Old 11th July 2019, 11:13   #1
Hatari's Avatar
Thanked: 926 Times
How to connect 2 headphones to a TV/amp?
Need a little tech help.
With my daughter sleeping in the room, and being unable to run the home theatre, my wife and I have been using 2 Infrared Philips headphones at night while watching TV. Though sound quality is average, a lag free experience made do.
Now the headsets are giving trouble and replacements are not available.
How does one get a lag free (lots of bluetooth headsets are reported to be laggy when split etc) experience while connecting 2 headphones simultaneously?
Hatari is offline
Old 11th July 2019, 11:46   #2
Thanked: 350 Times
I recall making the Bose Soundsport free and QC35 work without any issues with same sound source .The feature is called Music Share .
Trust_In_Thrust is offline
Old 11th July 2019, 15:13   #3
Hatari's Avatar
Thanked: 926 Times
re: How to connect 2 headphones to a TV/amp?
Ok.
Can you please share details or hardware/software involved.
Hatari is offline
Old 11th July 2019, 16:47   #4
Thanked: 350 Times
Bose does it out of the box with no additional hardware or software .
Old 11th July 2019, 17:31   #5
Rehaan's Avatar
Thanked: 36,126 Times
Are you looking only for a wireless option? Or is wired okay as well?
Do you have your own bluetooth headphones already?
I don't know about lag-free when connecting TWO headphones.
But APT-X LL (low latency) are designed for these uses.
I bought this recently (for a different use - as a reciever) but it might work for you :
https://www.aliexpress.com/item/3295...1dba4c4d5Jfm0p
How to connect 2 headphones to a TV/amp?-blucapture.png
See if it supports 2 SIMULTANEOUS output devices.
See if there's any other similar products that do.
Ensure your BT headphones support APTX LL for best low-latency results.
Rehaan is offline
Old 11th July 2019, 20:06   #6
Thanked: 15 Times
I had a similar issue about a year back.
The solution I found:
BT Transmitter / Receiver
I bought a similar device for 1500 and even I was worried about the lag but no such problems.
5hadow is offline
Old 15th July 2019, 10:39   #7
Hatari's Avatar
Thanked: 926 Times
Re: How to connect 2 headphones to a TV/amp?
Do you have your own bluetooth headphones already?[/ATTACH]
The distance to the TV is more than 9ft so wireless only practical solution. I have a 1 to 1 BT adaptor and a headset, it doesnt support 2 to 1.
Shall explore the one mentioned, thanks
Hatari is offline
