Remember the clanking sounds of your Maruti 800/Zen at around 30000km when you turned a corner? That was the Grim Reaper knocking on your door to claim the souls of your drive shafts. Lately, most driveshafts are built for a much longer time. My previous cars - Honda,, Skoda, Swift all crossed 60000 km with nary a clank so you would not expect anything from a tough Jetta?
Well, it has happened, read on..
Last month, my friendly dentist referred his patient to me over problems with his VW Jetta. I had a quick conversation with him and asked him to email me with the history.
In his words:
1. The vehicle is the Jetta diesel AT, purchased from VW palace cross in Nov 2012- 2 years warranty.
2. Nov 12 To end Jan/ early Feb 2013,- I had clocked between 2-3,000 kms. I had by this time experienced a occasional shuddering/ vibration from the front wheels/ drive shaft (??) at speeds of 120 kmph and above. This shuddering/ vibration would come and go, sometimes making me wonder if it was the road quality. I managed to establish it going over the same patch of road many times and experiencing the shuddering/ vibration occasionally, not every time. Also, noticed a metallic rubbing noise from front wheels.
3. End Jan/ early Feb- visited VW Palace cross Rajajinagar VW workshop with above info to investigate physically and by test drive. No conclusive answer.
4. Approx. Mar/ Apr 13 - visited VW apple workshop in Whitefield with the above concerns. Investigation led to the finding that boot drive assembly clips on both front wheels were missing and in their place are plastic tie wraps that electricians use to tie electric cables together. I had left the vehicle at the workshop and gone for some work, so did not see this physically. There might have been traces of lubrication leaks from the unit which they must have cleaned out.
5. Subsequently, many visits, not all recorded or with job card history, plus email correspondence highlighting the concerns took place till date.
6. Currently, lot of metal against metal sounds when turning the vehicle either side and front wheel noises have increased and are now obvious.
They had offered to replace the boot assembly and clips but I refused to accept unless they could prove to me that no metal fatigue/ damage due to shearing/ stress forces have not occurred and why. They have not been able to put that in writing and give me.
He has written to VW - both India and Germany who advised him to take it in to dealer to resolve, which has not been done. The dealer doe not seem to have engaged VW to look into this.
Basically, the damage has been done, no amount of circlips will rescue the situation and the car needs new driveshafts. The owner wanted me to keep the car for a couple of days and verify.
I suggested he checked the wheel balancing etc which was done. The owner also complained of noises and clonks under hard braking.
Today we met and as we pulled out of InOrbit mall, the clanking started as soon as the car turned up the ramp.From the driver's seat you could hear the bearings groaning (like an old Ambassador Taxi). I did not get any strange clonks under braking, it might occur under extended use
We then took it to the area outside the KPTO Convention Centre and I drove some tight circles around in both directions. Man, it sounds really bad
It was time to look at the damage
Even with the wheels steered back, it is difficult to see the driveshaft but if one pokes a hand with a phone camera in, you see a lot. You also get a lot as when I poked my hand in, I got plenty of grease on my hand (those driveshafts are sealed remember and as much grease comes out as grit gets in!!). So lets look at the pictures
The driveshafts on both sides
As you can observe
1:There are no clips attaching the boot to the shaft, grease has seeped out, the shaft is encrusted with mud + grease.
2: The boots are intact and did not seem torn hence no damage for use
3: There is not reason to remove the boots at any service as these are sealed for life.
Note the Jetta has done short of 22000km and is immaculately maintained.
Am sure any hapless owner would be told, "They all look like that!" So, what is the ideal way to calibrate that this is not the ideal state? Find a similar car with similar miles. I knew one car which was 6 months older and done almost the same number of kilometers - mine!
Since I could not take pictures in the office basement, drove to Bangalore Club to meet the school bus. While waiting, I reached with my phone into the wheel arch.
See the difference - the shaft is relatively spotless, no greasy bits evidence and note the presence of the circlip.
It looks like someone goofed up on the driveshaft assembly and forgot the circlips. Putting them on as an afterthought will not work and a very shameful thing for the dealer to suggest since the damage has been set in motion once the abrasive grit etc has entered the drive joints. Replacement is the only answer.
As the car is under warranty, I have advised the owner to take it back to the dealer and insist on driveshaft replacements to resolve this as soon as possible before the warranty expires.
Summary - Driveshafts assembled without circlips
- Grit/ abrasive material enters driveshaft joints and begins to hasten wear
- Dealer refuses to stem the advance wear happening and suggested fitting circlips despite the abrasion continuing.
It was a shame that VW Palace Cross have not sorted this out since I normally get outstanding service from them
