Old 2nd November 2023, 20:40   #1
CrAzY dRiVeR's Avatar
Thanked: 78,872 Times
2024 Ducati Hypermotard 698 Mono unveiled
Ducati has unveiled the Hypermotard 698 Mono, the brand's first single cylinder motorcycle in around 30 years. The motorcycle will be displayed at EICMA 2023.
This motorcycle will be powered by the all new Superquadro Mono engine. Equipped with a Desmodromic system - the new engine produces 77.5 hp at 9,750 rpm and is capable of going upto 85hp with the racing exhaust at 10,250 rpm.
2024 Ducati Hypermotard 698 Mono unveiled-my24_hypermotard_698_mono_01_uc575817_high.jpg
2024 Ducati Hypermotard 698 Mono unveiled-my24_hypermotard_698_mono_02_uc575816_high.jpg
2024 Ducati Hypermotard 698 Mono unveiled-my24_hypermotard_698_mono_03_uc575818_high.jpg
2024 Ducati Hypermotard 698 Mono unveiled-my24_hypermotard_698_mono_04_uc575820_high.jpg
2024 Ducati Hypermotard 698 Mono unveiled-my24_hypermotard_698_mono_12_uc575828_high.jpg
2024 Ducati Hypermotard 698 Mono unveiled-my24_hypermotard_698_mono_11_uc575831_high.jpg
Main standard equipment:
  • Ducati Superquadro Mono engine with bore and stroke of 116 and 62.4 mm, 659 cc, maximum power of 77.5 hp at 9,750 rpm, maximum torque of 6.4 kgm at 8,000 rpm (A2 version 43.5 hp at 6,250 rpm and 5 kgm at 5,750 rpm), box-in-box piston, desmodromic distribution with titanium intake valves
  • Steel trellis frame with tubes of different sections and thicknesses, steel tube subframe and aluminium double-sided swingarm
  • 45 mm Marzocchi upside-down fork, fully adjustable, with upper adjusters for hydraulic calibrations, 215 mm travel. Fully adjustable Sachs monoshock with interposition of progressive linkages, external adjusters for hydraulic calibrations, wheel travel 240 mm.
  • 5-spoke alloy wheels 120/70-17” and 160/60-17”with Pirelli DIABLO™ Rosso IV tyres
  • Bosch-Brembo ABS 10.3ME Cornering braking system
  • 330 mm diameter front disc with aluminium flange and Brembo M4.32 4-piston radial caliper
  • Rider footrests optimized for sport riding with removable rubber covering for maximum grip with racing boots
  • Full LED headlight with double-C DRL, Full-LED rear light
  • Dashboard with 3.8” IBN (Improved Black Nematic) LCD screen with gear shift LED
  • Lithium ion battery
  • Bosch Inertial Measurement Unit (IMU)
  • 3 Power Modes (Low, Mid, High)
  • 4 Riding Modes (Sport, Road, Urban, Wet)
  • Ducati Wheelie Control (DWC)
  • Ducati Traction Control (DTC)
  • Engine Brake Control (EBC)
  • Ducati Power Launch (DPL)
  • Ducati Link Ready with infotainment apps
  • Ducati Quick Shift (DQS) Up&Down
CrAzY dRiVeR is offline   (6) Thanks
