Old 27th July 2015, 10:36   #421
diyguy's Avatar
Thanked: 588 Times
I have kicked off my home loan transfer from LIC to HDFC and for this month there is a refund of the processing fee for the loan. In case anyone is considering it, now is the time.
diyguy is offline
Old 27th July 2015, 13:34   #422
S_U_N's Avatar
Thanked: 418 Times
Re: Help with a home loan!
Is refund only with LIC or other companies as well?
S_U_N is offline
Old 27th July 2015, 13:36   #423
diyguy's Avatar
Thanked: 588 Times
It is from any bank to HDFC.
diyguy is offline
Old 30th July 2015, 11:50   #424
Oxy
Thanked: 675 Times
I booked a 2 BHK in a project called Sumadhura Shikharam last week.
http://www.sumadhurashikharamppc.com/
I approached Citibank for the loan. They refused me the loan saying that the builder is not listed with them. I hold a Citibank salary account since more than 8 years and also have a Citibank credit card.
SBI though has no issues in giving me the loan. Citibank's loss then I guess!
Oxy is offline
Old 30th July 2015, 13:38   #425
pahwa's Avatar
Thanked: 157 Times
Just got another shock from LIC HFL. For my HL in 2009, the interest rate was increased to 11.75% in 2012, thus increasing EMI from 17k to 20k. This week when I went to branch to re-write my loan, I got to know that my loan tenure was increased to 25 years (no intimation, or approval from my end.
Any suggestions what could I do in such a scenario?
pahwa is offline
Old 30th July 2015, 14:42   #426
Thanked: 48 Times
The bank does not require your approval. The HFC or bank can increase tenure or EMI at their discretion. Usually tenure is modified, however you do have the option to change EMI instead by visiting the branch.
Most banks do intimate via regular post of any change in tenure/EMI. I don't recall receiving any registered post or courier for this.
But isn't your interest rate way too high? I took a car loan from SBI end of last year and the interest rate on that is lower than your home loan when it should have been the other way around. If I were you, I would shop around for competitive rates and move my home loan elsewhere. For this, you also need to get in touch with LIC and fully understand if they have any loan prepayment penalty.
nowwhat? is offline
Old 30th July 2015, 17:04   #427
Thanked: 385 Times
Can you please clarify what you have done when "re-writing" the loan? Is it an interest rate reset, an EMI reduction, etc? Do you have an idea if other lenders will be willing to foreclose your loan and take it over?
reverse_gear is offline
Old 30th July 2015, 18:31   #428
pahwa's Avatar
Thanked: 157 Times
Re-write means, you may 0.5 of outstanding loan and reset the interest rate to current ones. It brought my interest rate down from 11.65% to 10.5%. Effectively reducing tenure by 22 months.
pahwa is offline
Old 30th July 2015, 18:47   #429
Thanked: 385 Times
Why did you go in for a re-write? You should have just gone to some other cheaper lender and foreclosed the existing loan with LIC. I do not understand why you have to pay 0.5% for the privilege of getting rates that are probably higher than average market rates in any case.
Loan tenor can increase only when either the interest rate is increased or the loan amount increases (i.e. you draw an additional loan on the same property, which some lenders allow). It must have been either of the two.
Old 30th July 2015, 18:51   #430
Thanked: 135 Times
+1, at the same cost (o.5%) he could have shifted to a different bank, which are offering around 9.90% for new customers. Not a very prudent move.
ILTDrive is offline
Old 30th July 2015, 18:59   #431
rajeev k's Avatar
Thanked: 1,955 Times
This is because the HFC considers continuance of the same EMI even with increase in interest rate. Thus to compensate for the increased interest part, the tenure of the loan is extended and vice versa.
rajeev k is offline
Old 30th July 2015, 19:56   #432
pahwa's Avatar
Thanked: 157 Times
Yes, I agree. However, my friends/neighbors who took same amount of loan, at the same time have the same tenure. It seems some error in my case since EMI and tenure both have been increased.
I agree. I tried with HDFC, ICICI, PNB, SBI and Axis. None of takes over loan for a B-Khatha property if it is not pre-aproved by them.
pahwa is offline
Old 30th July 2015, 22:47   #433
Thanked: 135 Times
This is surprising, mine is also a B khata property and I moved from LIC to Axis couple of years back. You can check at the white field loan service center. However, it does not make sense to shift now, because you are at 10.50% and the benefit is only for 0.5%.
ILTDrive is offline
Old 31st July 2015, 04:44   #434
benbsb29's Avatar
Thanked: 14,216 Times
HDFC also has a similar option, which i have done twice in the past to bring down my astronomical interest rates. I had 2 years at 8.5% fixed when i took the loan, and then once it went to floating rates, it jumped to 11.75%!
I then used the reset option to lower the interest rate, which brought down the tenure, keeping the EMI constant throughout. I had done this twice.
benbsb29 is offline
Old 9th August 2015, 11:22   #435
JD1
Thanked: 163 Times
Any August month offers from banks offering processing fee waiver for home loan transfer? Mine is with IDBI and they are still charging astronomical rates. I have 9L outstanding but can't bear to see a difference of 2% between prevailing market rate and what IDBI is charging me.
Considering that interest rates may further go down, which are good banks currently to bring down rates religiously? (So even if I switch now, I don't have to worry that my rates would freeze).
JD1 is offline
