Re: Glare protection from oncoming headlights Quote:
Originally Posted by NerdSpeaks (Note that I don't have liberty to use usual Sunglass due to my spectacles.).
Similar product link is given below.
Also note that I suffer from Migraine headache when I drive in sun. This type of attachment has really reduced occurrences of headache for me. |
Since I have hyperopia, so have tried driving with and without glasses. With transition lenses by Essilor which I am using since the last three years the glare is cut and helps us drive peacefully and can easily view all the surroundings.I use Esilor progressive lenses with transitions so the moment glare or headlights are seen then the lenses darken(in about 30 secs) to cut out the glare without affecting the vision. The moment the light is back to normal the lenses return to normal shade. Have drove a lot in the night and have not had any problems since about 3 yrs.Even in sunlight the effect is the same. Quote:
Originally Posted by ramharis I have used these drive safe lens and still using them. I tend to get headaches while driving in the afternoon due to sun's brightness, drive safe helps a bit there too. It was suggested by Lawrence and Mayo's in-store doctor and I'm totally satisfied with it.
Personally I will recommend trying it. Please buy them from a well known dealer/opticals. |
If you have spectacles then get photochromatic lenses (Esilor/Zeiss) and you won't have headaches Quote:
Originally Posted by Vin@y Anyone tried using a day and night glass for driving?
Theoretically, the photochromic lens should help during day time and anti-glare should help during night time.Not sure whether photochromic + anti-glare combination is available and how much it helps during both day and night driving. |
Since I have hyperopia, so have tried driving with and without glasses. With transition lenses by Essilor which I am using since the last three years the glare is cut and helps us drive peacefully and can easily view all the surroundings. Quote:
Originally Posted by Ax0TD My friend recently had a rainwater repellant coating done to his old Alto's windshield. Says that worked against the opposite high beam lights spreading on the windshield. So visibility is better. Although it stays effective for 4-6 months only. Depends on how many times you use the wipers |
In heavy rain when visibility is low then wear simple dark sunglasses and see the result. Quote:
Originally Posted by ramharis I have photochromatic glasses and frankly, you will not see any tinting when you are inside the car. I believe those lens need UV to change shade which works when you are outside the car. Drivesafe with Photochromatic is available, but it was 11K when I enquired 2 years back.I would still choose drivesafe first and then the rest. There is something about drivesafe which really works in the real world. |
Esilor progressive lenses with transitions so the moment glare or headlights are seen then the lenses darken(in about 30 secs) to cut out the glare without affecting the vision. The moment the light is back to normal the lenses return to normal shade. Even when you are inside the car whether it is day or night.
Reason: Please avoid positing bold font responses.
