Guys,
One of my relatives is assembling the LED clocks with moving message display. Currently they buy a new working wall clock from market. Take out all parts except the casing. Later they fit in all the LEDs and circuits in clock. Major problem here is that a wall clock with a good casing is expensive :mad: going for a custom made wall clock case is quite expensive. They were told that the plastic mould would cost at least 1.5 Lakhs! Being new to market, initial investment of 1.5 Lakh is quite expensive for them!
The working mechanisms of wall clock are of no use for them. They just need the wall clock casing around 40cm diameter
We have heard that in Gujarat or Mumbai the plastic casing would be available/fabricated cheaply. If anyone has details of same, kindly provide the contact details.
Thanks in advance
I would suggest you to search for it on the
B2B websites like
www.indiamart.com,
www.alibaba.com etc. They have a strong database and will have lot of information which will be really helpful for your Business as a whole.
www.Alibaba.com will also help you in finding such manufacturers in China, which i believe will be very good for your business in long run.
There are couple of them in gujrat. Will found out and post you.
But if the quantity is substantial, it is much cheaper to get from china.
You can contact Mugen_Power on the forum.
Thanks guys for the reply. They are still starting the assembly, its in proto-type stage. So the market response for LED clock is unknown. If volumes are large then can think of Chinese casing or molding the case locally etc :)
