Old 19th December 2023, 17:39   #31
condor's Avatar
Thanked: 16,903 Times
Re: Ten years and 120,000+ kms with a Tata Vista D90 | Ownership Review
Brochure is up for grabs - a DM with postal address required. Who ever takes it, please keep it
Old 26th August 2024, 13:11   #32
Thanked: 7 Times
Dear Sir
Your thread as an owner of a 2009 Vista Aqua Tdi gives me great joy
I have a few questions
1. I’ve done 140000 k, were you ever advised to go in for piston change?
2. Did you have turbo issues? I’ve had mine serviced but seems underpowered still
3. Did you have fuel pump issues? I’ve had that serviced as well, but the engine goes off easily after a drive , along with dark smoke when it restarts
tdcarlover is offline   (1) Thanks
Old 27th August 2024, 17:28   #33
Neversaygbye's Avatar
Thanked: 2,121 Times
Originally Posted by tdcarlover View Post
Dear Sir
Hello sir, the answer to all your questions is in the negative. No work of any sort has been done on the piston, turbo or fuel pump. The only work I got done was EGR cleaning to remove the soot deposited over 120k kms. Plus of course changing the timing chain, belt and mounts. Everything else is still stock. I suppose this being the Fiat Quadrajet engine, it requires less maintenance than Tata's own TDI engine. I would suggest that you try taking your car to a different service centre or even a FNG to check out the issues you have mentioned. My experience with TASC is that some of them are better than others.
Neversaygbye is offline
Old 1st September 2024, 08:45   #34
Thanked: 7 Times
Thank you for your support
Much appreciated
