Old 11th January 2010, 14:29   #1
Mi10's Avatar
Thanked: 3,299 Times
Now, Why is my Amp power light not glowing ?
I noticed a peculiar thing in my Install.
My Front components are rated at 125W RMS and i am feeding a healthy 120W RMS from my Amp (RF T400-2)
Somehow the output from my Coaxials rated at 70W RMS fed by 75W RMS from its Amp (RF P300-2) seems to be over powering the fronts.
I used fader controls to check. When i keep all front, the output from the components seems quite low. Very much low than the rears. Now, i understand that Coaxials are very sensitive and all that stuff. But its just too low for me to ignore. the POint is, for the same volume level, the rear seems to play exceptionally loud than the fronts
I went and checked the Amp. The Power light of the front Amp (T400-2) is not glowing, however, the Amp for the rear (P300-2) is glowing.
For a second i thought the connection to the Amp is just not made. But then when i pull out the RCAs connected to the front stage Amp, there is no output from front.
What is the problem? Do i need to check again the whole wiring.
Is there a possibility of the Amp not giving full power to the components ?
Is the non functioning of Power light, just a case of defect LED or something more is running in the background ?
Can you Gurus pls help me sort out the prob
Mi10 is offline
Old 11th January 2010, 15:18   #2
DerAlte's Avatar
Thanked: 2,920 Times
1. Check the fuse(s) on the amp feeding the front
2. Check the connection on both ends of the power cable to the front amp
3. Check whether the ground connection to the amp is proper
No light at the amp may be an indication that, when loaded, the voltage drop is too much at the defective connection (fuse, joint, ground etc.) is too much for the amp.
DerAlte is offline
Old 11th January 2010, 16:00   #3
Mi10's Avatar
Thanks Der Alte for the quick response
Attached is a Pic of the Amps with the Distribution block
i my guess is that the Front Amps fuse may have blown.
I am telling this, as i ve used 2 distribution block (1 for power and 1 for ground) for the two Amps. Hence if one works fine, its has to be the blown fuse of the other Amp.
So how do we actually check if the fuse is blown?
Mi10 is offline
Old 11th January 2010, 16:12   #4
Thanked: 321 Times
Swap the power supply and check.
Ajaybiz is offline
Old 12th January 2010, 13:50   #5
DerAlte's Avatar
Oops, the manual does not indicate where the internal fuses are! Possibly one has to open the case to access them.
One possibility is to check the DC voltage at the 12V DC terminal with a multimeter when music is playing.
DerAlte is offline
Old 12th January 2010, 13:59   #6
Mi10's Avatar
Yes, i checked it today. It says only external fuse of 100A to be used.
I am running 3 Amps from my 4 gauge RF Amp kit. Hence if anything's wrong with the external fuse, all three amps may be affected. Hence that possibility is ruled out.
Will the amp also have an internal fuse ?
The Wiring is intact - i feel so, Not checked properly. will be cheking on the wiring this week. I dont see any other reason why it is not playing to its fullest potential
Mi10 is offline
