Old 9th May 2008, 20:55   #1
Virtualization Capable Workstation
Hey Folks,
I am looking to build a workstation for running VMware & other Virtualization technologies with commodity hardware as I can't afford the expensive Dell / IBM wares. I need to simultaneously run more than 4-6 VMs and hence the requirement.
Currently I am considering the following configuration.
Processor - Q 6600/6700 or Q9450 (Adv. - 12 MB L2 cache) (Can they be used as dual processor as in MP)
RAM - 4 GB (G-Skill / OCZ / Corsair Performance Chips)
Mobo- Need help on this one. Not sure about GigaByte / Asus / Tyan.
Storage - Can SATA2 do the job for me or I need to go for SAS?
Power Supply - ??
I am not looking to use this for gaming much. I am also considering booting it with RAID-0 with an option to boot from LAN using iSCSI with another comp working as storage server and taking off the I/O overhead off the server leaving it for pure processing job.
I will be keeping all my imp. data separate on USB and other hard drives just so VMs don't mess up.
I am sure I am leaving out many imp. details. Please keep them coming as I need to start building it soon.
given2fly is offline
Old 9th May 2008, 21:24   #2
condor's Avatar
Thanked: 16,893 Times
Check VMWare's website for recommended configs. Size your desktop based on their recommendations.
Check if memory allocated to each instance is shared or exclusive. Diskspace reqd will be cumulative of space allocated to each instance.
condor is online now
Old 9th May 2008, 23:37   #3
aaggoswami's Avatar
Thanked: 3,000 Times
I can help a bit.
The following is the configuration I would suggest.
Processor : Intel Core 2 Quad Q6700 11,000
Motherboard: (1) ASUS P5N32-E SLI 12,800
(2) XFX Nvidia 680i LT SLI 10,200
RAM : G-Skill F2-6400CL4D - 1GB*4 DDR2 -800 7,000
Hard Disk: 2X W.D. Caviar RE2, 500GB in RAID 0 14,400
Graphics card:(1) MSI 8800GT OC Version 13,000
(2) MSI 8800GT OC Version 2 * 26,000
(3) Zotac GeForce 9800 GTX Amp Edition 25,000
Before venturing for ASUS remember that it has got the worst RMA and is not recomemded. XFX is preferrable and it has very low problem rate.
Regarding the power supply, 1200W is what is preferrable for you and go for cooler master. Sorry, I dont the price of this.
aaggoswami is offline
Old 10th May 2008, 00:21   #4
tsk1979's Avatar
Thanked: 23,489 Times
If possible use separate HDDs for your different Virtual OSs. On my AMD 64 system if I ran 2 virtual OSs(One Slackware and another Gentoo) it would thrash like crazy. Maybe more ran(I had 1GB) could have taken care of the problem, but from the logs etc., I could make out that 3 OSs(1 real 2 virtual) accessing the same HDD is not really a good idea.
If you are okay with a huge motherboard, go for a dual processor unit and use 2 quad cores.
tsk1979 is offline
Old 10th May 2008, 01:16   #5
reignofchaos's Avatar
Thanked: 2,527 Times
The thread creator mentioned no gaming so there's no need for such an expensive video card. Nor is there need for SLI. Trust me on this the 680i chipset is nothing but trouble. I have one and the number of times I've had to reset it and discharge caps for boot failure, i've lost count. Absolutely not worth it. Any X38/X48/P35 boards is a much much better option.
reignofchaos is offline
Old 10th May 2008, 09:27   #6
aaggoswami's Avatar
Yes, my mistake.
The Details about TYan
S5393
Tyan* S5393 Motherboard
More details avaliable here.
::Tyan Computer Corporation:: System Boards detail
S5396
Tyan* S5396 Workstation Board
The following are motherboards from Intel.
DP35DP with P35 chipset and ATX form factor.
DX38BT with X38 chipset and ATX form factor.
DX48BT2 with X48 chipset and ATX form factor.
If you are using tyan, then Xeon processor should be used.
Also consider X38 Platinum and X38 Diamond from MSI:
X38 Platinum:
MSI -- MICRO-STAR INT'L CO., LTD.
X38 Diamond:
Old 10th May 2008, 10:47   #7
Amey's Avatar
Thanked: 253 Times
Originally Posted by given2fly View Post
Hey Folks,
Power Supply - ??
Processor - Q 6600/6700 or Q9450 (Adv. - 12 MB L2 cache) (Can they be used as dual processor as in MP) ---> go for Q9450
RAM - 4 GB (G-Skill / OCZ / Corsair Performance Chips)-----> Good 4GB kits will be slightly expensive.You should get a VFM kit rated at 800 CL5 from Corsair,Gskill etc. Corsair 2GB x 2 C5DHX DDR2 800 is going for around 5.9K
Mobo- Need help on this one. Not sure about GigaByte / Asus / Tyan.-----> Gigabyte boards solid and reliable.Asus is also good.
If you do not wish to overclock, you may want to consider Intel Original boards based on X38/X48 chipset.I would prefer sticking to Intel chipset,taking into consideration your application.
Models - Asus Maximus Formula - 14k, Gigabyte X38 DS5 - 13K, Abit IX38 QuadGT - 12k, Intel DX38BT - no idea.Abit is a good board, have had opportunity to get hands on experience with it.
Storage - Can SATA2 do the job for me or I need to go for SAS? ----> SATA 2 is pretty fast.I seriously dont have much idea about Storage requirements in Professional setup.You are in a better position to decide on that.
Power Supply - Seventeam 700-800W PSU will suffice and should cost ~7-8k
You can also contemplate Corsair TX750 for 7.5k or Even Corsair HX620 for 6.5k
I hope this helps you in making your decision.
Amey is offline
Old 10th May 2008, 10:48   #8
sfilinto's Avatar
Interesting Thread. I work on Microsoft virtualization technologies and will add my 0.2
Yes I believe you can build a system which works better (faster) then the expensive branded hardware.
Consider the following points when choosing hardware.
1) Disk
The Disk is one of the biggest bottle necks when it comes to performance hence choose the fastest possible disk, and split the IOPS across physical disks. Choose the fastest interface you can afford.
(SATA, SCSI, SAS, PATA, iSCSI, IDE, USB)
(USB is pretty slow but not very far behind.) - Personally I use USB on my laptop where I cannot use the others.
Keeping the VHD files remote & connecting to them via iSCSI is also a fantastic idea.
2) CPU
Ensure the Cpu is capable of Intel VT (or AMD-v) - These are 17 instructions which will give you hardware assisted virtualization capability.
I would also suggest you buy a CPU which can run x64. That way you can use Microsoft’s Hyper-v due for release shortly. (I use the Beta version on Hyper-v & it performs great)
3) Memory
Choose the fastest & the as much as possible.
4) Display Card
Be Careful here. You do not need any fancy display card because the hardware is emulated. (Whatever physical hardware you choose the hardware inside the guest will be the same – S3Trio)
The risk of using a powerful display card is that the driver could eat up precious kernel memory thus causing a performance hit. (In fact I never recommend using anything other than a simple svga display driver on a server)
HTH & do remember to optimize the OS for virtualization after you have setup the OS.
sfilinto is offline
Old 12th May 2008, 19:43   #9
Dude Ritesh here.
First thing:
Decide how much u can invest on the processor speed.
so the best proc can be a quad core if u need.
Memory is 8 GB nothing less as you already know that the VMs u use face claustrophobia.
For the IO:
option 1: Invest in a lean 1 gb memory system seperately if you have one lying around with a sata 2.0 card. Insert about 2 or 3 drives in a raid.
That is the Iscsi : Built from openfiler,Open-E iSCSI SAN.
Option2: Use a 3 disk sata on raid 0. for best IO. always prefer a hw based SAS card for optimal results, as cache matters.I suggest using a PATA for the base os as most OS' will work on it.
Oh don't use viridan it sucks (dont flame me on this) i have used it since beta. I have a few better options for virtualization. Anyone who needs it can send me an note on this. I suggest Parallels or virtualbox . These are lighter and work great.
Ritesh Nair is offline
Old 14th May 2008, 22:18   #10
sfilinto's Avatar
Originally Posted by Ritesh Nair View Post
Dude Ritesh here.
this would depend on what amount of RAM the Guests are configured with.
i run a machine with 4GB ram and its more then sufficient.
Dude Ritesh here.
Everybody has the right to express his opinion so i am not gonna flame you.
but do you mind explaining why you say viridian sucks ?
and i have heard of virtualbox but where the hell will i get it from ? also whats the support scene for this ? what does it cost ?
sfilinto is offline
Old 15th May 2008, 17:35   #11
More Details
Been doing some searching. Considering the situation that I am going to run most of the MS Server products inside those VMs with a 64 bit host OS, I will go with any reasonably fast memory. I think I need not go for those with least latency ratings as they are mainly meant for Gaming folks. Right? Correct me if I am wrong. Also suggest which RAM is going to be good. I am too confused looking at the ratings out on the web.
Regarding processor, I am kind of drifting more toward Q6600 ($ 210- about Rs. 8500)unless someone can point out any distinct benefit of going with Q9450 ($380+). Check the following (Though mostly gaming performance which is not my primary concern but stability).
Intel Core 2 Quad Q9450 Review » Page 16 - Conclusion: - Overclockers Club
Intel 45nm 2.66ghz Quad-core Processor Tested - OverclockersClub Forums
What to choose between WD Caviar & Seagate Barrauda? Even there, Seagate has 2 options; 7200.11 (For Performance) & ES series (For Reliability)? Which one do you suggest. How about the boot/system partition on a faster drive and keeping the data on a RAID 0 made of something like Barracuda ES / WD Caviar.
Seagate's Barracuda ES hard drive - The Tech Report - Page 1
One funny thing I came across was no shop in Vashi (New Bombay) was stocking Seagate. They say that WD has a better onsite support (Is that RMA?) and that is why they prefer selling WD by majority.
Also, do we get any Dual-Processor board for C2D or C2Q? Just curious if there is any MP possible with these components.
Old 16th May 2008, 09:13   #12
aaggoswami's Avatar
RAM : G-Skill F2-6400CL4D - 1GB*4 DDR2 -800 will cost around 7,000 and will be stable.
Q6600 is built on 65nm technology and Q9450 is built on 45nm technology. Its good to invest in Q945, and it will also perform better than Q6600. Any intel processor with Q6XXX series will be 65nm and Q9XXX will be 45nm.
Similarly, E6XXX is 65nm and E8XXX is 45nm core 2 duo.
45nm have performed better than 65nm processors. Q9450 is good deal but the cost increase is way too much against Q6600. Nevertheless, if you are able to afford Q9450, then go for it. You are future proofing your self.
Seagate has one of the best RMA, but for your function needs, WD will serve better. The percentage of Defective HDD are very less as compared to Seagate. I again feel that W.D. Caviar RE2, 500GB *2 in RAID 0 (you need this ) is good option.
Regarding dual processor board,
Intel D5400XS is one option.
Here is the link:
Intel® Desktop Board D5400XS Overview
Old 16th May 2008, 12:35   #13
NetfreakBombay's Avatar
Thanked: 1,130 Times
Good to see another Slackware user
Coming back to topic:
I run 3 VMs all the time on Windows XP host. This is for development/tweaking/safety and not for professional usage. Performance is satisfactory so far.
For a budget of 70k, I'll build this system:
Advantages:
1. 2.6 GHz CPU with 6 MB cache.
2. 8 GB RAM (Cab be used for SWAP by VMs through memory mapped files)
3. 4 HDDs so that :
a. Either each VM gets its own HDD
b. With RAID 0, and two pairs of HDDs; two VMs share HDD
This config should take care of bottlenecks caused by HDD, and should be stable.
NetfreakBombay is offline
Old 16th May 2008, 12:49   #14
Thanked: 77 Times
If you need only software virtualization, you can go for something called VirtualBox. I am using this product on my Laptop and my configuration is something like this:
On one partition, I have Windows. I boot through Windows only for my iPhone synchronization with itunes. Other than that, I practically have no use of Windows.
On the other partition, I have Solaris with a network virtualization software called Crossbow installed. My idea is to replicate my lab on the laptop. So, I used VirtualBox to install three virtual machines (two Solaris machines and one Linux machine). I have created a virtual network out there and all the three VMs can communicate with each other. I have used a separate disk space which I have exported as an iSCSI target to all these VMs. They share this "disk". Since I work with such a configuration very often, I need not look for lab machines to test my code changes.
EDIT: VirtualBox is available for Solaris, Windows and MAC.
deepakhon is offline
Old 16th May 2008, 12:50   #15
Thanked: 70 Times
I just noticed that given2fly wants to run 4 to 6 VMs simultaneously. Like several others have mentioned, buy several HDDs to avoid the bottlenecks there. Also, the thumb rule that I would follow is to have 2GB RAM per VM so if you are planning to run high loads so I would recommend a minimum of 8GB RAM. Go higher if you can afford it.
hondadude is offline
