If you have seen this initial ownership thread, (
ShuvCivic -Tafeta White VM/T) you'd know I really stretched my finances to buy the car. So there was precious little to spend on ICE. Butttt at the same time, I HAD to upgrade to something I liked. I'm used to a PioHU+Illusion Electra+75.4amp+MBQamp+GZsub in the Baleno. It's a setup I'm extremely happy with and it has raised expectations from ICE too. The stock Civic ICE felt decent at low volumes, but needed some juice.
Due to the lack of funds, I toyed with the idea of transferring the Baleno ICE into the Civic. Although I really wanted to retain the Baleno setup - since a lot of it was tweaked/installed personally. Thankfully along came @razor as a saviour. He was letting go of the ICE in his Scorp. And it had tried and tested equipment which I was very comfortable with.
Illusion Electra 6.1 comps,
JBL 75.4 and a
JBL GT4 sub. I did not need a HU, since I wanted to retain the stock look and was willing to compromise on any resulting SQ loss. Perfect timing and the deal was struck.
Quickly setup an appointment with Karan (@ace6120) and the install happened on Wednesday. Kudos to his team to make it happen on the same day. Due to some unprecedented road-repairs being carried out, the start got delayed to almost 5pm. And then the team worked non-stop till 11 to finish off.
Special mention must be made of the guy he entrusted the primary installation job to - Amirul. Extremely patient, cool young lad with an eye for detail and a real intent to do a good job. Even at the fag end of the day. Impressive.
The plan was simple.
- Retain stock look as much as possible
- Avoid opening the dash
- No wires to be cut
- Damp doors liberally
- Just have a front stage. Disconnect the stock rear speakers
- Speaker level out from the HU to a Scosche Line Out Converter. Tap the front and rear speaker wires at the harness ends.
- Tap the ignition (accessory mode) harness for the amp remote switch on
- Locate the LOC and all sundry wires behind the rear seat-back
- Xovers to be located on the amp board. This meant extra wiring, but I felt it would look good !
- Tweeters to be installed in stock tweeter locations in the dashboard
- Use good thick wires. No fancy branded stuff required
- Carry over Scosche RCA's from @razor's setup
Pics coming up in the next post
