Old 19th July 2021, 19:42   #1
Indian2003's Avatar
Thanked: 3,669 Times
Using the Bochum Plug for draining engine oil
Today I changed the engine oil without use of any tools for the drain plug. I have the Bochum plug installed.
The original 24 mm plug is very difficult to remove. I have only unscrewed the plug twice with a 3/4 inch breaker bar. Since then I have used a vacuum pump to drain oil. No more with this plug.
The plug is used instead of the original oil drain screw. To drain the oil, the cap is removed and a hose nozzle screwed on releasing a spring loaded stop valve.
The valve of the plug opens and the engine oil can be collected in a controlled manner.
These plugs are commonly used on construction machines.
The knurled cap is on
The cap unscrewed
The valve from inside the sump
The valve when the nozzle is screwed on
Draining the oil
Indian2003 is offline   (22) Thanks
Old 22nd July 2021, 11:29   #2
PraNeel's Avatar
Thanked: 2,010 Times
Re: Using the Bochum Plug for draining engine oil
Good addition, for DIY guys. Can you also share the procurement source? Thanks
PraNeel is offline   (1) Thanks
Old 22nd July 2021, 12:44   #3
Indian2003's Avatar
Mine is the Bochum valve that I got off ebay Germany.
https://skarke.de/en/products/oil-service-valves/
Here is the EZ Oil Drain Valve that can be bought in India. Amazon in some countries sell these.
https://ezoildrainvalve.com/index.html
Indian2003 is offline   (2) Thanks
