[MY DATSUN’S RESTORATION
Credit to GORDON for editing and reformating
Specifications
Model : Datsun 260 C , 330 Series
Also Known as : Cedric and Gloria
Car type : Large
Body type : Sedan
Production : 1970 to 1979 - Mine is 1973 model
Max Power : 138hp
Engine : OHC 6 cylinder, 2 barrel down draught carb
Cubic Capacity : 2565cc , 2.6 litre – L 26
Manufacture : UK
Colour : Metallic Sky Blue
Dirve : Rear Wheel, Left Hand Drive
Gearbox : 4 Speed Manual
Fuel : Petrol
Doors : 4
Seating Capacity : 6
Owners : 2
Accessories : Limited Slip Diff
Power Windows and Power Steering.
Original Radio with auto tuning in perfect working condition.
A/C – Only High spec models came with Air Conditioning.
Features : A quality 70's Japanese car,
Wonderful piece of Datsun history, you don’t see many of these around these days. Very Reliable, (Starts every time).
(Note :- My Car Started after 5 Years on the third starter.)
Drives well - The 2.6L, Straight Six Engine runs like a charm.
Clean and comfortable car. Interior is good.
Has a lot of character, and a suitable choice for a low rider, has a lot of potential (quite a few of these cars have been modified into lowriders.
Technical Details
Overall Length 4690
Width 1690
Height 1440
Wheel Base 2690
Thread Front 1360
Thread Rear 1360
Weight 1330
Turning Radius 5.5 m
Carb Diphagram Pump
Tank Capacity 70 lit
Lubrication Pressure Feed , Full flow type oil filter,
Gear Pump
Cooling Corrugated fan, Tube Type Radiator, Centrifugal Pump
Cooling water capacity 7 lit
Electric System Battery 12 v 50 ah , Alternator 500w
Ignition System H. T ___(Coil) , Vacuum & Governor Distributor
Clutch Dry Single Disk
Suspension
Front Independent coil spring ,
Double action telescopic shock absorbers, Torsion Bar type Stabilizer
Rear Semi - Eleptic Leaf Spring ,
Brakes Foot Brake - Master cylinder with Vacuum Servo Front Disk Rear Hand Brake - Mechanically operated on rear wheels
Steering Recirculationg Ball Type , Variable gear Ratio 19.0 - 22.5
Tyres 6.95 - 14.4, 175SR 14 Radial Tyres
Body Construction Monococoque
Restoration
My first job was to access what work was required.
The car was lying around unused for around 5 years in our parking lot, abused by the weather & in addition the construction on second floor of our bungalow subjected it to cement which clogged the drains & thus rain water was collected in it, thus rust kicking in. Also quarter of the tires were underground
My Inspiration to restore my “Datsun 260 C” car was the show on Discovery Travel & Living – “Overhaulin”
On January 2nd 2005 I Made my Decision to Restore My car, as it was then I became aware of the huge FanClub of Datsun’s & other Vintage & Classic Cars In USA & UK and all over the world.
January 2nd 2005 – I summoned a crane to pull out the car from it’s “GRAVE”.
Jacked it up & removed all tyres. Took them to a local Puncture removal shop.
Had every thing checked up. Punctures removed, Air filled.
Amazingly even with flat tires for 5 years there was no damage to the Tubes inside. It only cost me 200 rupees for the whole thing. The wheel rims were sandblasted before, and I painted them with rust proof material.
Attached all rims & tires back on ready to roll.
Mechanics - Work could now begin on the mechanics.
The pump delivered fuel but unfortunately not continuously and the brake master cylinder leaked. The set of new rubbers installed. Replaced it with a Gypsy set. All said and done eventually the car was turned over and after a little coaxing of the set-up the engine burst into life at the third starter.
All the brakes were made fully functional along with some minor repairs.
Interior
The interior was complete but rather tatty. The seats were removed first and then the door panels, then the Dash board, A/c, the Flooring Mats, Fuel Tank etc. These were stored away along with all parts bagged and marked
The Fuel Tank
The petrol tank was removed cleaned internally and only then the bottom was treated with flow solder to ensure any minor surface rust had not penetrated through. The tank was then tested for leaks and the sender unit overhauled and tested. All the tank was then treated to primercoat and then 2 coats of black gloss coat applied.
The Exterior
All the Chrome trims, the Badges & the Bumpers were removed. Then the Head lights & the grille, the indicators, the rear lamp assembly,
The nuts and bolts surprisingly undone with the aid of "Plus-Gas". Those that didn't were angle ground off.
The chassis was in good condition considering, only two small sections required cutting out & strengthening
The body was next on the agenda as the body requires lots of work and not too much financial outlay. The Running Board & Boot were the worst.
The running boards were so rotten at the fixing points a good hammer and chisel was all that was required.
After much searching, sending of pictures and quotations, one of my fathers friend Mr. Pawar (with experience at shaping metal & wielding) accepted the challenge as a one off at reasonable cost. I transported the body to his workshop, where we together did the needful.
The rust evident in this area was
Boot
The boot floor was filled with water when I opened it. The spare wheel was completely submerged in water & totally rusted. The whole Boot compartment floor was done in two piece & wielded back
The boot floor is now installed after some minor repairs to the surrounding sheet metal the boot is “OK”. I prefer to use the butt weld oxy technique for this type of repair as there is very little finishing required after welding.
Fortunately the Spare wheel tub was not damaged or else it would have been a very hectic job to be done. Thank God.
Now that the boot tub was basically back to it's correct shape, we started working on the boot lid.
The front left edge of the boot lid was damaged so was the Inside Edge of the Rear lamp assembly.
Mr. Pawar did a great job here. The result was so good that one could hardly recognize that it has been replaced.
The Boot.
Windshields & Windows – All power windows were working fine.
They were removed along with the Front & rear windshield.
On the Left “A” pillar
We decided to fabricate a new section in 2 pieces due to the many folds and curves of the back panel and its attachment. After much hammering and a second attempt the section was ready to be fitted. After cutting out and stitch welding, & checking. Minor adjustments were to be made but the fit was quite good considering and the final welds made.
Floor
On removal of the Flooring We understood the nature of rust on the floor & the running board.
The floor was only rusted at certain flat areas. The rusted parts were carefully removed & new sheet of required size were cut & wielded back on. The floor board was reshaped considering its strength requirements a higher grade steel was used & finalized.
Door Sills
After spending a lot of time and taking lots of dimensions off the old rusted sills & running boards, which was in original shape in certain areas, we made wire mesh for reference in making & shaping new sheet metal. The new steel for running board required quite a lot of bending, rolling, hammering & shaping it to the correct size & shape and then getting the contour correct. However, higher grade metal was used to increase the strength of the guard and prevent flexing. But there are few plastic moldings which should fit on it dint fit properly. So again lower grade metal was used & finalized.
Doors – The doors were rust prone on lower ends. These parts were carefully removed & replaced on all doors as required.
Unfortunately due to other commitments and my “On the Job Training (Hotel Management), little was done between August and October 2004 but I made a start eventually and set to work on some proformas. My first attempt was as they say "a learning experience" but the second go fitted reasonably and I then set to work
Any small rust prone areas inside the cabin were restored to original.
A coat of Hammerite was now applied to the interior walls of the body.
The damage was removed with careful but time consuming panel beating and a new complete set was welded back to the Body. The rusted areas have been cut away and the replacement section trimmed to suit, after checking the fit on the car. After each tack the shrinking that takes place is released using a hammer and dolly so the the area retains most of its shape, it is a slow process but getting it right at this point is critical.
The minor patch work was soon completed. I repaired this using what seems to be the usual method of cutting an 1 1/2 inch hole through the area of the crack and welding in a patch. I used the T.I.G welding process for this.
The Floor, sills & running board, bonnet, boot, the A pillar and boot lid all came out ok, the front guards (wing), has shown up a couple of areas that will improve after some more work before being painted.
Then I started the process of finishing the panels that we have repaired so far, the bodywork is without doubt the most labor intensive part of the restoration so there isn't a lot to show for a lot of work.
Finally, an end to the bodywork!
and the body was now ready for paint removal.
It was decided to use paint stripper rather than sanding due to the health risks. Over a period of one week, the whole main body had been stripped of paint. I now made minor fillings to the small dings and blemishes and then finally sanded the complete lot down with dry wet and dry. The complete areas were then thoroughly cleaned with cellulose thinners and I was ready to spray.
It was decided to spray an Duco primer onto the metal to give a very strong adhesive coat for the rest of the paint and the final result is shown.
I used 2K black primer on the floor. The chassis was treated with Rust Proof Material before finally being coated with 2 coats of rust proof Duco Paint.
As usual the images don't do justice the the amount of time that has gone into this so far.
New Tubes Tyres were put before, due to the rains of June – September 2006 the respray of the body and panels has been defered until October. The complete body was sprayed with several coats of High build primer followed by flatting this back ready for top coat.
Whilst looking to be a quick job, it turned out to be quite lengthy due to ensuring alignment was correct before final fixing.
Thing’s Need to Be Done :-
New Metallic Paint.
New Seat Covers, New Flooring/Carpet, New Roof lining.
New Wiring.
New Hose pipes – they become dry & fall apart & leak.
Window Seals – Find out which existing cars seals will fit. Any Help?.
Chrome :- Headlamps, Bumpers, Windshield Trims & other trims, Rims, Hubcaps, etc
Polish all Plastics interior.
Bringing the engine to this condition
Finally “A New Enclosed Parking for My Restroed Datsun 260C”
Almost A year exactly has passed since I started this restoration, in the process I have re-established old friendships and made a lot of new ones. The other reward has been the tremendous amount of satisfaction gained from seeing a pile of junk turn into a car that will turn heads wherever it goes. I think it is rather fitting that the last image that will be posted (in near future) will be from the rear, because disappearing into the distance is the view most other motorists will get. Cheers!
Will Post new Pics After New Paint. Thank U for your time.
Any Suggestions are Welcome.
You can contact me On “TEAMBHP”, or @
shreeramparulekar@hotmail.com
Here are some pics of the interior but from a right hand automatic version
Whoa! When can we pop over to see the work Shreeram? Looking forward to see your car in flesh.
@gordon : Thanks a lot buddy!
like you said pictures dont do it justice. when the car is complete get a nice photoshoot done.
Great job Shreeram. Congrats on the great work.
:Cheering: good job there buddy! Good luck with the pending work... and really looking forward to seeing some pictures of the finished product
Good work Shreeram. I'll drop in sometime next week to check your car out.
great job shreeram. I have a friend in Panvel who is an authority on these cars. Will ask him if hes got ant spares to give out.
congrats on you restoring project and your amazing car Datsun are one of my favorite cars especially the 240z.
great effort on this amazing car..very painstakingly done, looking at the pictures in different stages
