Re: Motorcycle Engine Oil Recommendations Quote:
Originally Posted by Mannvvs A) If synthetic or semi synthetic oils are better then why do some manufacturers recommend mineral oil? |
Semisynthetic 10W40 should do good Quote:
Originally Posted by Mannvvs B) Which is the best engine oil & grade for my motorcycle(State is Punjab, temp. varying from 10°C to 45°C)(Fazer/FZ16 V1)? |
Any 10W40 Semisynth should do good; my personal preference will be Shell or Motul for their technical superiority Quote:
Originally Posted by Mannvvs C) Another question is regarding the quantity of oil to be poured in with & without filter, also, some recommend soaking the filter in oil before replacing it, what are your views? |
Check the owner's manual {or online} where this information will certainly be available. No need to soak.
Whichever oil you use, whichever brand, how much so ever you fill, soak or unsoaked, one foremost task that needs to be ALWAYS done is: Inspect the engine oil level every 750-1000 Km {even lower number for any brand other than Shell/Motul} without fail & TOP UP if required. |
