^Aye capn' Haddock !
right, ABS regulates the pressure at the brake pads and when it senses that the one(or more) of the wheels is about to lock. One can certainly put great tyres and probably even fit aftermarket brake pads for better braking power. But that does not stop the sand, small gravel or any other traction-reducing element to essentially bring the frictional coefficient between the road and the tyres down considerably.
So when you slam on the brakes the brakes do work great. The wheel locks due to the braking power given by the brake pad's force on the disk to retard the wheel's movement down significantly. Therefore the wheels tend to slow down abruptly. Now the inertia of the car tends to not allow any change in the state of the car. So the tyres bear the brunt. When the inertial force & braking power is greater than the frictional force between the tyres and the road, the wheel locks.
Now when the wheel locks the rubber melts which further reduces the frictional force. So if you do lock up for a good amount of road length (i.e skid ) , even if you release the brakes you may not be able to get back the control of the car because the tyres have melted which may throw the car in a spin.
ABS + EBD is the ideal package since EBD can actually distribute the braking force separately as per the need. Suppose you are half on tarmac and half on the road, the ABS would reduce the braking pressure on all the wheels. Rendering it ineffective since the ones on the road would have braked better but now cannot. But EBD can regulate with the ABS so that the wheels on the sand will receive lesser pressure than the ones on the road.
ABS + EBD it'd be for me.
and no matter how much you practice, something or the other is out there to make you panic.
Reason: spell check, punctuation edits. : P
