Earlier this week when I was fiddling with my Jaguar I noticed a small chip in the front window. It was not very big but you could see that the layers in the window were beginning to split as well.
Over the years I have had countless of these chips and I have lost count how often I have had them repaired. Last year I had one on the company car too.
I checked with my insurance company first. And as expected, as it is fully comprehensive insured as an old/youngtimer, chips are fully covered. It is very easy. You just make an appointment with the nearest CarGlass location, rock up at the agreed date/time, the fix it and invoice your insurance company directly. Completely hassle free.
So I called Carglass this afternoon to make an appointment. As luck would have it , their local service station had a cancellation and I could come around straight away.
Not sure to what extent window repairs are carried out like this in India. Companies like Carglass specialise in window repair. Either chip repair or replacing your whole window. They even have mobile units that will come to you. My company car in the past suffered several badly chipped front windows that needed replacing. CarGlass uses their mobile unit and changes out the window at my employer parking lot. Great service.
But this time, I went to them. I was seen to by Pascal, a very nice and highly competent lady.
Here you see the chip, Pascal has already put a mirror on the dashboard.
Next she cleans the chip edges and puts a vacuum cup on it. This draws out any moisture. Notice the vertical strip she put on the windscreen. That is a thermometer. Is shows the temperature of the window, which needs to be within a certain band width for the repair to be effective
Everything she needs and uses comes in this handy box, including the little compressor.
It takes a few minutes to draw out the moisture and the system gives a ping, indicating you can move onto the next step.
Next another device is fitted to the windscreen. It is held in place with vacuum, but it also uses pressure to push special repair gel into the crack/chip.
Here you see this device from the bottom. The large hole is for drawing the vacuum. The small hole is where the repair gel will exit from and is positioned right smack in the centre of the chip area.
Here you see Pascal getting it in place. She uses the mirror on the dashboard to check the exact position.
It takes 7 minutes for the repair gel to be injected in 7 steps. You can actually see it in the mirror. It was quite fascinating because I just saw the cracks sort of disappear as the gel was pushed in.
Then Pascal get an UV lamp to harden the gel.
Here she is positioning the UV lamp
Takes a couple of minutes to harden. Again the machine will bleep at you when it is done!
Last step, Pascal uses a knife to scrape away any excess repair gel
A quick polish and cleaning of all the windows of the car and we’re ready to go. All in under 30 minutes. No paperwork. Just my signature on an electronic device that the work has been carried out satisfactorily.
As it so happens, Pascal was quite interested in my Jaguar. She has a 1972 VW Beetle. She loved the Jaguar, but did notice that the interior, especially the driver seat really needs some work.
When we were still in Kansas City, USA, I had the leather of both front seat repainted by ColorGlo. They did a really good job but that is almost ten years ago.
So I had been looking for somebody who could redo them. Colorglo went bust here in the Netherlands some years ago. You can still buy their products for DIY work, but they don’t do services anymore.
As luck would have it; Pascal’s partner, Joost, used to work for Colorglo. When they went bankrupt he started for himself and is very successful. Pascal showed me some of his work on his website. I gave him a call right away and he is coming round this weekend to look at the Jaguar. I will let him have a look at the dashboard of the Spider too. That has some typical sun/heat damage and apparently he can repair that too.
So all in all, a very good and productive/constructive visit to my local CarGlass.
Next, cleaning, waxing the Spider for our tour de France!
Jeroen
