Old 14th September 2021, 19:06   #31
Thanked: 1,807 Times
Re: Prefabricated House Options - Light Gauge Steel Frame
Originally Posted by Aravindpn View Post
Great! It should be really good. How are they holding up?
For now it's holding up, but I don't think long term maintenance is going to be easy or cheap. They also aren't setup to execute works in the south as yet.
Good luck.
keroo1099 is online now   (1) Thanks
Old 14th September 2021, 20:14   #32
Thanked: 26 Times
For the above: you could consider:
Build a single room structure that can later serve as parking or storage. This can be in the vicinity of the house you would want to build later. Of course, some modifications will be required. But at least such a structure will get you moving. Working out of a resort while parallelly trying to the farm activities moving will be definitely challenging.
And do remember murphy's law. Applies very well to getting a farm moving from ground up. Anything that can get delayed, Will !
True with delays. The entire process till now saw many delays and hiccups. Agriculture development is definitely not fast like Mumbai/ BLR city life. Now Iam in the stage to do the plantations as per plans. Will start small as far as rooms are concerned.
Aravindpn is offline
Old 18th December 2021, 23:32   #33
diyguy's Avatar
Thanked: 588 Times
I am looking to build a 2000-2500 Sq ft home for five of us in Chennai. Kids will likely leave us in a few years and then we will be down to three. Am seriously considering Prefab for precision, speed and avoidance of regular construction headaches. Will try to visit a few sites in Bangalore and see. Found some good name builders and their photos of actual projects look good. Hope to go down this path but from initial research this is more expensive than B&M, maybe am wrong but will dig into this more.
diyguy is offline
Old 19th December 2021, 01:56   #34
condor's Avatar
Thanked: 16,900 Times
Originally Posted by diyguy View Post
Will try to visit a few sites in Bangalore and see. Found some good name builders and their photos of actual projects look good..
May be you could share these here. Can help others who are looking for the same.
One of the names I came across: Tata. I think you would have seen Post #1 & #17 on the prev pages.
condor is online now
