Originally Posted by sagarpadaki Excellent stuff graaja. The outcome is very neat and functional!
Might I suggest that you coat all the solar panels with ceramic coating... |
Thank you for the kind words and the tip about ceramic coating. I will check with the installer about ceramic coating and see if I can do this.
Originally Posted by thanixravindran Wow, Fantastic graaja. An Off-grid farm like 'Down under' is a dream that can be very rarely realized here. Congratulations and Best wishes.
I can only imagine the smile on your face when the first water was pumped out using solar energy.... I am now interested to go for Solar for my home borewell pump.
I have few questions
1. Is there any reason that you did not consider a single phase pump which I think is available in 230V range? Or in future you want to get the 'Mains' from Electricity board also? I presume you don't have any need for night irrigation which is mostly done when 'Mains' is available.
2. Since you have series connected all the panels, have you considered a scenario when one of the wires can be bitten say by a rat that can stop the entire solar system? (Apologies if this is coming in a wrong way, but since I was an product development engineer, my mind is trained for FMEA).
3. What is the overall DC connection length that is ongoing from the panels to your control room (which I think houses both VFD as well you home inverter)? I guess the poles carry 220V AC to your home from control room and are properly sized and insulated.
4. Did your installer do any full day survey for the sun or shade pattern from morning to evening prior to the installation?
5. Have you considered any insurance for this solar farm set-up? Is anything available?
Your set-up is excellent as per the good practice for the height. The steel-concrete structure at a height upto 3 feet even in roof top is generally rated for winds upto 220Km/hr. I did this research and consultation with Luminous given Chennai has experienced Vardha cyclone couple of years (2016) before my installation.
Please consider a system to wash the panels may be using the same Solar pump water with automation. |
Thank you for the kind words, and all the best with the installation of solar for your pump.
1. For a solar VFD where the frequency of the pump is varied according to intensity of solar, I don't think a single phase pump would work.
2. No. I have not considered this scenario. As the panels are raised at a height above the ground, there is very less chance of rats climbing the structure and biting off the wires. In the remote chance that happens, then I will have to just patch up the wire.
3. The panels are located at a distance of around 50 feet from the control room and a 10 sq.mm wire has been used to bring the panel voltage to the control room. The maximum panel current would be 9.5A. The 230V AC line is routed through the posts to the house, and I believe that is also appropriately sized (did not pay attention to this size).
4. No. We did not do a full day study of the location. We just decided based on the surrounding trees and left enough gap based on experience.
5. No. I have not considered to get insurance for the system. Not sure if such an insurance exists and the procedures to get one.
I have made provisions for water connection near the solar panels from the solar pump and used this to wash the panel once. As it takes about 15 minutes to wash the panel and as it is a good workout in the sun that can provide both strength and mobility training along with good Vitamin D, decided to keep it manual
Originally Posted by frewper Excellent Thread as always Graaja. And what an excellect project to have.
Obvious I am too raising my hand for a few questions.
1. You mentioned you intend to use a PLC for controlling the values. I am assuming you have something else planned to add on the PLC? Since the cost of adding a PLC and programming it might not be cost effective. Even if we go in for the cheapest PLC.
Or do you plan to build it yourself? Then it would make sense.
2. Is cleaning the panels that difficult? Wouldnt just holding the water pipe directly from the pump clean the panels easily. Given its not too high.
3. Since there are no mains, are you planning to keep some small electric generator as a backup. |
Thank you so much for the kind words!
1. I plan to use a simple starting level PLC which costs about 10K, and will be doing the ladder programming myself. Also, I will be building the complete control panel myself. So, it shoudldn't be expensive. This is at least a year in the future.
2. Just holding the pipe will not be enough to dislodge the thick layer of dust that gets accumulated. Need to scrub the panels as water is flowing over the panels to completely remove the dust.
3. No. I am not planning to keep a generator. Before this 3kW installation, the small 300W setup used to get off most of the time at around 4AM in the morning. And we used to manage with a cell phone torch light. Plan to do the same if there is any failure
Originally Posted by fordday First, a big congratulations on your setup. I am sure it gives you immense pleasure when you see the sun's energy put to use on the farm. Hope it gives you a hassle free years of operation.
I wanted to know what exactly is the function of the VFD? You mentioned it shows the frequency at which the motor is running. Doesn't a regular solar inverter creates/matches the normal 50Hz frequency? |
Thank you for the kind words. aim120 has very clearly explained the system. In a regular hybrid or grid tie system, when the intensity of the sun goes down, the difference power that is required to run the pump will be provided by the battery or the grid. Because of this the pump can always be run at 230V/50Hz. But with a solar based VFD, as there is no alternate power source to provide this difference power, the VFD adjusts the output based on the solar intensity. With a 3 phase motor, the simplest way to vary the output is by varying the frequency. Like aim120 mentioned a 3 phase hybrid inverter setup would cost close to 2 lakhs whereas the VFD costs about 30K. The downside of the variable pump speed is that the water delivery and pressure is directly proportional to the intensity of the sun. So, if the pump delivers 6000 liters per hour on a sunny day, the delivery can drop to 3000 liters per hour on a cloudy day.
