Old 26th January 2021, 10:10   #76
Thanked: 21,373 Times
Infractions: 0/1 (10)
Re: Gain settings simplified!
Originally Posted by straight6 View Post
The 1st post of this thread says you must consider the rms of the amplifier which would be 700 @ 2 ohms so then shouldn't I have set it at 37.41 V?
Yes sir. Sorry for the blunder at my end. RMS of amplifier is to be considered and not the speakers/subwoofers.
V = sq root of (700 x 2) = 37.41V.
a4anurag is offline
Old 26th January 2021, 14:20   #77
straight6's Avatar
Thanked: 283 Times
Lol no wonder I found the bass to be a little less. When setting gain should the rca cables be unplugged alomg with the speaker wires or can the speaker wires be connected?
straight6 is offline
Old 26th January 2021, 17:21   #78
It'll be good if the speaker wires are disconnected when setting the gains and crossovers set to full.
Find where the HU clips first (so you never cross that volume level), then set gains on the amplifier.
a4anurag is offline
Old 26th January 2021, 20:05   #79
straight6's Avatar
Thanked: 283 Times
How do I find the clipping point of the hu?
Old 27th January 2021, 20:03   #80
Do you have access to an oscilloscope?
a4anurag is offline
Old 27th January 2021, 20:09   #81
straight6's Avatar
Thanked: 283 Times
Nope but im seeing some cheap ones on Amazon these days. Are those any good?
Old 27th January 2021, 20:15   #82
My friend tried but they weren't accurate enough hence was returned. I have one on the way from the USA, will see how good that is.
You have a PM from me.
a4anurag is offline
Old 24th May 2021, 22:26   #83
roby_dk's Avatar
Thanked: 2,143 Times
Hi Guys,
I recently upgraded my music system and I have added below components with factory stereo.
1. Mosconi Gladen PICO 8|10 DSP - Eight Channel DSP Amplifier (Rated: 50W x 4channels + 80W x 4channels at 4 ohms)
2. Gladen Zero 165 - 6.5inch 2way Component Speaker Set for front and rear (Rated: Mid Range: 2 x 100W at 3 Ohms, Tweeters: 2 x 50W at 4 Ohms)
3. Sundown SFB-1000D Mono Amplifier (1 ohm RMS=1000W, 2 ohm RMS=850W, 4 ohm RMS=500W)
4. Sundown Ev3 12″ D2 subwoofer (500W RMS at 4 Ohms)
The above system is running fully active with all components customizable via Mosconi Gladen GUI interface. I need help in understanding the GUI if anyone here is using the same amplifier or maybe help in understanding the frequency range and slope to be set.
Attaching few pictures of GUI interface for reference.
roby_dk is offline
Old 24th May 2021, 22:59   #84
Thanked: 870 Times
Originally Posted by roby_dk View Post
Hi Guys,
Here you go - refer to this video:
It's very difficult to walk you through based on GUI pic. Even though most of the options would be similar among these DSPs [I play around with Dayton DSP 408] it'll definitely take some time getting used to. Also if this is the first time, I would suggest read up on different parameters of DSP settings in general like frequency/phase/slope etc.
PS: Congrats on the system! Those are some cool stuff in there.
somspaple is offline   (1) Thanks
Old 31st July 2021, 15:07   #85
viXit's Avatar
Thanked: 2,755 Times
The links in the OP's post aren't working.
Kicker Audio has everything here.
https://www.kicker.com/test-tones
viXit is offline
Old 31st July 2021, 22:07   #86
viXit's Avatar
I'm using a JBL stage a9004 90.4 amp. It says class d on the internet.
when trying to set the gains using method in post #1 of this thread, my voltage reading isn't going higher than 15v when according to the calculation I need close to 19v. What am I doing wrong?
viXit is offline
