Re: Royal Enfield 650cc Scrambler spied. Edit: To be called Interceptor Bear 650 Just rode the Bear 650 a couple of hours ago and am still in confusion as to what RE intended to achieve with this bike. Apparently road Scrambler is what the marketing screams, but its a stiff highway bike, which irons out the deficiencies of the Interceptor 650. The observations are from the standpoint of my daily, the 2017 Duke 390 and the experience of all others in the segment from 200 - 650 cc. The test bike had done 371 km and my ride was for 20 km, 40 mins. Looks - the biggest selling point. The wild honey colour was given for the test ride and it looked splendid! Engine - lovely sounding, extremely smooth 648 cc parallel twin. There is noticeable change (for the better) despite the already torquey Inty 650 due to the 4 nm extra. The torque is the main talking point for most REs and this is the case again. From 500 rpm upto 3000, makes traversing through traffic jams a breeze in one gear. Unleashed from 3000 rpm is insanity, coupled with the loud brap and quick get go like a V8 muscle car. Took it to 95 kmph in 4th gear on the Turahalli road and grinning like a monkey end to end. Heating is well managed, but you will need to wear jeans or trousers and boots as any rider should. No vibrations at any point! I felt some on the NX500 after 5500 rpm.
Make no mistake, this is no KTM-like exciting. Many have sold their Interceptors and gone to the Duke or purchased the ADV/Duke alongside it for excitement. In the city, certainly you wont cross the 2nd gear or 3rd gear. Effortless to ride in the city. Gearbox is slick shifting and no false neutrals even once. Clutch is neither here or there in terms of hardness. Adjustable levers would have been welcome. This is the main reason why you will buy this bike for. Yes, me too. The Duke is frustrating sometimes, being totally dead below 2500 rpm. Ergonomics - horrendous. I am 5'8 with riding boots on and the positioning of the handlebar and the gear shifter/foot brake is the biggest pet peeve for me here. You sit comfortably, but the troubles start below the waist. My boots (size 46) wouldnt fit on both and shifting gears was a chore. I had to keep a slant angle to avoid grazing my boots on the engine casing and the levers, resulting in a slight right knee pain. The tiny pegs do not inspire confidence for standup riding as riders who wear XL and above size boots run the risk of slipping on them onto the seat, is very real. The round mirrors are woefully inadequate and show you nothing but a small space next to your arms. Overtakes felt like a Rottweiler on a tight leash due to this. Double take mirrors ordered? Yes!
The handlebar felt too wide, is neither low nor high and your arm will have some tension while riding it which will cause pain, you will need to change to one that is comfortable. This is a bit of a problem to me even on my Duke when on long rides (250 km+), but not at the scale of misery the Bear inflicted on me. The Continental GT with its shorter handlebar, felt far better. I felt relieved when I was back on my Duke. Seat is soft, will require a firmer touring seat option for long distances. Those round switches, especially the high beam and starter need to be discarded and normal ones put in place. The horn switch seems placed rather too much to the left.
In general, in this segment on naked bikes, being at the middle in terms of height (not 5'3 and not 6 foot and above either), has anyone faced this arm pain issue? Please let me know. I find keeping my forearms parallel to the ground ensures a comfortable ride and most stock handlebars do not make the cut. Handling - Coming from a noticeably lighter and extremely nimble motorcycle, the weight is one thing you will notice while changing directions and overtaking if aggressively riding. Ofcourse you wont feel the weight, its reasonably quick and stable on long sweepers. This being a test bike, did not want to push it as it seemed a little hairy to dip and quickly get back to its line. Previous RE owners like the Classic/Meteor 350 or the Himalayan 411 wont even notice this at all. The USD forks really deserve the extra money paid cent percent. No noisedive under heavy braking. Suspension - stiff, but did not observe the head nod on white topped or tar roads like the KTMs (pre 2022). The KTMs are the hallmark for stiffness (apart from supersports but they are not daily commuters). You will need to slow down for potholes and bigger speedbreakers post 30 kmph to save your spine. No longer wallows or bounces like the Inty. Have requested a longer test ride to confirm the head nod. Did some mild trails (read dusty gravel on the dug up left side) and it handled it with aplomb, offroading is not for this bike yet. The second reason you will buy this as an improved Interceptor, not as a scrambler. Adjustability at the front should have been a must. Wheels and tyres - MRF Nylorex 100 and 140 section, resembles the Pirelli Scorpion Trail II, tubeless tyres with spoked wheels. Spoked wheels in 2024? No sir! The MRF Nylorex was grippy on both wet and dry conditions, not sure how it will corner. though I saw signs of wear which is not typical for 371 km. A bit too much for my liking. Brakes - great brakes. I cant believe I am saying this for a RE! The front certainly shed speed quickly for the 314 kg load it carried (I am 98 kg). The Interceptor I had ridden was a little spongy, but that bike had 6500 km on the odo and probably was due for brake pads replacement. The rear is okay, provides stopping but ABS intervenes a lot. Not at all recommended for wet or gravelly surfaces. Use the front! Headlights - Lousy. All show and no go. No two ways about it. Even worse than the candle lights of my ex-Himalayan 411. Just like the stock headlight of almost 80% of vehicles. No night riding for me without Bajas. The tail light looks nice!
Would I plonk my money on this? Probably not at this point. RE has to prove that this is indeed a scrambler that functions as marketed. RE must get feedback from its customers at the dealership level and present this to the engineering team. Accessing long test rides for 30 mins + duration itself is a chore, asking for PAN card, original aadhaar card and what not despite filling a form with the details!
