Originally Posted by Ithaca @Scorpion.
A few queries as you have commanded LNG Vessels and I haven't sailed on LNG. |
At the onset, let me clarify that I have only sailed on LNG carriers with steam turbine engines. They do not have LNG liquefaction plants. There are LNG carriers that have reliquefacion plants and diesel electric engines. Steam turbine engines are still very popular and the Japanese ship yards like Kawasaki and Mitsubishi still swear by them. The Koreans are the pioneers in the Diesel/Electric propulsion system. Re-liquefaction of Methane is far more complicated than for Propane and Butane because the critical temperature of Methane is around -83 degC. The normal refrigeration cycle used to reliqefy propane and butane do not work in the case of methane and they require far more complicated equipment. Reliquefaction plants for methane on ships have not been a great success in my opinion, and there is lot of scope for improvement.
LNG is carried at around -160 degC in tanks that are, basically, heavily insulated flasks. It is a completely closed system and not a drop of liquid or gas ever escapes unless something goes wrong. However, some amount of heat exchange does take place and gas keeps evaporating from the liquid surface causing increase in the tank pressure. This evaporating gas is called boil off and if not removed from the tank, it can lead to disastrous consequences due to increase in tank pressure. That is why an LNG vessel is allowed to burn her cargo as fuel. On a steam turbine ship the boil off is burnt directly in the boilers. On a ship equipped with a reliquefaction plant, the gas is liquefied and returned to the tank. There is a provision to burn off the gas in a Gas Combustion Unit (GCU) at times when the reliquefaction plant is not working, or to burn excess gas. There are some newer types of LNG ships with IC engines, where the boil off gas is directly burnt in the cylinders. Again, maintaining tank pressure within a safe limit is the key and the most important task. It can neither be too high nor too low. For your information, the maximum tank pressure allowed is 25kPa (100 kPa is one Bar), above which safety valves lift and let the gas out into the atmosphere, and the minimum is 0 kPa. Of course, there are automatic safety systems built in which give adequate warnings and start shutting down equipment well before the pressure reaches these figures. The normal pressure within the tank is maintained between 5 to 18 kPa.
LNG ships are highly automated ships with a plethora of electronic systems monitoring and controlling the entire cargo and boiler management systems. They have the highest safety record in the shipping industry because of the amount of safety devices and the training that goes in before a person is allowed to take charge of the vessel, its cargo equipment or her engine and other machinery.
Now to answer your questions. Again, a reminder, I am talking about steam turbine engines, mostly:
1. The boilers are designed to burn either gas only, HFO (Heavy Fuel Oil) only , or both simultaneously. The superheated steam is then used to drive turbines. Boiler burning modes are called Gas only or dual burning modes where both gas and HFO are used. HFO alone is only burnt at rare times during a break down of the gas compressor or system or if the ship is completely gas free, like for instance, before going in for a dry dock. A trivia, newer designs from Mitsubishi, with something called reheat burners, have taken the boiler operating pressures to 100 bars from the normal 60 bars. My last 3 years of sailing were spent on such a ship, right from her delivery. During manoeuvering, an LNG vessel has to be on dual mode to allow for sudden changes in fuel requirement.
2. LNG vessels have this written into the charter party. Older LNG ships had a guaranteed boil off rate (from the maker) of not more than 0.15%/day of the total cargo capacity of the vessel. This means that the maker guarantees that the insulation system is so good that not more than 0.15% of the total cargo capacity will evaporate per day. The owners may reduce this rate further as a means to get a better charter rate. The latest LNG ships (with the 100 bar boilers) have a guaranteed boil off rate of not more than 0.08%. The 100 bar boilers also reduce consumption. So you are allowed to burn this amount (maximum) every day, as fuel, and it is normally mentioned in the charter party. Normal maximum consumption of gas in the 100 bar boiler ships is about 6.5 tons/hour at full sea speed of about 18~20 knots.
There are 2 types of voyages for an LNG vessel, dual voyage or gas only. Dual voyages are voyages where both HFO and only the natural boil off (within the guaranteed rate) are burnt in the boiler as fuel. A gas only voyage is where only gas is burnt in the boiler except during manoeuvering. In this case, the natural boil off is supplemented by gassifying LNG in heat exchangers (called vaporizers) to meet the boiler demand. The decision to burn gas only or HFO is normally taken by the charterer depending on the prevailing rates for LNG and HFO. There cannot be a HFO only voyage for obvious reasons.
3. There is only one grade of LNG. A certain amount of the LNG cargo is normally retained in one tank (called heel) to keep the tanks cool and to act as fuel depending on the type of ballast voyage. The tanks, pipelines and related equipment, have to be at a certain minimum temperature, depending on the type of tank, before you can start loading LNG in order to avoid thermal shocks. This again is part of the charter party and the ballast voyage may be dual or gas only. In some cases, the entire cargo may be discharged and the tanks warm up during the ballast voyage. A tank cool down operation will require to be carried out at the load port before commencing loading operations.
