Old 26th May 2009, 14:08   #9406
cooldude1988765's Avatar
Thanked: 222 Times
Most HU's use bridged amps so do not attempt this.
Attempting to bridge 2 bridged amps will damage the amps.
So it is a firm no then ?
Originally Posted by DerAlte View Post
If you are connecting the speakers to the HU you will be using the dedicated Speaker terminals, not the Pre-outs. Pre-outs are meant for feeding (low-voltage) signal to an amplifier, and 'bridging' is not associated with them.
HU amp will distort at high volume levels. If you really want to go loud, someone is selling a 2-channel Kenwood amp cheap in the Classifieds - grab it.
I was talking about the speaker terminals only.
I am talking about my jeep ice so cannot install an amp.
cooldude1988765 is offline
Old 26th May 2009, 17:49   #9407
Sam Kapasi's Avatar
Thanked: 2,479 Times
Originally Posted by cooldude1988765 View Post
Dumb question:
Can the internal amp in a HU be bridged ??
No dude. Firm and absolute no. You will fry the HU.
Sam Kapasi is offline
Old 26th May 2009, 19:33   #9408
sathee46's Avatar
A Doubt on setting the gains. I read the gain settings simplified thread, I got myself a multimeter to do the tuning. as per ohms law the target voltage is calculated as sqroot of {watts ( rms) x load ( ohms )}. The speakers which I have has is rated 2 Ohms, my amplifier is rated 85W RMS x 4 channels @ 4 ohms and 135W RMS x 4 channels @ 2 ohms
When tuning with the multimeter, should I be aiming at a voltage of 16.4 V @ 2 Ohms or 18.4 @ 4 Ohms?
sathee46 is offline
Old 26th May 2009, 22:15   #9409
Shashank.A's Avatar
Thanked: 11 Times
Originally Posted by Sam Kapasi View Post
The esteem accomodates a 4" speaker in the front. If its the old esteem, the position of these speakers is brilliant, corner top dash. However the newer esteems relocated these speakers to fire at the knees. Bad.
JBL doesnt even make a 4" component system and i dont think other mfrs do either. Besides, you already have tweeters so why waste them?
Just buy a decent pair of 4" normal speakers. Make sure theyre powerful enough to handle an amp in the future.
If you want to save money on a crossover for this speaker (basically cut sme bass off the front speakers) i have an excellent supercheap idea.
Go down to lamington road and ask for 2 pcs of 100microfarad, 50Volt electrolytic capacitors. (Dont faint, its not that hard to say it) Should cost you about 10 bucks each. twist them back to back (Negative to negative)
then use the 2 positives as in/out.
Sam Bhai !! great piece of advice. Very old post of yours, but going through the ICE threads now is all about big bucks.
And regarding the Old Esteem, I do have a 97 Esteem and the stock Audio system that came with it. yes its a 12 year old, kenwood cassette player, with god knows what speakers. I have been using the Jugaads to run Mp3 player and Mobile phones till now, but now I am going for a new ICE. And I agree, the positioning of the front speakers is excellent in my car, with a bit tweaking in the balance, it creates a very nice effect.
Now as you have mentioned 4 years back, no one was making 4" Comps, what about now ? Are they still not available ?
What about rear speakers ?
Shashank.A is offline
Old 26th May 2009, 22:51   #9410
navin's Avatar
Thanked: 9,961 Times
Either is fine. the amp has current limitation and that will kick in if too much current is drawn.
navin is offline
Old 27th May 2009, 10:43   #9411
devrajman's Avatar
Thanked: 119 Times
iPOD/PMP/MP3 Player/MP3 Phone with Car Amplifier (NO HeadUnit)
I was thinking we can totally get rid of Head Units.
A good Amplifier, any MP3 playback capable gadget and speakers...Thats it!
This has many advantages like,
-No expensive HU required
-Loud Music due to Amplifier (also not wasting HU's internal amplifier which we mostly do when we install an amp)
-A phones jack that can be used with any gadget so lots of compatibility
-No question of theft of HU as it isnt there at all!! :-)
-Can hear FM too if your gadget has it
All we need is a cable from Amplifier which has phones jack which can be used with any MP3 playback capable gadget.
All MP3 playback gadgets have inbuilt equalizers, library and other features that make playback of music very easy.
devrajman is offline
Old 27th May 2009, 12:33   #9412
Sam Kapasi's Avatar
Thank you. That post was made a long time ago. People today may be spending more on ICE than ever before, but we are still here to help those who want to spend as little as possible.
Today even fewer 4" speakers are available that before. I believe Kicker and Illusion do make 4" component sets, I could be wrong. I know JBL and Infinity do not.
What about rear speakers? The original factory position of the Esteem accommodates 6" speakers. Go for it.
Old 27th May 2009, 12:46   #9413
Shashank.A's Avatar
Thanked: 11 Times
Is JBL not doing them in India only or all over ? because i saw this is classifieds - Team-BHP Classifieds - JBL 4 inch component speaker system. - Powered by PhotoPost Classifieds
Old 27th May 2009, 13:02   #9414
hydrashok's Avatar
Thanked: 19 Times
@devrajman, you'll find more info here:
http://www.team-bhp.com/forum/ask-gu...will-work.html
hydrashok is offline
Old 27th May 2009, 13:08   #9415
Sam Kapasi's Avatar
You have forgotten an indispensable part of the audio system.
The PRE-amplifier.
The HU corrects and tweaks the raw signal from your player. It further divides it into front and rear preamp outs, allowing you flexibility, not only for balance, but also the front and rear fader output.
It can allow you to digitally process the signal, may allow you to adjust time delays to get a good soundstage.
It can also divide the the low signal and route it to the subwoofer amplifier, also correcting the phase and offering an electronic crossover.
There's a lot a HU does apart from playing discs.
Old 27th May 2009, 14:49   #9416
anoopap's Avatar
Thanked: 22 Times
Mobile to Amp to Car speaker
Is it possible to play music through my mobile (W810i) bluetooth/USB jack to amplifier and then to car speakers.
i dont want to spend on HU as im not using mp3 CDs anymore.
Can anyone pls advise on the specifics (for 4 speaker output). mine is swift petrol.
anoopap is offline
Old 27th May 2009, 15:16   #9417
Thanked: 328 Times
Anyone can help me with a reasonable shop in Mumbai who is a good tuner of ICE and knows his job, I am looking at something in Andheri West or around, don't mind going upto bandra or something.
I don't want someone who will rip my pocket apart.
I have a honda civic with JL Audio Component 2 pairs with Blaupunkt amp and JL Audio Subwoofer 12" with Jl Audio mono block 1000/1 amp.
Just need someone to tune it properly as my guy has moved to Bahrain.
PLease help with some contacts.
Cheers.
The Saint is offline
Old 27th May 2009, 16:05   #9418
navin's Avatar
Sam, you'll be surprised by the number of people who have tried this. The result usually is a fried output IC.
This has been done but it has limitaions as Sam has pointed out.
Ipod via ipod dock to RCA splitter (splits stereo signal to dual stereo). Splitter feeds 4 ch. amp. Front channel of amp feeds front speaker, other 2 channels bridged to sub. All controls (vol, eq, etc..) on ipod.
limitations
1. No rear speakers hence no fading
2. No TA
3. No balance control
4. you have to control ipod in car which is diffcult when driving.
navin is offline
Old 27th May 2009, 16:47   #9419
jaibir's Avatar
Thanked: 50 Times
I've been tweaking around the system for the last couple of weeks with the help of an audiophile friend. The first thing he suggested I get done was some damping for the front doors. Got that last weekend from FM drive. Made a world of difference to their sound. He also tweaked the amp settings and HU settings to bring out the best in the existing speakers. However, the bass on the rears is still too lose. Will try tweaking with the way the rears are installed (possibly some fiddling with the MDF tray) to see if that help make the bass tighter. I'll also be borrowing his sub to see if that suits my needs better.
Any suggestions on possibly tweaks on the rears from the Gurus?
Originally Posted by jaibir View Post
I upgraded the ICE setup in my Swift yesterday. Here is what I have now:
HU: Pioneer 4050
Fronts: Illusion Electra 6.1 components (upgraded yesterday)
Rear: JBL 937 on a MDF tray
Amp: JBL 1004 (added new)
Wiring: ground zero and monster
Got the install done from FM Drive (Pankaj Bhai).
While tuning the system, the shortcomings of the rears became quite apparent. I dont know if they are defective or are designed that way but the bass was a bit too loose (as if the speakers couldnt quite handle the power). Pankaj Bhai tuned the system so that the overall sound stage sounds quite good, but I cant help feeling that a better rear solution is warranted.
Would appreciate some inputs on what to install in the rear in lieu of the JBL 937's:
a) a new pair of 6x9's? If so which ones?
b) a Sub. If so which one and what type of install? would like to retain as much boot space as possible if going with a sub
I still have the GT5 2-way speakers and GTO tweeters I was using the front earlier, if needed.
My upgrade budget started out at 10k and has already reached 22k. I guess I can add another 8k or so for the rest of the upgrade. I mostly listen to rock (spectrum from Emerson Lake and Palmer to Megadeth). The Mrs. occasionally likes to listen to hindi movie songs.
jaibir is offline
Old 27th May 2009, 18:03   #9420
Thanked: 4,910 Times
Dumb question:
I have a blaupunkt cassette player that has a provision for 4 speakers. I am going to use it to power only 1 pair of ovals (mostly JBL 937). So if i can bridge the HU preouts (?) will i get the speakers to go louder ?
we had discussed this in detail on this thread
http://www.team-bhp.com/forum/ask-gu...ier-works.html
read through if you are curious WHY it will not work
greenhorn is offline
