Team-BHP - Buying a used Mitsubishi Pajero SFX
-   SUVs, MUVs & 4x4s (https://www.team-bhp.com/forum/suvs-muvs-4x4s/)
-   -   Buying a used Mitsubishi Pajero SFX (https://www.team-bhp.com/forum/suvs-muvs-4x4s/212268-buying-used-mitsubishi-pajero-sfx.html)
Hello Everyone.
How sane of a decision would it be to buy a used Pajero SFX?
Have come across a 2008 model with 54000kms on the odo for sale at a dealer.
I don't plan on using this vehicle for specifically offroading, but driving to offbeat places, bad roads that i will encounter, occasional camping, long distance travel.
Would request your inputs on few queries that i have.
When inspecting the vehicle what do i have to look out for?
How is the spares availability and after sales service of the vehicle in mumbai?
What would be the yearly running costs of scheduled service and other nitty gritties that occur?
Considering everything checks out this will replace the Elantra and will be the primary vehicle.
Anything else you think is necessary please add.
Kashif
I can not comment on other aspects but I can say with certainty that the odometer is tampered with.
Please hunt for Tejas's Pajero thread, that should be your guide. For your purposes, the Pajero will suit you. You only need to sort the service and spares aspect.
IF you are not using the vehicle strictly for offroading purposes, why not look at the Montero? It is far more comfortable and rides and handles better too.
Hi Sheel
Is there any way to find out if the odo has been tampered with ?
Will the ASC help out or any FNG dealing with Pajero’s be able ascertain the kms done based on service records?
I am indeed going through Tejas’ thread bit by bit as that’s the most updated one.
Have also gone through the threads posted by sawyer, vijay.
Hi Ishaan
Ok will look into it.
Originally Posted by iron (Post 4641527)
Hi Sheel
For 10 years now, we've been relying on a FNG mechanic to evaluate our used cars in the family. All our guy needs to do is to inspect the engine bay's innards thoroughly and then to take one look at the odometer. I'd say that he can identify odo tampering in 60% of the cases just based on visual cues. His test drive takes things another 30% further. As for the remaining 10% of uncertainty, it ought to be a minor margin (perhaps 20k Km at the most) which cannot be detected by such means. We place our full confidence in his judgment when evaluating used cars and it has worked out well so far.
Having bought a 2011 Pajero SFX about 2 yrs back, here are my 2 cents...
Totally insane but worth every penny :D
I would be really surprised if the odo is not tampered with! You'd better assume that the vehicle has done at least double that distance, if not triple, in 11 yrs.
Perfect vehicle for the requirements you have listed down, although a well-maintained Fortuner would also be a worthy contender, especially if you wish to do cross-country runs. Pajero SFX is not the best of highway cruisers, given the archaic engine, which is a locomotive when it comes to low-end torque but runs out of steam at higher RPMs/speeds. Having said that, I have done 3000+ km drives in the SFX - if you are not a highway scorcher and tend to cruise in the 90-100 kmph range, then the SFX will not disappoint you.
That's about it. The Pajero is built to take abuse and will continue to run come what may!
Tejas should be able to comment specifically about Mumbai. After having been fleeced by the ASC here in Bangalore, both on parts and labor, I am getting my Pajero maintained by a FNG who also procures original spares for me from Delhi.
My suggestion is to budget for 1.5-2.0 lac towards getting the car in shape and up to your satisfaction levels. In all probability, there would be a few things you'd need to replace in a 11 yr old car, unless the previous owner(s) have already done so. Once the car is "stable", all you'd need to spend would be towards yearly oil changes and if you stick to good old mineral oil, you'd be done in less than 5K per year.
Feel free to bug me with more queries if you have any! All the best :thumbs up
Originally Posted by locusjag (Post 4641561)
For 10 years now, we've been relying on a FNG mechanic to evaluate our used cars in the family. All our guy needs to do is .................................................. ............ch means. We place our full confidence in his judgment when evaluating used cars and it has worked out well so far.
Thanks for the input, Will try using this method but not sure how well would i be able to assess.
Have been reading through many forums about the pajero and everywhere i have read people throw in a word of caution of odo being tampered with.
I am really hoping / praying that its not the case with this one.
I am fine with crusing speeds of 90-100kmph.
Mostly all my long distance trips are leisure trips where reaching the destination in the fastest way possible is not at all the priority.
Its only me and my father who drive in the family, that too father drives very rarely.
Compared to today's standard the engine technology is indeed archaic but if its survived for so long and still running there must be something right that Mitsubishi must have been done right. As long as its happily munching miles being trouble free and light on the pocket I will not complain.
My Concern is the availability of spares and technical expertise required to work on the car in case anything does falter.
  • Suspension
  • Timing belts
  • Electricals
  • Clutch - might warrant a replacement unless not already done
  • Chassis inspection, to rule out an accident-involved vehicle
  • Service records, if available
A checklist is exactly what I needed, Thanks for giving it a start.
Other can keep adding to it.
What about the 4WD system, should I include that as well?
I have PM'ed Tejas as he is the go to guy for the Pajero and quite rightly so , after seeing his thread.
Awaiting his revert.
My suggestion is to budget for 1.5-2.0 lac towards getting the car in shape and up to your satisfaction levels. In all probability, there would be a few things you'd need to replace in a 11 yr old car, unless the previous owner(s) have already done so. Once the car is "stable", all you'd need to spend would be towards yearly oil changes and if you stick to good old mineral oil, you'd be done in less than 5K per year :)
This amount of 1.5l-2l that you have mentioned is it on the basis that if the vehicle odo is tampered, and the car has not been cared for properly in its 11 years of existence??
Thanks! Will definitely bug u.
Your inputs are actually worth more than 2 cents!
On an optimstic note considering everything checks out positively what would be an appropriate asking price for a 2008 Pajero SFX that has done genuine 54000kms.??
Originally Posted by iron (Post 4642008)
My Replies in bold
My responses inline
Have been reading through many forums about the pajero and everywhere i have read people throw in a word of caution of odo being tampered with. I am really hoping / praying that its not the case with this one.
Do not worry too much about it. Even if it has been tampered with, as long as the vehicle is running fine, should be okay. The odo unit in mine was kaput when I bought it. However, I liked the car so much that I just replaced it with a new one and moved on. Ah, the joy of driving a Pajero SFX with an odo reading of 000000 :D
I am fine with cruising speeds of 90-100kmph. Mostly all my long distance trips are leisure trips where reaching the destination in the fastest way possible is not at all the priority.
Then the Pajero will not give you a reason to complain
You hit the nail right on the head. The engine, while archaic, is a tried and tested unit, which can easily last you 3-4 lac kms with basic maintenance of regular oil changes. With a good clutch, you will be amazed to see its performance in the hills. After driving modern CRDi engines, where you need to be in the "power band" to get some tangible output from the engine, this one is a revelation.
The Pajero is a very easy vehicle to maintain, given minimal electronics, unlike today's cars. From what I have understood reading Tejas' thread, there are some competent Mitsubishi ASCs in the Mumbai/Pune area, you should be good on that front. Coming to spares, online vendors like boodmo, amayama, and megazip are quite reliable, albeit the wait time is tad high
It is a bulletproof unit, just like the engine and gearbox. Note that I have not listed these on my checklist either. Nevertheless, get it checked as well. A common issue with the SSII (Super Select II, the 4WD system in SFX) is "blinking green lights" while switching from 2H to 4H. Can be easily fixed by basic troubleshooting, and worst case, replacing the vacuum solenoid valves that operate the same. Other than that, any issues with the 4WD system of the Pajero are very very rare!
At the end of the day, a 11-yr old car is a 11-yr old car and age related issues are bound to crop up. Unless the previous owner has taken care of basic aging stuff, you will need to replace things like steering/suspension parts (upper & lower ball joints, tie-rod ends, bushes), drive belts, brake pads/discs, clutch assembly, engine/GB mounts, etc. You will get a better idea once a knowledgeable mech inspects the car. The expenses could be lesser but I am giving a worst-case scenario so that you can plan accordingly. It also varies from person to person - there are folks who would choose to NOT invest much on a pre-owned car and let components function till they fail but if you are one of those who prefer preventive maintenance, then the budget will go up. A key item here would be the tyres, unless replaced recently - if you go with a good A/T like Yokohama or Michelin, a set of 5 will cost you around 45-50K.
Pleasure is mine. Glad to be of help :)
On an optimistic note considering everything checks out positively what would be an appropriate asking price for a 2008 Pajero SFX that has done genuine 54000kms.??
Very hard to estimate without physical assessment of the car. Not sure about Mumbai prices but a ballpark for Bangalore would be in the range of Rs. 7-7.5 lac. Note that this should come down as the amount of work required in the car increases.
One question:
What is the typical FE pajero gives? How is it compared to fortuner?
Owners tell me it is a dismal 5-6 in town and max 10 kpl on highway
Does FE also get down with age?
Originally Posted by vikramvicky1984 (Post 4642216)
One question:
The FE will certainly reduce but a little care and maintenance should gradually bring it back to better levels.
ps - have you considered a Scorpio for your needs? About the same size and form factor as the Pajero, and more up to date.
Originally Posted by cool_dube (Post 4642186)
My responses inline
Your post clears a lot of things for me. It’s quite reassuring.
I searched for the ASC on google, it’s located not far from my place and has good reviews/ ratings as well posted on google.
What’s the difference between a 2007 Pajero GLX and 2008 Pajero SFX?
From the forums I have come to understand there was face lift that happened in 2008??
Came across brochure copy and spec sheet of the SFX posted in 2011 on the forum itself (Thank you Stratos) does this apply to the 2008 SFX? but couldn’t find anything on the GLX.
The reason I ask for details on a GLX is because I have come across one for sale.
I've heard other members opine that the Scorpio in its 4x4 avatar isn't as capable as some of its competitors in the offroading department. Of course, the OP hasn't sought a pure offroad use vehicle...but I just thought I could perhaps get your take on the topic.
SFX if I remember correctly had wider flares, airbags (not sure of this)
Only major update was BSIV around 2012 which actually reduced the power output.
To me what really makes the Pajero exceptional is the sense of control one gets from the seating position, view
due to the low bonnet and great visibility all around;unmatched by fortuner etal.
Of course the timeless design is a big plus.
Concerns are low FE & spurious spares and if matters: lack of high speed driving (which may be a blessing in disguise, tall vehicles should anyways not be driven fast)
Still looking for FE numbers from actual owners please:
One question:
I know two owners who have/had a Pajero for ~1.5L kms each. The FE was a consistent 8kmpl, no matter you drive in congested city or cruise on the highway. The worst was 7 and the best was 9.xx, all figures with AC. Fortuner should give 1-2 kmpl higher.
Having personally driven a Pajero and Scorpio, for 300+ kms each on the same stretch of road and on consecutive days, I can say that Pajero is miles ahead in comfort and handling. Scorpio has a better performing engine.
Well, if you are looking to replace your primary car with the Pajero - Dont.
That said, Am I happy with my Pajero? Hell YES!
With the current prices, the vehicle is an absolute value for money. You can get a good one for the Price of a used Thar. The Pajero is probably the best in:
Well now - The choice is yours.
Here's mine:
