Old 27th November 2015, 13:54   #1
Thanked: 804 Times
How to DIY clean the wiper cowl vents?
DIY request from my side :
Maruti 800 : How to clean the inner portion of the highlighted area ?
Last edited by GTO : 28th November 2015 at 13:52. Reason: Each DIY = Its own thread
MunnabhaiMBBS is offline   (1) Thanks
Old 27th November 2015, 14:15   #2
noelnelly's Avatar
Thanked: 135 Times
re: How to DIY clean the wiper cowl vents?
I'm guessing the easiest way to do that is using a pressure washer with some kind of de-greasing agent and a plastic brush with a thin stem, maybe the ones used to clean bottles?
noelnelly is offline   (2) Thanks
Old 27th November 2015, 18:05   #3
Thanked: 804 Times
Thanks for the reply noelnelly.
Am also planning to open up the cover highlighted in Blue in the below picture. (I think) that it will further provide a larger outlet to get the stuck objects out.
Old 28th November 2015, 08:37   #4
Thanked: 21,451 Times
Why not get hold of an industrial blower and try blowing air into these vents to free out the debris?
Old 28th November 2015, 21:41   #5
Leoshashi's Avatar
Thanked: 43,503 Times
Re: How to DIY clean the wiper cowl vents?
There are two ways to do the same. Switch to recirculation mode first.
1. If you have only dust accumulated-take hold of a high pressure washer or blower and blow everything.
2. If there is debris accumulated, open the fender lining and then wash it. IF size of debris is too big, you may open wiper link rod inspection window and clean it.
To all 800 owners-keep this area clean always. If the drains become clogged, it can cause rust damage. It is one of the many areas which is prone to rust.
Do let me know if you need any more details.
Shashi
Leoshashi is offline   (10) Thanks
