities such as power, torque, airflow, volumetric efficiency, and fuel consumption in the design phase itself (when the real prototype engine is not even built). I mentioned it in the context of arithmetic and calculus in order to calculate engine torque and power.
Jeroen
You need to follow a whole lot of previous posts from the new gen. Thar review thread for this, where it was pitched in-- when one wheel loses traction the vehicle can't move out on its own because the engine receives insufficient load to generate ample torque. I put this simile of a ship engine, which produces much higher torque in the idle state itself than a puny vehicle engine generates at its maxed-out limit with external load. The question was-- despite the ship engine generating more torque, is it able to move the vehicle with one wheel losing traction?
Blooming Flower is offline   (2) Thanks
Old 25th February 2023, 22:17   #314
Thanked: 5,892 Times
I am an electrical engineer, so don't understand 90% of the jargons used here, so unable to form a coherent understanding of who is making what point exactly.
But inorder to check whether I am getting a sense of the direction this discussion is going, I would like to compare two systems - an electrical motor and an IC engine. Both generate torque and both have rpm ; and both obey the fundamental tenet of energy calculation :
energy/sec = power = torque x rpm
So far so good, all of us agree.
Electrical equivalent of fuel is the current,
Electrical equivalent of accelerator pedal (or throttle) is the voltage.
Electrical equivalent of flywheel is a parallel capacitor (simply there to 'smoothen' out 'pulses' of torque generation)
Say the load on the electric motor is gradually increasing (it's lifting a sand bucket through a chain mechanism and sand is constantly pouring into it from a hole) - even without voltage change, it will 'automatically draw more current' and produce more torque, to combat the increasing load. And as it does so, the rpm will keep coming down gradually, until a point where it can no longer draw anymore current, and stall (and possibly burn or melt the windings from the highest current at the time of stalling).
So what happened here ?
The system is inherently having automatic feedback (higher load making it draw higher current) until a certain 'load limit' is hit. For the next stage, there is no other option other than increasing the voltage, further enabling higher current for higher loads.
This is similar to the case of a constant throttle (for simplicity sake, consider a petrol engine with a pure mechanical butterfly valve as throttle) for the vehicle to climb up a slope, the ECU decides by itself (automatic feedback) to burn more and more fuel, continuously suffering vehicle slow down, until it can't do it anymore, and stalls the vehicle. For the next stage, there is no other option other than increasing the throttle (voltage) to enable more air and further enabling more fuel for higher loads.
So in both cases, the load-demand 'automatically' translated to torque-demand and made the system generate more torque. By drawing more current in one case and by drawing more fuel in the other case. However, this happened only until a load-limit window was breached.
The provision of various gears and exercising the available choices amongst them ; in the path between generation point and load point , is simply 'widening the window' of 'automatic response by the system'.
So we can all agree that 'load' influences how much 'torque' is generated. However, it happens only within a 'window of operating points' - beyond that, to generate more torque, some 'external action' like more throttle to enable more air or more voltage to enable more magnetic field is needed, so that even more fuel or even more current can be drawn and utilized to generate more torque.
So what happens when an engine in neutral / motor at no load , is given more throttle/voltage ?
The load is purely the 'rotational inertia' present on the disconnected shaft. Since this "load" is unvarying, as soon as the system generates the torque to overcome this, all the rest of the energy provided simply translates to more and more rpm. More throttle/more voltage - simply more rpm, no change in torque generated.
Hence, my take on the matter is, within a window of operation, the load indeed does decide what should be the ratio of split between torque and rpm, for the energy that is made available to the system. If the load increases such that a point is hit where (100% torque, 0% rpm) occurs, then more energy needs to be made available for this new load to further decide what should be the split ratio between new torque and new rpm.
venkyhere is offline   (3) Thanks
Old 26th February 2023, 10:58   #315
I understand that this thread originated due to the debate about MLD, BLD, LSD etc getting too technical in another thread.
The thread is filled with jargons and technical terms to the level that a layman will find it hard to understand, so let me try to translate a bit :
What is a differential and why was it invented ?
When the non-steered rear wheels of an RWD vehicle are subjected to a turn, say a right turn, there has to be a mechanism to allow the inner wheel to turn at a lesser rpm than the outer wheel, so that when the vehicle changes it's orientation gradually from straight to 'right turned' , no tyre rubber 'screeches' against the road or 'slips' against the road and gets shaved off.
Turns out, the mechanism is 'already there', because the rubber that forms the tyre, needs to 'twist' at the contact patch, when wheels which have no steering have to 'turn'. Utilizing this fact, a basic 'differential' (called open differential) was invented, with a system of rotating cogs that works in the following way :
A way where the 'energy' gets split equally amongst both wheels - the inner rear wheel experiences more tyre rubber twisting load on it's contact patch than the outer wheel, because it's trying to achieve a sharper change in orientation due to smaller turning radius => more torque demand presented by inner wheel w.r.t outer wheel => the ratio of rpms between wheels is inversely proportional to the ratio of torque loads between the wheels. Effectively torque x rpm (the energy/sec) on each wheel is the same, and this is a neat mechanism.
However, all hell breaks loose (the energy getting split equally goes out the window), when there is very poor or no friction on offer, on one of the wheels amongst this left and right. The design of the open differential is such that the 'engine torque' that needs to be generated is defined (through gear ratio translations of course) purely by the smaller of the two torques demanded by the left and right wheels. This aspect creates an issue. When one wheel is on a slippery surface (sand or ice) the 'load torque' on that wheel is effectively the rotational inertial mass of the wheel+tyre+brakedisc of that wheel alone. That means even if the 'other' wheel is sitting on a proper grippy surface, the torque-demand or torque-load presented to the engine is that of the slipping wheel, which is low. The engine will only generate as much torque as is presented as load to it (previous post above).
So now, there is one wheel with grip, and the open differential is ineffective in 'utilizing' it. In other words, the open differential is something that allows the flow of energy through the path of least resistance.
To combat this problem, the question now is, 'how to present a higher torque demand to the engine, when one of the wheel is simply slipping and presenting none'. Thus was invented things like MLD, BLD, LSD etc. (all jargons, but with careful meaning hidden in them - mechanically locking, brake locking, limited slip). All of these are trying to build a relationship between the left and right wheels, something that the open differential never allows. These jargons are trying to 'counter' the fundamental edict behind the invention of the open differential - FROM "let the load dictate how much torque demand needs to be presented to the engine" TO "let us artifically remove the independence of the left and right loads from each other and then present a 'cooked up' torque demand to the engine".
In case of MLD, the left and right are simply locked into a single solid axle, the left and right have to rotate at the same speed. In case of LSD, there are clutch packs present, that can control the 'resistance to turning' offered by left side or right side. In case of BLD, the brake computer (or ABS computer) externally uses it's brain, to actually press the brake discs to 'artificially' create extra torque load wherever necessary.
In case of open diff, the effective torque demand to engine is the smaller of the two "contact patch friction load" required to rotate the individual wheels.
In case of locked diff (MLD), the effective torque demand to engine is the larger of the two "contact patch friction load" required to rotate the individual wheels.
In case of a slipping diff (LSD/BLD), the effective torque demand is the smaller of (contact patch friction load + brakes pressed load) required to rotate the individual wheels.
Hope this is useful to a layman reader.
venkyhere is offline   (5) Thanks
