Search Forums |
Advanced Search |
Go to Page... |
Search this Thread | ![]() 116,203 views |
![]() | #1 | |||||
Distinguished - BHPian ![]() ![]() Join Date: Oct 2013 Location: Bangalore
Thanked: 5,740 Times
| Technically understanding Airbag systems & SRS Related Thread : Link Supplementary Restraint Systems (SRS) in modern day cars are quiet complex and Airbags and Seat Belts with pretensioners are key components that help keep one safe during accidents. I have broken down this thread into the following components in order to aid easy reading
_____________________________________ History _____________________________________ Quote:
![]() Source: http://www.explainthatstuff.com/airbags.html Quote:
_____________________________________ Key components of Airbag Systems _____________________________________ To keep it simple, a modern day automotive airbag system contains the following key components:
_____________________________________ How does an Airbag System work _____________________________________ Here is the simple explanation of how the system is designed to work ![]() Source:http://www.explainthatstuff.com/airbags.html
_____________________________________ Deconstructing the Airbag Module _____________________________________ ![]() Source: https://www.autoliv.com/ProductsAndI...s/default.aspx The Airbag module typically consists of 4 main components:
_____________________________________ Types of Sensors _____________________________________ Here is where things can get a little complex. Based on my understanding, sensors can be broadly classified into 3 types:
Based on their construction, Sensors can also be classified into:
_____________________________________ Modern day SRS system _____________________________________ Here is the simplest representation of a modern day SRS system ![]() Source:https://www.slideshare.net/abhisheks...-in-automobile
Last edited by GTO : 9th August 2017 at 09:18. Reason: Adding link to related thread | |||||
The following 42 BHPians Thank procrj for this useful post: | abirnale, AdityaDeane, aman9393, Ani0404, aniket17, Arun Venugopal, arun_josie, audioholic, Avikbrio, CrazyToDrive, digitalsuresh, FORTified, GTO, harry10, jeevadeepan, knightrider_7, libranof1987, Lobogris, LoneRidder, Motard_Blr, motorguy, n.devdath, Nohonking, paragsachania, ravib, Rohan24, saket77, satishv1987, sayakc, SDP, shipnil, skchettry, SmartCat, Sutripta, The Rationalist, tifosikrishna, Udit, V.Narayan, vaasu, VaibhaoT, xtremeshock, yoscenario2000 |
![]() | #2 | |||||
| re: Technically understanding Airbag systems & SRS _____________________________________ Some Questions _____________________________________
_____________________________________ What you need to know _____________________________________
Here is an interesting video from 1991 Last edited by procrj : 8th August 2017 at 16:14. | |||||
The following 37 BHPians Thank procrj for this useful post: | AdityaDeane, aman9393, ampere, Ani0404, arjithin, arun_josie, audioholic, Avikbrio, blackwasp, Boomerang, Dhananjay_Desai, earthian, GTO, highway_star, IshaanIan, itsmb, Karthik Chandra, knightrider_7, libranof1987, LoneRidder, mallumowgli, mishraak, Nohonking, paragsachania, ravib, saket77, samaspire, skchettry, SmartCat, supertinu, Sutripta, The Rationalist, Udit, V.Narayan, v12, vjkamal, yoscenario2000 |
![]() | #3 |
Team-BHP Support ![]() ![]() | Re: Technically understanding Airbag systems & SRS Thread moved from the Assembly Line to the Technical Section. Thanks for sharing! |
The following BHPian Thanks GTO for this useful post: | procrj |
![]() | #4 |
Senior - BHPian ![]() Join Date: Dec 2006 Location: Mysore / B'lore
Thanked: 4,462 Times
| Re: Technically understanding Airbag systems & SRS Good info. Here's some vehicle specific info about the sensors and how they work from my Mitsubishi's manual. ![]() ![]() |
The following 13 BHPians Thank SunnyBoi for this useful post: | arun_josie, audioholic, Avikbrio, Dhananjay_Desai, GTO, IshaanIan, kutts, mallumowgli, procrj, saket77, skchettry, SmartCat, The Rationalist |
![]() | #5 |
Newbie Join Date: Jan 2014 Location: Bangalore
Thanked: 13 Times
| Re: Technically understanding Airbag systems & SRS Thanks. Very valuable and useful information. What I would like to know is does it cost a lot to reset an airbag once it's deployed? Last edited by GTO : 11th August 2017 at 09:16. Reason: Not my article :) |
The following BHPian Thanks kirren07 for this useful post: | motorguy |
![]() | #6 |
BHPian ![]() | Re: Technically understanding Airbag systems & SRS @Procrj and @sunnboi - fabulous articles. Both of you have broken down the complexity of the SRS systems to something all of us can understand. Always wanted to know the intricacies of SRS systems. On a humorous note, someone I know (and this is true) after seeing the words "Airbag" on the steering wheel and near the glove compartment, thought that there was actually a bag that could be used for a purpose (like a shopping bag container) and didn't actually know that it was a restraint system. She almost tried to take out the airbag by prying the cover with her hands to find out what this "air bag" was, before a friend stopped her and said you would have to pay a pricey amount to replace (as it can't be packed back into the steering wheel). ![]() |
The following 3 BHPians Thank motorguy for this useful post: | procrj, Researcher, SmartCat |
![]() | #7 | ||
BHPian ![]() Join Date: Jul 2017 Location: Madurai
Thanked: 48 Times
| Quote:
Again, everything happens in a matter of less than 80 ms. So the subject is very debatable with a lot of if's and why's. ![]() You can't actually 'reset' an airbag. You will need to replace the entire SRS. For sure, it will cost a fortune. Last edited by GTO : 12th August 2017 at 08:34. Reason: Merging back to back posts | ||
The following 2 BHPians Thank vjkamal for this useful post: | procrj, shashanka |
![]() | #8 |
Senior - BHPian ![]() | Re: Technically understanding Airbag systems & SRS Thanks for the insights. What this makes us know more is having an airbag equipped car is no longer a peace of mind. Manufacturers can still skip on some necessary sensors (and thereby save a few hundred rupees at the most). Skipping on an impact sensor, and in case of a crash, which as mentioned, in real life scenarios may not be head on, the airbag may not deploy, thereby making the entire purpose of having an airbag as useless. Last edited by vinit.merchant : 10th August 2017 at 14:58. |
The following 2 BHPians Thank vinit.merchant for this useful post: | procrj, shashanka |
![]() | #9 | |||
| Re: Technically understanding Airbag systems & SRS Quote:
![]() For me its a trade-off between 100% likelihood of injury and a less likely chance of injury due to SRS. Also need to note that Airbags are only 1 part of SRS. Pretensioners today work quiet well and I have observed on many occasions that my seatbelt pretensioner held me in place during panic breaking or even when I suddenly move in front to get a little more comfortable. | |||
![]() | #10 |
Senior - BHPian Join Date: Jul 2009 Location: Calcutta
Thanked: 6,234 Times
| Re: Technically understanding Airbag systems & SRS How doesa one find out the weight of the person(kid/ adult) in the seat? Something a bit more detailed than 'with sensors'. Regards Sutripta |
![]() | #11 | |
Senior - BHPian Join Date: Feb 2008 Location: Bangalore
Thanked: 2,028 Times
IIRC, I have read in other threads in TBHP that it is mandatory to wear seat belts in order for SRS Airbag to deploy (atleast in modern cars). Aren't we getting mixed information ? Or Am i missing something. ![]() I met with an accident last March in my i20 Asta. Because it was not a frontal impact, airbags did not get deployed, but we all walked out safely due to seat belts. However, when i dropped the car in Hyundai garage, i saw another i20 which had complete damage all the way till windshield due to head on collision. But the steering wheel was intact and Airbags didn't deploy because the driver was not wearing seat belts. This is my personal experience and confirmed by Hyundai service advisor. -Ravi Last edited by ravib : 10th August 2017 at 23:16. | |
The following BHPian Thanks ravib for this useful post: | procrj |
![]() | #12 | |
Distinguished - BHPian ![]() | Quote:
True, but that would be a very small effect. I would think that the bull bar can change the way the car crush zone absorbs the crash and therefor impacts the deceleration. Jeroen | |
The following BHPian Thanks Jeroen for this useful post: | procrj |
![]() | #13 | |
There might be different ways about it, but essentially a weight system, e.g. Bladder, in the seat with some electronics. http://auto.howstuffworks.com/car-dr...vices/ocs1.htm | |
![]() | #14 | ||
| Re: Technically understanding Airbag systems & SRS Here is a more detailed explanation of what is called Occupant Detection Systems While bladders have been in use for almost 20 years, today the systems are more advanced and make use of bolt type weight sensors, pressure sensitive mats and in some cases electrostatic capacitance sensors as well. The entire system is called an Occupant Detection System and consists of a Weight Detection System and also an Occupant Position Detection System Not sure how much of this is in use in Indian cars. Quote:
How does a Weight Detection Sensor work? ![]() Source: http://www.google.co.in/patents/US6161891 Quote:
How does a Occupant Position Detection Systems? ![]() Source: YouTube video below You have pressure sensors in the seat back and side bolstering that will help determine the position of the passenger and send signals to and ECU located in the seat back, which then send inputs to the ACU about which airbags to turn on or off. More info for those who are interested: http://cpsboard.org/cps/wp-content/u...tic-On-Off.pdf Ravi - yes its mixed info as there is no clear guidance which says that it will work or wont work without seatbelts. Hence to be on the safer side, always wear seatbelts ![]() Can you explain a little more? Not able to clearly understand the relationship between the crush zone and the change in deceleration experienced by the sensor. | ||
The following BHPian Thanks procrj for this useful post: | Sutripta |
![]() | #15 | |
Thanked: 48 Times
1. The first phase is when the barrier hits first point of the vehicle. Both the parties start deforming. On the car side, it is mostly the soft parts (bumper/ radiator) that can absorb light impact. 2. The second phase is when the barrier enters in to the crumple zone present in between the engine and the bumper. This can be lateral members made of sheet metal or other part of BIW. This is a relatively harder phase. 3. The third phase is when the barrier has almost deformed (meaning it will not take impact in the same way as it did in the previous phases) and it reaches the engine. This is the most severe phase. Now consider the case of a bull bar. Remember most of the bull bars are mounted on the underbody directly on some rigid area. The bull bar will be the first to contact the barrier where the pulse is expected to be softer. Even though the bull bar takes some load, the accelero-meter sensors may send to the ACU a sharp shock wave due to this. This may or may not trigger the restraint systems depending on case to case. If it does, the airbag may not be 100% effective in securing the occupant because early triggering means the bag will lose out some gas even before it is being loaded. The occupant head may bottom out. This is again, very subjective. Last edited by vjkamal : 11th August 2017 at 14:45. | |
The following 4 BHPians Thank vjkamal for this useful post: | Jeroen, procrj, shashanka, Sutripta |
