Old 2nd April 2023, 14:19   #16
arjithin's Avatar
Thanked: 2,551 Times
Re: DIY - Automatic Transmission Fluid Change
Your method of several flushes is a tried and tested method. The only thing is, it will never remove the dirt and grime that has really got stuck. Therefor it is advisable to really get a proper flush done of a gearbox. But it require a special flush machine, cleaning fluids and somebody who knows what they are doing.
Jeroen
I would have spent 25% of the value of car just to get a flush done from a mechanic.
Agree with all your comments, but I have taken the decision not to open the sump to reduce complexity. Now that I have done it once & if I plan to do it in 2 years time, I will certainly open the sump and change the filter. I saw the existing fluid to be in very good condition on first drain, and that gave the confidence just to change the ATF and leave rest as it is.
arjithin is offline
