Hi BHPians,
This is a review of my Diamond White 1.4TDCi Titanium Ford Figo which I purchased on 11th March, 2011. I will try to keep things short and sweet
Purchase:
Back in 2011 I was stuck between the SWIFT VDI ABS and Figo Titanium. Better put the fight was between and
awesome engine + proven reliability combo and an
awesome chassis + steering feel + features combo. In the end I decided that a car is more than just the engine and the brand.
Fast Forwad to September, 2012:
In around 1.5 years, I covered 20k+ kms. I have travelled to almost all kinds of roads kerala could offer. In addition to this travelled to Chennai and Pondy too.
Things I Love:
1.
The best steering in a hatch (Probably Punto's steering is slightly better): Had a blast while negotiating the curves on the way to Munnar topstation. Two-finger direction changes can be done all day long. The feedback is to die for.
2.
Sublime handling: Throw the car into a corner and forget it. The car sorts out the rest. Again Munnar drive and the Athirappilly waterfall drive comes to mind. The car tracks like its on rails. Understeer? What Understeer?
3.
City driveability: Negligible turbo lag and relatively light clutch means city drives are a breeze (for a diesel). The low turning radius is a boon.
4.
Ride: Maybe Punto has a better ride and handling combo but the Figo is not far behind. The low speed ride is a bit harsh but high speed ride even on slightly uneven surface is F-L-A-T. Was a joy to ride to Chennai and Pondy through the superb Tamil Nadu highway network.
5.
Maintenance and Service costs: Whoever said "Fords are difficult to afFORD". Not anymore, with the Figo atleast. Other than service cost I haven't incurred a single Rupee. To elaborate, my 20k km service cost me around
Rs. 4600!! (inclusive of wheel alignment, balancing and rotation which I did at another place). That is cheap by any standard. Touchwood!
6.
Features & Space: The standard safety features like ABS, EBD, Airbags etc. provide immense confidence. ABS has cut in quite a few times especially during heavy braking in the rains. Space - leg space and seating space- is decent for 5 and has one of the largest luggage bay in this segment. The Bluetooth enabled stereo is very very useful.
7.
Fuel economy: The new diesel engines especially in SWIFT and MICRA scores here, but the Figo holds its own here too. It has an older engine and a hydraulic power steering which eats into the fuel economy. Still I get 15-16kmpl with Full A/C in city and 20kmpl on highway runs with Full A/C.
8.
A/C : One of the best units I have come accross. Rapid cooling guaranteed.
9.
Rattle-free build quality: The car is built well and weighs more due to that. Probably one of the reason why the lesser powered Micra is a bit more responsive. No rattles at all after 20k kms. Ok, if I was nit-picking, yes some squeaks come and go automatically!
Things I Loathe:
1.
Low speed ride: Owing to the stiff suspension, low speed ride is jittery over uneven surfaces. I understand that the benefits come in during high speed drives, but even then sometimes this gets on my nerves.
2.
Headlamps: Headlamps are just not powerfull enough. Moving on to a higher wattage means losing warranty. I feel i'm stuck here. Fog lamps are a necessity.
3.
Feel underpowered at times: With 5 on-board highway overtaking needs to be carefully planned. SWIFT scores big time here. I have taken the Figo to a top speed of 150kmph(True speed with GPS, speedo showed around 160kmph) on the L&T highway near coimbatore. 120kmph to 150kmph takes a while. With partial load though, in-gear accelaration is more than enough.
4.
Comparatively Hard steering at low speeds: Again I understand that this is a hydraulic unit and the benefits are to be reaped at higher speeds and curves, but steering could have been a bit lighter at lower speeds.
5.
Refinement Levels: You can hear the unmistakable diesel clatter during idling and hard acceleration. Ford should have provided more firewall insulation.
So there you go. This sums up my experiences. Following my advice, 6 of my mates bought the Figo and they are still my friends
In a nutshell, I am one extremely satisfied customer! And yes, a car is much more than its engine alone.
Happy driving!
