@N_C, I didn't get this. Why did you need to change the whole fuse box?
Shuvc,
The fuses blowing happened thrice. And the fuses broke/melted into pieces inside their slots. I had removed the pieces with a screw driver which made the slots a bit wider. Also I was not sure whether smaller pieces of the fuse had been removed completely from inside the slots. And since it had happened 3 times - I thought - "Better to be safe than sorry"
Originally Posted by normally_crazy
(Post 852151)
Shuvc,
The fuses blowing happened thrice. And the fuses broke/melted into pieces inside their slots. I had removed the pieces with a screw driver which made the slots a bit wider. Also I was not sure whether smaller pieces of the fuse had been removed completely from inside the slots. And since it had happened 3 times - I thought - "Better to be safe than sorry" |
I normally Crazy,
I have had the sma ething done to my 1.8Tpi twice already and its a pain when it happens, it happened to me once in the middle of the nite after partying!! and had to call skoda 24 hr service to drop me off home. Which they promptly did.
Any clue as to why this happens? They changed the main Battery wiring also and after that it hasn't caused me a problem so far, I have also changed my battery to theTDI's battery which has a higher capacity then the petrol.
Anyway now I havent faced the problem in sometime, but my fingers are crossed.
Happy riding...
Ok - so just changed the air filter to the stock replacement K&N one (thanks to MM). I have to reset the ECU, right ? (disconnect the battery terminals for 20 mins and plug it back in ?)
EDIT - Reset done yesterday evening and immediately there is a noticable difference in the way the car responds to the foot. Seems eager to get on with it. I might be wrong but I feel it revs a bit more freely too. (maybe my OE filter was choked :D)
N_C any update on the timing belt,did you manage to get it changed ?
(Post 446151)
Below I am listing the service bill -
Misc - 300 includes cooloant - power steering fluid - windshield wash concentrate
.[/b] |
Sorry to bring up such an old thread, but I was reading through your service bills, the Skoda dealer in Kolkata-JIA AUTO charged me Rs.600 +VAT to top up the coolant!!!
Since your dealer charged only 300 that too with the other stuff, does it mean that the Kolkata dealer has not been totally honest?
It seems to be an epidemic. My take is that water gets in and creates these issues. Have sprayed WD 40 all over mine.
Just a small update
The timing belt was changed at 61000 kms and that completely solved the irritating noise.
The odo now reads 68000 kms.
A new battery has been installed - Exide (I know I know :D)
A new set of tyres have been installed - Bridgestone Turanzas AR10 - 5500 / tyre (grey market). Lovely tyres, comfortable and very silent.
The interiors need an urgent shampooing, vaccuming and cleaning. Going to the Car-Spa tomorrow.
I think the suspension bushes might need replacement and a power steering might have a small leak - going to get it checked in the next 10 days, other than that - all great.
The 2 Car runs just fine. no issues.
Wooh! U do drive a lot.. 68k kms.
How many kms do u drive in a day?
(Post 1121444)
A new set of tyres have been installed - Bridgestone Turanzas AR10 - 5500 / tyre (grey market). Lovely tyres, comfortable and very silent. |
Congrats Normally Kanjoos :p
(Post 1121444)
What about carpets?;)
Originally Posted by kpzen
(Post 1121481)
How many kms do u drive in a day? |
Atleast 70 in a day.
Should be normally_sindhi :D
Yes - I forgot - new carpets too - thank you KPGenerous :D
Finally you bought the tyres. Post a review after driving around for a while.
Also is the timing belt change interval at 60,000kms?
(Post 857671)
Ok - so just changed the air filter to the stock replacement K&N one (thanks to MM). I have to reset the ECU, right ? (disconnect the battery terminals for 20 mins and plug it back in ?) EDIT - Reset done yesterday evening and immediately there is a noticable difference in the way the car responds to the foot. Seems eager to get on with it. I might be wrong but I feel it revs a bit more freely too. (maybe my OE filter was choked :D) |
please help me understand this , do you need to reset the ecu when you change to a stock replacement free flow filter?
Siddharth,
Yes you do need re-set the ECU. The reason being - the values from the MAF sensor stored on the ECU get erased and when you start driving after the re-set, the ECU picks up the new values due to the filter change.
If you do not re-set the ECU, the old values from the MAF sensor are stored on the ECU and you do not immediately feel a difference in the way the car moves and feels. Over a period of time the values get re-written but re-setting the ECU means you can feel the change immediately.
Hope that clears things. :)
(Post 1121653)
Siddharth,
Hope that clears things. :) |
thanks , will keep that in mind.
just went through the entire thread and i must say it has been quite an experience for you. Myself planning to pick up an RS in sometime, so just preparing myself on that. Thanks for sharing all your info.
