Originally Posted by utkarsh10
(Post 5086797)
Fastag is finally available at the Yamuna Expressway. It took a long while but now that it’s there, let’s hope it’s seamless and is expanded to all lanes. Currently, it’s available only on 3 lanes. https://timesofindia.indiatimes.com/...w/83752740.cms |
Originally Posted by mayankk
(Post 5092175)
Left two most lanes are fastag enabled now. I did have a hiccup at the second booth while coming back to Noida, and had to pay 140 in cash, but smooth otherwise. I was surprised, though, by many under 4 year old cars, even expensive ones , that were still standing in the cash queues. |
the private concessionaire was directed to increase the number of lanes as vehicles spend about 20-25 minutes on an average in each of the toll plazas during the morning and evening rush hours.... The FASTag system, which was started in June last year with just two lanes on each side, has now been extended to all the lanes after the service became mandatory on February 14 this year... adding that all the toll gates would allow FASTags. |
Originally Posted by tanwaramit
(Post 5319211)
Folks, I have a question to people traveling from Noida to Agra. Is there a U Turn available before Jewar toll gate ? Usually all toll gates have U Turn option available for people to go back apart from other needs/rules. I don't know if the U Turn is available before the toll gate of Jewar. |
Originally Posted by Born 2 Be Wild
(Post 5319235)
Yes there is a U turn available around 3-4 kms before the Jewar toll booth, have used it multiple times on sunday bike rides. Also there is a U Turn Gate at the toll booth but you have to pay toll cross the booth and take the U TURN 50 Mtrs ahead |
(Post 5092175)
Originally Posted by LordSpymaster
(Post 5565740)
Hi, I'm going to Agra in a few days and planning to use the Yamuna expressway. Worried about tyre blowouts so I'm curious as to how safe is it from a driving POV? |
(Post 5565744)
If you have decent tyres, not ancient, good tread, 30-32 or recommended psi, this is hardly a worry. |
(Post 5565846)
Anything I should do before going on the expressway? Like a specific tyre pressure range or something? |
(Post 5565846)
Originally Posted by barcalad
(Post 5566595)
The probability of a tyre blowout on a concrete surface is a lot more on soft compound tyres (like most superbikes and supercars) and in tyres that have more-than-recommended tyre pressure in them. |
Originally Posted by SLK
(Post 5566769)
Its normally not so simple. The higher the tyre pressure lesser the friction and lesser the heat which leads to less expansion. So if I were to take my pick, it's safer with higher pressures than lower, which cause more heat and expansion. So go with recommended pressure and keep your speed in check, don't race with people! Give way to overspending vehicles and you'll be fine. It's just a road, a very tempting one to break speed records, which is what causes most accidents. If you are following speed limits, you don't even need to think about it. But if not! Then check tyre rating first and if you have history of punctures don't do anything adventurous. |
(Post 5566595)
If you're driving between 9 AM - 6 PM, I suggest you keep your tyre pressure 1-2 PSI below your usual number. Don't maintain a steady speed - keep fluctuating the needle. Most important - don't stress about it. The probability of a tyre blowout on a concrete surface is a lot more on soft compound tyres (like most superbikes and supercars) and in tyres that have more-than-recommended tyre pressure in them. |
(Post 5565846)
Yeah, mine's a 9 month old new Honda City 5th Gen ZX MT so this shouldn't be a worry. Was still checking in advance to be safe. Anything I should do before going on the expressway? Like a specific tyre pressure range or something? |
(Post 5565744)
(Post 5565740)
Originally Posted by Shreyans_Jain
(Post 5566843)
There is a strictly imposed 80kmph speed limit all over the “expressway”. |
