Re: Electra 350 as someone's first motorcycle? Quote:
Originally Posted by SubodhRage Hi everyone,
Thank you for your suggestions !
I recently took a long test-ride of the Electra 350. It has actually has 30K kms on the ODO. Here were my observations from the ride: - The vibration are subdued till 75kmph after which the Electra vibrates like crazy.
- The suspension is composed and soaks up bumps pretty well
- There is froth collection or something in the fuel tank. The inner walls of the tank appear reddish. This appears really problematic.
- The rear drum brakes are working just fine, but the front disc brake has no feel left. Could be an issue of just the brake pads or something deeper.
- The horn isn't working, but that's just a matter of changing the horns.
- The engine feels amazing. Still pulls like a locomotive, barring the vibrations
While riding the Electra in the traffic, I could easily manage the weight. The main problems for me I think were that - - The cruising speed if below 80kmph. Modifications would have to be made to make it even a 90kmph cruiser.
- The inner walls of the tank were covered in some layer which looks troublesome.
Can anyone tell me if the tank-washing, and subduing the vibrations would be expensive on the pocket ? |
No matter what modifications you do the UCE will not relieve you off vibrations post 80 kmph. The best I can think off is using a semi-synthetic or synthetic grade engine oil, and using the soft cushion handle grips, along with wearing hard soled shoes. Do not go by suggestions of changing the handlebar etc. I really think the stock handlebars are the heaviest, tunes down the vibes to the max extent. You can try the original Thunderbird handle for better seating position, but its a matter of choice and comfort. can suggest you more touring mods depending on your preference.
For the tank you can just get a replacement tank from Karol Bagh to save you of current or future headache. Jeetu at Naiwala is your go to shop.
Btw, I am also from Kharagpur and reside in Noida. PM me for more details. |
