Old 15th November 2011, 00:18   #1
k2max6's Avatar
Thanked: 183 Times
Hows the Pioneer GM-3400T 2 Channel Amp?
I am about to buy a 2 channel amplifier to power my rear infinity coaxials 9633i.
Saw the JBL GT5-S422 and the Pioneer GM-3400T.
Could not find anything about the GM-3400T.
How is it & is it advisable to go for it against the GT5-S422.
Similar Price for both.
k2max6 is offline
Old 15th November 2011, 06:38   #2
nitrous's Avatar
Thanked: 333 Times
Re: Review Wanted : Pioneer GM-3400T 2 Channel Amp
Better options are available.
Get a 4-ch amp like the JBL GT5-S644 or the hertz ep8 and you could power either the front channels or a sub too.
nitrous is offline
Old 15th November 2011, 11:16   #3
panky12345's Avatar
Thanked: 172 Times
Having used the same amp, I can firmly say that its a quite average product. With the same money, you have better options, as my friend nitrous has pointed out.
panky12345 is offline
Old 15th November 2011, 16:49   #4
k2max6's Avatar
Thanked: 183 Times
Thanx.
I have the GT5-S644 powering the front components and the sub.So i guess the GT5-422 would be good to power the rear coaxials ?? Also is it advisable to amplify the coaxials ? Would i feel the difference,soundstage being in front ?
k2max6 is offline
Old 16th November 2011, 11:17   #5
DerAlte's Avatar
Thanked: 2,920 Times
Re: Hows the Pioneer GM-3400T 2 Channel Amp?
If you are driving, you wouldn't (shouldn't) know the difference in the rear seat. The rear seat passengers will definitely feel the difference between amplified and not amplified even with a coax.
Also, instead of buying a weak 2 channel amp, it is recommendable that you buy a good amp (mono or more powerful 2 channel) to drive the sub separately, and use the existing 4-channel to drive the front and rear speakers.
DerAlte is offline   (1) Thanks
Old 16th November 2011, 23:13   #6
k2max6's Avatar
Thanked: 183 Times
I always drive alone ! Do i have any options under 7-8k ?
How would be Auditor RIP 2300 ? (450W RMS @4Ohms)
One last noob question - Is it by any way possible to bridge all the 4 channels of an amp to 1 Mono Channel
k2max6 is offline
Old 17th November 2011, 11:15   #7
DerAlte's Avatar
How much are you getting the Auditor for? Sounds good.
NO, one cannot bridge 4 channels of a 4 channel amp to get one powerful mono channel. Of course, if one has a DUAL-voice-coil sub, one can drive each coil with the bridged channel. There are limitations in driving in bridged mode: most amps cannot drive less than 2 ohms in bridged mode, so one cannot connect the coils of a 2+2ohm sub in parallel and connect it across the bridged channels.
DerAlte is offline
