Team-BHP > Motorbikes
Old 7th August 2018, 13:15   #826
Thanked: 2,231 Times
re: The Royal Enfield Himalayan thread!
Originally Posted by bblost View Post
Repeating again:
Please share pictures and where you got them from.
Sharing mine, if you dont mind .
rakesh_r is offline   (2) Thanks
Old 28th August 2018, 00:45   #827
Ketan's Avatar
Thanked: 354 Times
Repeating again:
I shall add the one showing close-up soon, currently travelling so see these are the ones that I have with me right now.
Ketan is offline   (2) Thanks
Old 28th August 2018, 10:25   #828
bblost's Avatar
Thanked: 13,336 Times
Thanks Guys.
I have almost solved my issue with the seat.
  • The lowered angle of the handlebar.
  • The new seat cover.
  • A rider friend recommended I get some tight fitting underwear. . It works.
  • I am used to riding in a perfectly straight line. Now every few kilometers I simply zig zag the bike a little.
The Fego Float is currently being used by a friend of mine. He has Spondylosis and uses a scooter. He may end up buying it from me.
bblost is offline   (2) Thanks
Old 28th August 2018, 10:44   #829
CrAzY dRiVeR's Avatar
Thanked: 67,807 Times
A good review from overseas, this time from MotoGeo -
CrAzY dRiVeR is offline   (3) Thanks
Old 28th August 2018, 14:02   #830
satishv1987's Avatar
Thanked: 339 Times
Has anyone faced issues with steering ? 10 days ago, the bike started drifting slightly towards the right. It became very pronounced over the last couple of days. Balancing the bike in peak Bangalore traffic was quite hard. I thought it could be a bent fork. I went to Mehboob garage (nandidurg road) & the lead mechanic said that a worn out ball bearing in the steering rack could be the culprit.The bike is currently at the workshop. Since it is less than a year old (5000 kms), I am covered under the warranty.
Last edited by satishv1987 : 28th August 2018 at 14:03. Reason: Incomplete sentence
satishv1987 is offline
Old 2nd September 2018, 12:01   #831
Thanked: 120 Times
Some Himalayans faced 'T-stem' rusting due to the water seeping in through the gaps in the T-stem bolt. This caused problems with handling - similar to what you have described. You can get it checked once.
sdubey23 is online now   (4) Thanks
Old 8th September 2018, 11:27   #832
Thanked: 339 Times
The mechanics at both Mehboob Garage and Technik motors (Indiranagar) said I could continue using the bike for the time being without any major issues. According to the SA, getting the T stem bolt replaced under warranty is a big ask as RE uses every tactic possible to avoid a free replacement and will approve one only if it is absolutely unavoidable.
Is it ok to ride the bike with a faulty bolt in the T stem? I face issues only at lower speeds in traffic. At highway speeds, the bike weighs up and handling is not really an issue.
Old 8th September 2018, 14:42   #833
Thanked: 19 Times
This is quite concerning to be honest. A faulty part is either fully faulty or not. Saying it's ok to use it for the time being is only brushing away the responsibility IMO. With each passing day, the warranty period is also reducing so I would recommend that you take it up with them for a replacement.
Not a apples to apples comparison, but I own a VW Polo - other owners will probably also tell you how difficult it is to get parts replaced under warranty. The SAs are generally hesitant, since the replacement parts need to be approved by guys sitting in Germany! Like really?! When I have had issues during the warranty period I always have insisted that they replace the parts and not repair it. We pay a premium for these vehicles for the quality and I would not be willing to compromise on it because of the service centers callousness.
AbhiIyengar is offline   (1) Thanks
Old 8th September 2018, 17:04   #834
bblost's Avatar
How much does this cost?
Ask them to change under warranty. Else social media can be your friendly way to raise a lot of noise.
But if it costs very less maybe just getting the damn thing changed without the hassle is a simple way out.
bblost is offline   (1) Thanks
Old 8th September 2018, 17:36   #835
Urban_Nomad's Avatar
Thanked: 2,377 Times
Its often the case with incorrect choices, they are simple
The part with labour shouldn稚 cost more than a grand. But If the company makes such halla with changing cheap parts, they値l probably throw a full on hissy fit when it comes to changing something not so cheap in future
Speaks volumes about the company. But, I知 guessing this has more to do with a crooked SA than the company policy. I recommend holding them by the scruff of their necks and get the needful done
Urban_Nomad is offline   (2) Thanks
Old 8th September 2018, 18:19   #836
bblost's Avatar
Completely Agree.
My point was more an inquiry into how much time and energy satishv1987 wants to invest in it.
bblost is offline
Old 8th September 2018, 18:56   #837
Thanked: 19 Times
Couldn't agree more. It's time as customers we took a hard stand against what has now become the "norm" at the ASS's to brush off genuine customer issues.
Old 9th September 2018, 08:29   #838
Thanked: 339 Times
The whole T stem unit will have to be changed and the not the faulty ball bearing alone. It will cost around Rs 2500.
Unlike other dealers,Mehboob Garage is quite reliable. The SAs are trustworthy and rarely recommend anything unnecessary. On a number of occasions, they have fixed minor issues for a very nominal charge . So when he tells me that getting the spares under warranty from RE will be a challenge, I know he is not making it up .
As a last ditch attempt,I am planning to check with the dealer from whom I purchased the bike. If he gives me a similar answer, I intend to take it up with RE directly.
satishv1987 is offline   (1) Thanks
Old 9th September 2018, 10:00   #839
Thanked: 317 Times
That sounds right. Don't worry, it's a small job. Get it fixed ASAP though.
anilp is offline   (1) Thanks
Old 9th September 2018, 17:54   #840
Thanked: 120 Times
Yes you can continue to use the bike. But a faulty t-stem could cause the other components like the tyre, bushes, bearings etc. to wear out prematurely. I'm not a qualified mechanic or an automobile expert. Maybe the experts in the forum can comment on this?
Moreover the T-stem rusting is a known issue in the Himalayan (Atleast in the BS3 models) and 90% of the BS3 bikes got a free replacement. Even a circular was issued to all service centers to replace the faulty t-stem and apply the anti-rust primer as well (There's an image somewhere in this thread I think). Don't go by the RE service centre folks advice. They are just ignorant and very good at procrastination. It is YOUR bike and you have to get things done. That's how it works with RE. Take to Twitter, FB and insist on speaking with the TSM (Territory service manager). RE is super concerned about maintaining their reputation on social media. Give them a nice shelling and they will start giving you respect you deserve as a customer. Don't hold back.
sdubey23 is online now   (2) Thanks
Copyright ゥ2000 - 2023, Team-BHP.com
