Re: Which fully synthetic engine oil for Enfield J series engines? Quote:
Originally Posted by 2wheelsvaga How is your experience using fully synthetic engine oil on the RE classic 350 J series engine? I don't have any idea, as per internet API SL 15w50 is used in this bike. Is it correct?
Which brand do you use and why? When it comes to motorcycles, Motul is the best brand
The recommended oil change interval is 6 months, so do you change the oil every 6 months, or much after that interval? Never overshoot recommended interval no matter what diamond studded oil you use. But, if the motorcycle is used very rarely, you can extend at risk
Given that the standard RE oil is already semi-synthetic, I wonder if it's really useful to shift to a fully synthetic oil. If one were going on long tours in the mountains with a full load, but not cruise at more than 90 kmph, would it really make a significant different to engine health if I used fully synthetic? |
Some answers in bold. For the last one, semisynthetic oil should be good enough. If you are looking for the best oil, Motul 300v and 7100 are the best. You can also opt for equivalent Shell or Mobil grades, like Shell Advance Ultra. Quote:
Originally Posted by Jeroen If I were you, I would stick to what the manufacturer recommends. Not what some (anonymous) guys on the Internet, without any research facility's, tells you. |
I agree that manufacturer recommended grades are best (but not the oil brand, I myself suggest the same. However, some factory filled oils, or manufacturer provided motorcycle oils (like Yamalube or Bajaj dtsi 10000 etc.) are too much uncomfortable to ride, especially in the first 20k kms. Moreover, I have never seen anyone riding a pulsar for 10k kilometers on Bajaj 10000 oil, although it is claimed to be usable for this duration.
If I were OP, I would experiment myself and find out which oil suits my riding style the best, which oil has the smoothest gear shifts and which oil is not impacting my budget. But not everyone enjoys experimentation and getting stuck with an uncomfortable oil for few thousand kilometers.
Hence, asking for other rider experiences is an easy fix and a workable (not best) solution to the problem.
